Is there a fix or is the Civic's design inherently flawed? If Honda eventually agrees to replace the IMA battery packs, will we feel like we have a reliable and safe car? We will still have the same gas engine and will be at the mercy of Honda's software upgrades. The new IMA batteries may work fine for 2-3 years but it could deteriorate in a few years especially for those who live in hot climates.
Also read in the owners manual that if the 12v battery goes dead or is disconnected, the IMA system will read lower than normal battery charge levels for up to 30 minutes of driving. Still hate the possible financial drain if the IMA battery pack is going bad.
So for that electrical question I need to figure out what logic to start the car needs the small boost from the charger.
I checked all relays associated with the A/C that is in the fuse block under the hood, and they appear to be OK. The next item I will do for the following week is to turn off the A/C switch every time the car is shut down. Maybe there is some logic that is sensing the switch being left on, and this is operating the A/C clutch randomly with the ignition off, killing the 12v system.
A new study by J.D. Power and Associates states that sales for electrical and hybrid automobiles can be slow for at least a decade. The report utilizes current sales of electric and hybrid vehicles as a starting point, which are a tiny portion of overall passenger autos sold worldwide. It is estimated that in 10 years, the sales won't grow significantly. The study projects that just over 7 percent of all sales worldwide could be hybrid or electrical by 2020.
Regarding the effectiveness of my complaints, I tried everything I could to try to get the attention of Am Honda and the dealer. I'm not sure how effective the NHTSA complaint was, but if a number of consumers were to file similar complaints I'm sure it would attract the attention of the govt. Am Honda did respond to my BBB complaint saying that the changed performance of the car was normal. I know that the dealer responded because of my complaints, but all I was able to accomplish was getting a good deal on a trade. I agree with you that the car suffers from engineering deficiencies.
Tonight the car will set with the A/C compressor and blower relays removed. WIll see if that changes things.
Did the car give any indication that the 12V battery was not being charged or that the IMA system was not functioning? Normally, the IMA light will come on with the battery symbol just like in a standard car when the alternator fails. When the 12V battery finally dies, the dash lights and gauges start to flicker and reinitialize a minute or so before the engine dies.
If none of that happened, then something else is going on here and it may not have anything to do with the Hybrid battery.
The change in speedometer accuracy will affect the accuracy of the mpg gauge for the purpose of calculating the mpg effect of the new tires, so they may be more than a "slight" loss of mpg, but that has no effect on the IMA system.
Your other symptoms sound like a P1449 error, but you should have an accompanying check engine light as well. Please feel free to contact me privately and I'll help you track down what is going on. It is possible that you have a wiring problem to the dash.
The length of Honda's warranty on the replacement battery is not a good sign -3 years? That means you would have to fork out for a new set if they give out after the 3 years. And we've found out that Honda won't replace them unless the IMA light is on even if it is clear they are going
The Prius gets around this by only using about 40% of the battery's capacity while Honda uses 60%. The Gen-II Prius use less cells than the Gen-I Prius but they amplify the voltage to make it usable. The 2010 Insight and the CR-Z use 84 cells which should stay balanced longer. Than the earlier models.
If this is true, and I am not doubting it, then there will always be a problem with these cars. There is not a permanent fix. Isn't this the thing that class action law suits are made of? Anyone remember the class action lawsuit against GM for the diesels it made in the late 70's and early to mid 80's? The settlement required GM to repair these cars free up to 100K miles because there was no permanent fix. These cars generally begin to fail around 30K miles and every 30K miles thereafter. Maybe the Civic hybrid is not as bad, but it is the same principle. Wonder if any of those lawyers are still around and need work.
Of course the bottom fell out of the resale values of the GM diesels and people that did not mind the inconvenience of continuing repair bought them for a song. These were mostly Oldsmobiles, but also included Pontiacs, Chevrolets, and a few Buicks and Cadillacs. All the engines were made by GM's Oldsmobile division.
Is this food for thought?
Nothing lasts forever. The batteries are covered for 80K (or 150K in CA) miles. What is acceptable? 120k? 160k?
The gen-I Civics that I see are all high mileage (lots of highway) cars because all the rest are still under warranty. The 2003-2005 batteries seem to last either 90k or 120k or 160k. I think 160k is a reasonable life for a battery, don't you?
Honda's changed software should push all the non-damaged (not previously damaged) batteries up to at least an 80K life.
