Chrysler 300M Electrical/Lighting
The lights up over the windshield have started blinking whenever they feel like it. They will blink a few times and then stop. There may be other lights blinking, too, but it only has happened when the car is moving so far and i can't tell.
I would expect that these lights are controlled in a number of ways. Unlocking the door, nights when getting out of the car, turned on by pressing the light, others.
Any idea what causes this or how to fix it? Are the lights controlled by the car computer or in some other way?
I have a 2000 300M mileage in the 70,000.
Stan
Stan
I have a 1999 Chrysler 300M. It has 158,000 miles. I got in it and turned the key and that's when the problem started. I will list the problems in order to keep the message as short as possible. I could not arm the alarm, doors will not lock by using the power switches on the doors,the rear windows will not go up or down and I can only let the front passenger window up, not down with the driver switch, the a/c and compass comes on at 75 degrees and there is no electricity going to the a/c compressor.Electricity was applied to the a/c compressor and it worked fine. The interior lights will not come on, the power mirrors have no power, the radio has no power, and the turn signals will not come on. The funniest of the problem is when I turn the key to start the car the horn blows! Is this a sign that the body controller module has gone bad? I have enjoyed this car and I do not plan on getting rid of it. Any help or advice will be greatly appriciated!!
Thanks A Lot
Issues I've had:
Currently passenger rear window wont go down.
Passenger heated seat works-sometimes-??
oh yeah and the car doors attract door dings like crazy???
Good info
Thanks again!
coldknight300
coldknight300
Does this model use a mercury switch?
Thanks! TED
When I went to start up the car and leave, I noticed that when I turned on my lights fully, and then turned on my fog lights, the hazard (or left/right turn indicator on the main console) was on. It wasnt a bright green like when the hazards are on or when I am turning, but a very dim green. I then went to look outside, and my fog lights would not come on. Whenever I turned them on, the yellow lights on the front sides of the car would brighten up. I then went to try out my turn signals, and they were blinking as if on a crack rush. They would blink at very high speeds, but go back to normal as soon as I shut the headlights/foglights off.
I am not very vehicle savvy but I imagine this is maybe a fuse. But I wanted to know if anyone on here had an idea of what might be wrong, or if any of you have experienced this. And if so, how I can fix it. Thanks!
Anyone have any thoughts ideas or same problem?
I´m living some 100 km above the arctic circle and for some years I´ve been driving a -99 300M that runs smoothly. The other day the headlight (drivers side) went out.
As I understand it´s a bit tricky to change bulbs, so before starting I would really appreciate some advice from any of you hardened Chrysler owners that knows how it should be done in the best way. Thanks in advance.
I am having the exact same experience. What answers did you get to resolve it. I have been checking the wiring harness under the front passenger wheel. Does anyone know where I can get this part on the cheap? Please Help
Has anyone else ran into anything similar?
I recently purchased a 1999 300M and the overhead interior lights seem to be burnt out or might be an electrical problem.
I can't seem to get the piece off to check the bulbs. I only see one screw and I took that out and the back seems to pull off a little but the front will not budge and I didn't want to break it.
Please help me understand how to take this piece off so I can check the bulbs. It's the overhead lights pannel where it shows the temp outside, MPG, and other things.
Anyone??? Please help...
I have a 2003 300m special...and am having issues where all of the lights work sometimes and not others. This makes it difficult to see my rpm and speed. everything else seems ok. any ideas?
Thanks! Barb
Jill
The fuse box is under the hood in the black box in front of the coolant container.
The cavity number is 20 and it uses a 20 AMP C/BRKR.
Looking for help!
I own a 2000 300m and have had the problem that you are having a few times. I had to call a locksmith to fix it. He said that it is a common problem with the 300m's - the ignition locks! :shades:
It doesn't look like anyone has posted on to this thread for several months, so I hope this wont fall on deaf ears (or no ears at all, for that matter). I came here to see if I could find a solution to the latest problem on my car, and all I realized is that my car totally blows. I read MANY posts. I wish I read them years ago. Right now, I have some bat-[non-permissible content removed] crazy electrical problem and my car isn't starting at all. Not even a noise when I turn the key... not even a dash board light (usually... sometimes every light possible is on... but it still wont crank)
So, here is an open letter to all 300 M owners who have posted here... please enjoy.
