I improved my seat comfort in my 2007 V6 XLE Camry. ------- I purchased two pieces of 2" foam, (cut to fit the size of the base of the front bucket seats), and I covered them with gray toweling. I now sit on these cushions, and it makes the seat vey comfortable on long drives. ------ Something that you might want to consider. ------- Best regards! ------- Dwayne :shades:
I just went to a "Bath Store" and purchased two large bath towels that matched the interior of the car. I folded the towel around the foam, and made it into cushion. It works! ----------- Dwayne :shades:
Thank you for any advice on strategies to remedy this.
Even with the pillow, I'm still not 100% crazy about the seat, but I'm hesitant to have it taken apart and rebuilt because I know from experience with other cars that that doesn't always come out right. When my Pontiac seat had to be rebuilt, it took 3 or 4 tries, and I was in agony before they got the right foam and feel.
Another important thing is to be conscious of the fact that Camry seats are made to sit in firmly like on a chair, rather than the way I learned to sit in my cushier former cars. Sit up straight, legs in front of you, like you're at a desk, and that helps.
The other major thing that I did to improve the ride is reduce my commute to work from 15 miles to 6. It's easier to stand the Camry for 10 minutes at a time as opposed to 25. For longer rides, I still have my '97 Pontiac Bonneville that, thank goodness, I didn't trade in. Hope that helps.
I commute 130 miles often, so comfort is important. So, I'll look into an add-on cushion. That seems to be the best option short of re-upholstering, which as you note, is not a sure thing.
I've had it to 2 different Toyota dealers and yesterday to my regular mechanic. 1st dealer said to disconnect the battery and bring everything back to default positions...no difference, battery was off for 35 minutes. 2nd dealer said to have the throttle body cleaned, which I did...no difference. A bit of background with the vehicle, I've had it since new, I drive 170 hiway miles per day, I use Shell branded fuel, oil changes always at 5,000 miles, dealer serviced since new.
So yeaterday my mechanic checked everything, engine mounts (OK), any error codes (none) cylinder compression (all within spec) spark plugs (OK except for 1 so I asked hime to change them all), he installed 4 NGK iridium plugs and guess what...it still shutters & vibrates!!
Anyone out the have any suggestions?
Anyone have problems with the driver's side sun visor? Mine fell apart and once again Toyota didn't see it as their problem so I paid an independent mechanic to replace the part. He fixed the problem for much less than the dealer would have charged, of course.
