Pontiac Sunfire Transmission Problems
I have a 1997 Pontiac Sunfire GT with an automatic transmission. Whenever I make a left turn at a reasonable speed it will shift down for a split second and shift back up, then will stay in gear (2 I think) for a few second and then shift back down for another split second and quickly shift back up and then will stay there as I accelerate away from the intersection. I thought it might be the way I drive, but it keeps getting worse. Any idea what could be wrong?
I need to bleed my hydraulic clutch. Anyone know where the bleeder valve is? Is there anything I should look out for when bleeding a manual clutch that is different from bleeding brakes?
Jim
I'm wondering if every time i bring the car in the techs at the garage reset the computer on the car,....because they can not find any error codes. SUNcrape.
ANY ONE ELSE THIS HAPPEN TO >>>>> help
Now i am certainly am going to sell IT. Pontiac Sunfire sucks!
Anyone else have this problem?
I've had a trustworthy garage check the clutch without result. Could this be some sensor or an electrical issue?
Any ideas? I love this car and don't want to give it up!
The previous owners replaced the transmission, and it still will not shift into overdrive.
It tops out around 50 mph at 4k-5k rpm.
If anyone can help me diagnose this problem i would greatly appreciate it.