To the person who experienced both of their coolant fans seizing and is overheating if not in constant motion to draw air through the radiator: Been there (for years)
to the one who's ignition wont turn (seems locked?).... You'll need to replace the whole ignition switch/lock/cylinder. I did.
To the guys and gals with possessed interior lights. Its weird at first, but you get used to it. The flickering and flashing never ceases to freak out your passengers.
To the people who have their car cough and stutter and stall out completely... O2 sensor or swithch or intake something or other. Its a [non-permissible content removed] but at least its not your transmission.
To those whose seat heaters stopped working: Let me know if you find an easy fix...its just not that important to me. I have been without for 2 years.
To anyone whose AC went out: I have been driving without it for the better part of 4 years.
You say your wiper fluid light stays on when full, but goes off when empty? Yeah, me too. Thousands. There is way too much to take apart to fix it.
Radiator leaking? May be due to the fact that you overheat from time to time because those fans stopped working. sucks.
Do your front woofers work? I blew mine out in 2005 listening to talk radio.
Oh... my alarm goes off every time I use the key to open the driver's side door... my key fobs already failed. I have to unlock the car from the passenger's side, but it makes me look like a gentleman when on a date.
Sometimes my headlights will turn on buy themselves when Im not even in the car. I think thats cute.
The tires... can you pick a stranger size of tire? Unless you really shop around, they will cost you over $200 a pop.
I havent even touched on the basic maintenance of the car that I hate so much.
So, if you re wondering what is wrong with your car, it's that you own a 300M. they absolutely suck.
If I didn't get laid off, I'd buy a new one. Mine doesn't even start now due to a seriously freaky electrical problem The bright side is that I save on gas money, something that this POS has never been very good at until now.
Anyway, its a good thing that I don't have to drive to work everyday or else this thing would continue to nickle and BENJAMIN me to death.
I get a hissing sound when I push the brake pedal. You can hear it while sitting in the car, the brake has to be pressed all the way to the floor. I have not driven it at all as this would definitely not be safe. I have thought master cylinder could be the problem or perhaps the brake power booster. I mean we all have the same car their has to be similar fixes right?
And for most of you who are having electrical issues or stall out issues. Try simply getting the battery positive ad negative terminal wires and posts changed. For some reason chrysler thought it a good idea to place the battery low on the car and by the wheel well no less. I was stalling bad, thought it was the alternator, NOPE simply the positive/negative connection wires that were beyond corroded and the posts were barely touching the battery(stripped)
I'm having problems with the front passenger power window. The damn thing is stuck in the down position...fortunately it's not down all the way (this time). It was stuck in the down position one other time so I took it in to the shop to have it fixed. I had to have the door torn open and the motor replaced - cost me $150. Now the window is only down a little bit, but is stuck again. I don't want to pay to have another motor replaced, so for now I've got plastic taped over the opening...real attractive.
Anyone have any ideas for getting the stupid window back up....that won't cost me money? I've already tried forcing it back up...didn't work.
I am curious about your car's headlights coming on and off by themselves, as I have had ta similar experience with my 2001 300m. The car belonged to my father, who passed earlier this year. On two separate occasions (as I stood talking to two friends)~the tail lights came on a off a number of times in rapid succession, as if they were blinking at us. The car had not been driven recently, was locked, the keys were in the house, and no one else was in the vicinity. Yesterday was the second occurrance of this phenomonen, and this time, the lights went on and off about three times and then stayed on. After several minutes, with the lights still on, I told my friends~ the same friends that had been with me the first time~ that I was not going anywhere until the lights went off~which they did, about three seconds after I made the comment! Is this similar to the experience you have had? I am curious to know more about this phenomenom, and if others have witnessed the same thing. Thanks!
By the way, are you familiar with the device that keeps a car battery charged at all times? It is mostly intended for people that don't use their cars very often, but it might be helpful for your daughter, if her battery runs down frequently due to this problem. If you need more info, let me know and I will check on details from my friend who has this device.
Best wishes,
Diane
Please forward your solution.
There are two simple ways to prevent this problem. This problem is the result of the windows becoming stuck in the door frame insulation. If the windows are closed to just touching the door frame they will not get stuck. Close them all the way and then open it just enough that the window stays in contact with the door, but is not driven deep inside the insulation. Another solution is to just make a point of opening the windows once weekly because if they move out of the door insulation periodically they do not get stuck inside it. I find it works well in winter to just make opening the windows for a moment part of my routine of letting the car warm up.
