Mazda 323 Electrical Problems
1992 Mazda 323 - just replaced the alternator and car ran OK for a few miles. Now at times the discharge light comes on and vehicle looses power, radio quits working and lights go dim. This problem comes and goes. Battery holds a charge so I don't think that is the problem. Any suggestions will be appreciated.
my dashboard lights dont turn on when i turn the lights on . just wondering if its a fuse or maybe light globe or somin like neone know nething about it.
Just bought this 1994 mazda 323, got 2 days driving out of it and now won't start. Turns over fine, but not starting. So I changed the fuel pump, new coil, new coil wire going to distributor cap, new distributor cap, new rotor. All fuses are fine, both inside the drivers panel and the ones in the engine compartment. And there is power going to the coil - weird huh - but nothing coming out.
Distributor gone? Timing? Ignition? It was starting fine, then we stopped, turned it off, and never started since.
But there is still no spark. Also we only have 6 volts going to the fuel pump, shouldn't it be 12 volts?
I'm totally fed up with the car, so if someone knows anything about these, maybe its a common issue, I really don't know.
Argggggggg!!!! :mad: & many thanks
