Lincoln Town Car Water Leaks
I own a 2004 Town Car Ultimate (no sunroof) that has a problem in the trunk area. After it rains, when I open the trunk, water drains out of two holes on the underside of the trunk lid. AS the trunk lid is opening, the water goes directly into the trunk area. I have complained to Ford Motor Company about this and they say it is within factory specifications. I would like to know if anyone else out there in Lincoln-Land has the same problem. If so, would you please reply to this post and let others and me know how you got it resolved?
Thank you..........Silverton
I didn't expect a reply so quickly. That's great. It shows me that there are people out there who care about what's going on around them.
Thanks again, euphonium.................Silverton
.link title
Actually,the carpet is kind of easy to remove.Back seat out,trim removed,front seats out and there you go.I'll admit that I had the body shop remove it because I don't have space or time to do that,but I did have the trim off and back seat out for a while myself.
"REMOVED BLACK PLASTIC LEAF/RODENT GAURD & RAN WATER IN LEFT CORNER ON BODY--SAW LEAK INSIDE AC BOX-NOT A WINDSHIELD LEAK--
-GASKET BETWEEN AC BOX & BODY LEAKING INTO BOX & ONTO CARPET BELOW GLOVE BOX ON PASSENGER SIDE--REMOVED SCREWS--LIFTED PLASTIC--APPLIED SILICONE SEALANT TO GASKET & REPLACED ALL---LEAK GONE---GUD LUK---RUDY IN LA.3-17-05" and "dealer said that this is a common issue with TC. There is a air supply intake for the A/C system that can develop a leak at the gasket. The water will run down inside the door and soak the passenger carpet. They fixed it the first trip and I have not had any problems since."
Thanks again,
Your fix seems (to me) that this must be the problem.
I have 3 Town Cars (airport service) and each one has
wet floors on passenger side only. I'm going to try your method.
I'll let you know.
TCGUY3
Two hundred dollars later it was fixed and they said thats all it was.. No more problems..
Melba
Remove the side sill plate in the front and the kick panel than pull the rug up enough to feel under the carpet. if it is wet than you may have one or all of a few issues 1. it may be as simple as debris stopping the plennum/air vent cover from draining 2. it may be tht water is getting under the air vent cover and entering the heater case. 3. you may have water entering around the heater case, or 4. you may have a cowl seam leaking ( the worst case ) . let me know if there is water under the rug
remember there are a few things that can be happening at the same time to soak the floor. if the cowl seams leak you will have to remove the right front fender and probably the hood to access the seam which wraps behind the fender . happy hunting
what state are you in?
good luck
thanks for all your technical help-
rob
Is the screen you're talking about under the removable black plastic piece that can be removed with the long plastic screws on the passenger side, when you lift the hood in front of the windshield? I found some debris in there but didn't look further. What is this screen for-fresh air? I'm assuming everyone is saying that if water leaks through there it will eventually wind up on your front carpet and if it leaks a lot, can eventually find it's way to the rear as well since it's lower. I have to find this problem as I'm not garaging my car at present and every time it rains, I'm getting some moisture. At least this explains why it's only on the passenger side front and rear.
* digg
* delicious
* stumbleupon
* netscape
* addthis
I had that issue and I did the plastic fix under the hood.It's raining here today as well so this is the test for that fix.I'll let you know how it's doing later today.
