Ford Focus Engine Problems
Hello, i bought a new 2007 Ford Focus six months ago, i have barely over 10k miles on it. today i was driving to work and smoke started to come through all the vents, so i pulled off the freeway and popped the hood. the engine was on fire. looked like it started from the alternator. its under warranty and got towed to the dealership. the service dept is closed until monday so they cant look at it until then nor will they give me a loaner. has anyone ever heard of this happening? My warranty should cover this i hope.
not too happy with Ford right now.
See also: Ford Focus Engine Vibration Fix (Video-6:39)
Somehow a large piece of plastic, like a tarp or something got entangled in the engine and part of it got caught up in or around the alternator. it was not the engine. Ive never heard of this happening before. The Ford dealer actually had to melt it off, how i dont know. Bottom line it was not the car, Ford did not charge me and everything is good with the car. it just took a total of six days. Its kind of embarrassing.
i wouldve never guessed these things happen.
Yes, running your car while having the air conditioning turned on does burn or use more gas then if you had the A/C turned off.
Using the air conditioning in a vehicle turns on the compressor which makes the engine work harder to run this component of the car along with the other parts the engine is already running. The harder the engine works the more gasoline or fuel that it needs and uses.
However if you are comparing using the AC on the car to rolling down your windows there may not be a difference in the amount of gas used. Rolling down the windows and driving puts drag on the car and again makes the engine work harder to overcome the drag coefficient and thus uses more gas than if the windows were in the up position.
In all the studies I have read or seen they say the amount of extra gas used for running the air or rolling down the windows is about the same but that most people agree that it is more comfortable to have the air conditioning turned on then have the windows down in the heat of the summer.
If the weather permits you to neither turn on the air conditioning nor roll down the windows in your vehicle then you should get better gas mileage then in the warmer months when you will feel the need to turn on the A/C or roll down the windows to let the wind cool you down.
http://www.carinsurance.com/kb/content25587.aspx
Incidently, the AC compressor runs if you turn on defrost when its over 40 degrees outside.
Mark
http://www.sparktecmotorsports.com/h10086.html
It is a friends roommate's vehicle.The part has an attachment, that looks like should have something on the top of it.
Did you ever find out what was wrong with your LX? The reason why I ask is I have a similar problem. I can't pin point it exactly because the wurring noise seems to be associated with the steering. As the wheel is turned to the right, it sound increase 5 fold. Backing off it goes away. My problem is not exactly like yours however some feed back would be appreciated.
Thanks, Jack
Carl
I could turn the key. $300.00 later it was repaired. Can't complain about $300.00 repair for 120,00 miles and great gas milage.
Hope this helps
Caccia
Its under warranty.
Mark.
If you can find a way to let your car sit for a day and then take note of how easy it starts (or not) you may be able to determine if you're losing fuel pressure when it sits. If it is, there has to be a leak, however small and hard to find it may be.
Dropped the wife's 2006, 25,000 mile, 1.6 (Duratec) Focus in for its 3 yr service this afternoon. Service manager phoned this evening to say that they have broken 2 sparkplugs off in the cylinder head, whilst trying to remove them, as per service requirements.
Now they want ME to pay for them to remove the cylinder head and repair, I don't think so mate!!!
Has anyone heard of a similar problem ?
Service history is complete and with main dealer
My own mechanic says the coolant is probably being burned up in the engine because of a head gasket leak or crack (considering the head is aluminum). No visible leaks with putting a large piece of cardboard under the car for a month to see. Nothing. No sign of coolant in the oil either.
I've been late to work each time (work only about 5 miles away), and was warned I will soon be disciplined if it happens again. This problem is not only causing me frustration, but could cost me my job! What should I do? They won't listen to my mechanic. The dealer just reassures me it won't happen again, and they've finally fixed the problem, but it still overheats. Time to drag out the lawyer?
Hope this helps you.
Any help would be greatly appreciated. Thanks.
If you don't find your leak, you have an idle air control valve,it's round, about 3" long,
w/electrical plug on 1 end and mounted to intake manifold w/2 8mm bolts. you should be able to find a new one at a NAPA store.
Cliff
Cliff
My questions are: should the serpentine belt be changed with the timing belt as a preventive maintenance thing. Also, I'm told the water pump is not driven by the timing belt on a Focus as it is with other four cylinder engines. Should the water pump be changed with a timing belt change to avoid labor expenses to get at it later on?