The reason that the 2006+ Civics are having more problems is twofold. 1: the car is heavier than the 2003-2005 Civic and 2: there are 10% more cells in series.
I don't have a definition. I was just pointing out that in the GM class action suit they used 100K miles for free repair. I don't know what the average failure millage is for the gen-2 Civics, but it seems that these hybrid battery problems are occurring often at less than 80K miles. Unfortunately, mine occurred at 90K miles. Since this type failure affects performance drastically, maybe it should be at least 150K.
Perhaps. However, expectations of engine life these days is from 200K to 300K miles. Since this car is dependent on the battery for proper performance, maybe it should be higher.
That's great for Honda, but no one else. To me that is unacceptable and is not really a fix for the design deficiency you cited.
The relay appears to be interchangable between five others in the fuse box, but don't want to mess up another system by switching them around.
When I tried to start my car tonight, the green key light on the dash starts blinking and the car doesn't start. (light blinks many times for a few minutes, when I turn the key to the lock (0) position, it blinks 8/9 times and turns off)
I check my handy dandy service manual, follow what troubleshooting steps I could (since I don't have all the equipment the garage does), all to no avail. Double checked all the fuses, they were fine. The car locks/unlocks fine, but as soon as the key is in the ignition slot, the car doesn't lock or unlock from the fob.
Is there any way to fix this without having my car towed to the dealer? (probably not, as my ECU probably needs to be reprogrammed).
Oh, and I just had my car looked at YESTERDAY by the dealer because my mpg went from 55 to 34 (Yes, I was getting 55) because the damn IMA would recalibrate every morning (my guess is the ECM would lose track of the battery voltage as it dropped overnight)
Coincidence? Hmmm
I'm now sincerely scared to take my car anywhere. What happens if I get stranded?
If this problem happens one more time, I'll pull out the lemon law. The prius seems like a better engineered car, which isn't saying much for the prius, since the HCH was obviously designed by engineers who got their "Degrees" online. With all the battery problems... I can't WAIT to get rid of this car!
On Monday the IMA and check engine lights came on but did not notice any differences in car performance. I called the dealer and made an appointment to get it checked out a couple days later (lights stayed on) and the car returned code P0A7F.
From reading on the internet I guess this means that my battery is degraded. Honda's fix was to load the new software update (which, I had been avoiding given the mixed reviews I was reading on this forum). The guy at the dealer told me that this should fix the problem and they tested the car and is performing as expected. I've only driven it a little so far and don't really notice any differences. Doesn't seem like the car is charging as much and continues to lose charge quickly (my morning commute is about 1 mile, 5 mins drive. From overnight park appears 3/4 full but by the time I get to work it is only 1/4 full.).
Any advice on what to expect? Should I expect battery failure soon? I find it hard to believe that if my car is registering battery degredation (ie: hardware problem) that a software patch is going to fix it...
The software upgrade on your car may prolong the IMA battery's life but the check engine and IMA light signify to me that your battery is substantially gone and that the check engine and IMA light will come on again fairly soon. You will have a stronger case to make to Honda to replace your IMA battery. But who knows how long this could take and how much Honda will drag its feet?
I will hook up a volt meter on the relay signal contacts to check on the possibility of random voltage, and not just assume that the relay is bad.
As an OBTW, I have never gotten the software update that Honda offered free up until June 2010 as a voluntary 'recall'.
Think more long term. The first 2003 Civics are now coming off warranty for time not distance. 2000 and 2001 Insights are now too old. 80K is great for the person who drives 7K per year.
From what I know of the updates, it should extend the life of a 15k per year driver to more like 150k (starting with an undamaged pack). It is helping some damaged pack come back to life. Others have problems that can't be corrected this way.
The only problem is that it reduces the amount of charge that it allows the driver to use and that leaves some people with an empty battery when they wanted power.
I'm lost and simply don't know what to do about my problem. I purchased a new civic hybrid in August 2007. I'm a retired teacher, not driving much. The IMA light came on in October 2008 at 2096 miles with code P0A7F. The module was replaced. Now, December 2010, the light is on again. The 3 year warranty on the car is up but I'm only at 4880 miles. Will honda pay for another IMA replacement because of the low miles? I've read elsewhere that this can cost as much as $3000. I cannot afford this every 2 years and really thought I'd have this car forever. Thoughts please and thanks.
