Honda CR-V Handling and Alignment
Bought a new CRV EXL on July 1st. I have noticed that the car "shimmies" while driving (i.e., shifts right and left, especially on the freeway at higher speeds (approx. 70 mph). I feel the ride is unstable. Is anyone else experiencing this problem? I have brought it to the dealer once and they couldn't find any problem. Very disappointed as I am a new Honda owner after being a GM owner for years. What are my options if I am unhappy with what I feel is an unsafe ride? Any input would be greatly appreciated. Thanks.
Would not this have been addressed during the "new car prep"? as well as checked off & corrected to proper PSI from the check list in the owners manual...
thru rain grooves, scary loose. Checked my tire pressures and they were all about 10 psi LOW. Aired them up to the high side and its much more stable (not perfect)but much better. Don't bet that they are aired to 45 psi. I do agree its all tire design though.
JJ
I have an '07 2WD that pulls/drifts to the right. They had the nerve to tell me that a pull/drift to one side or the other could be a "design feeature". Could that be true? The service technician took it for a drive, but "found" nothing by taking it over some random bit of freeway to see if it would drift/pull in <= 500 ft. The dealer put it up on the alignment rack, and told me that it was within Honda's spec. I wanted to argue with them, that there was no way it was within spec if it pulled - it was a safety issue. Dealer made me feel guilty/stupid for urging him to put it up on the rack for an "expensive" test that a test drive should have proved out.
I'm going to press them harder - I see lots of talk here about the "crumby" Bridgestones that come from the factory. Maybe those are the culprits?
Are there others with alignment issues? I sure would love to hear about it.
Many thanks.
Swap the front two tires. "If" radial pull is the problem, the issue will go away or pull to the left.
If nothing changes, the issue is caused by something else.
Any other alignment defects on the 2007 CR-V models? If so, we just might have a class action suit.
Did you test drive the car before buying?
I have bridgestones.. i noticed some CRVs have continentals.. maybe the difference is there?
PEACE.
It is puling to the right and they seem like can not do anything about that, they check and recheck alignment again. Just called Honda customer service and let them know, will file all necessary documents for lemon tonight and call BBB Automotives. If you have same problem with 2008 CRV please do the same.
Business hours are Monday through Friday, 6:00 a.m. to 5:00 p.m., Pacific Time.
By Phone
At our toll-free number: 1-800-999-1009
http://automobiles.honda.com/information/customer-relations.aspx
Okay, thanks for the info. But what is the camber Bolt and can that be fixed.....Please
I'm very desperate, I've had the owner of the dealership that I bought my fromt and he
basically states they can't do anything else to the vehicle. I love the vehicle except for that.
Write me back, please
Is there a mileage issue with the lemon law, I have a little over 5000 miles on mine now..
Thank you for your time and patience in letting me know. It's very valuable information. I cannot see me driving this car for 5 years feeling like your driving crooked down the road.
I think you are describing two different issues.
PTTR is when the vehicle drifts to the right while cruising, without acceleration.
What you describe on take off is called Torque Steer, and is inherent to many FWD vehicle. The Accord is a different platform, which is designed to accomodate V6 engines and associated power, and may have equal length drive shafts to minimise or eliminate torque steer. CR-V is based on the Civic, which was not designed to accomodate engines with lot of torque. So, by shoving a 2.4 liter engine on a frame designed for the 1.7 - 2.0 liter engines, torque steer is more pronounced.
Lemon Laws are state dependant. You will need to read up on the Lemon Laws for your particular state. There is no Federal Lemon Law that applies to everyone.
http://autorepair.about.com/cs/generalinfo/a/aa012201a.htm
Thanks for all your help!
Teresimo
My CRV was built Jan, 2008. It does not pull to the right or left, tracks straight and true on the highway and around the suburbs. No pulling when accelerating from a dead stop.
The steering wheel is straight. No vibration at 70 mph.
Also the 4 cyl engine accelerates as fast the 6 cyl 2.7 in the Hyundai, highway and suburbs.
I guess I got lucky, or maybe the problem is fixed on late builds.
I just wanted to know if you issue with your CRV was resolved. I just purchased one in March of this year and I am having the same problem.
