Buick Regal Check Engine Light
bbernander
Member Posts: 6
in Buick
My 96 Buick Regal's check engine light continues to stay on. I have reset it by disconnecting the battery and have filled up with new gas which worked for about 3 days. The engine seems to sputter once in a while either from a stop at a light or around highway speeds. I have noticed as well the gas gauge has started to float as well when turning corners. What would you say would be a good option at fixing this or the possible cause.
I own a 2002 Buick Regal. I am having some trouble with the car when driving it. I feel a stall or stumble that really jars the car. It is like the car shuts off. This lasted for a number of weeks and the dealer couldn't tell us what was wrong. There was no engine light for weeks while experiencing this problem. Finally the service engine soon light came on and the code we got was for the Mass Airflow sensor. I changed the sensor with a remanufactured unit and reset the code and the car ran fine for 6 to 7 weeks and now it is doing the same thing again but no service engine soon light has come on yet. I checked the sensor and the new one is connected up nicely, the battery cables are clean and not corroded in anyway. There are no codes in the computer at this time telling what it might be. It just has this stumble and it has stalled out a couple of times. Can you give me any advise as to what to do at this point.
Hard to say about getting a new one. Funny though that's it's not putting out a code. It cost me around $350 at my Buick dealership for a new MAF sensor, I think that included $90 for diagnostics.
The engine continues to studder which it seems the RPMs fluctuate when coasting and at idle. The RPMs will dip for a second, slowing the vehicle a little and then resume to where it was. And this will continue. At idle the RPMs will fluctuate from 1000 which is a little high to 500 and then back. Plugs and Fuel Filter have been changed, the plug wires seem to be in good condition by looking at the tubing themselves but I am confused as to what else it could be. Any other suggestions?
What to watch out for
Mass Airflow Sensors are often replaced when the only problem is a bad connector or the sensor wiring harness. The shop should check these items before replacing the sensor.
"High-performance" wet foam air filters are not recommended because they will damage the mass airflow sensor and actually cause poor performance.
Recommendations
The air filter should be replaced along with the Mass Airflow Sensor. Dirt and debris should be cleaned out of the system to prevent any damage to the new sensor.
Why this happens
A failing mass airflow sensor can cause the "Check Engine Light" to come on and due to high nitrous oxide, the vehicle may fail an emissions test.
If the Mass Airflow Sensor is not functioning correctly, the vehicle may lack power when accelerating or going up hills
I had my MAS replaced a few years ago to the tune of $300. I'm sure the dealership checked for bad connections and only replaced it if necessary... not!
Car has 59000mi. Is there a check to narrow down which components are bad. Car does not have a turbo and never has.
291 days and 20 hours ago.
Reply
Removing the battery cables and putting them together did not solve the problem. I dont know what a scan tool is. my a/c was working very good. I was having no problems until the new battery was installed. There is the push button climate control in the dash and buttons on the passenger door that says cooler and warmer on it. Sometimes when i push around on some of the buttons the outside temp light will quit flashing and i get heat. with the air i get cold on the driver side and heat on the passenger side dashboard outlets. ajusting the climate control on the passenger door does not change the heat to cool.
Posted by Bob 291 days and 20 hours ago.
Answer
I understand the ac WAS working ok before, but there is a TSB from Gm on this exact problem and this is the bulletin. It could be just coincidental when you changed the battery the controller is the problem. A scan tool can check the body control module for codes and show you the right direction to go.
#02-01-39-001: HVAC Temperature Difference Side to Side and/or DTC B0361, B0441 Set (Replace HVAC Controller, Splice into Backlighting Circuit) - (Feb 7, 2002) Subject: HVAC Temperature Difference Side to Side and/or DTC B0361, B0441 Set (Replace HVAC Controller, Splice into Backlighting Circuit) Models: 1997-99 Buick Century, Regal 1998-99 Oldsmobile Intrigue with RPO CJ2 Condition Some customers may comment on a temperature variation between the left and right hand ducts. Typical concerns may include that the right side of the vehicle cools down but the left stays warm or the opposite. This condition is sometimes associated by the customer with a recent service visit for other non-related repairs. The codes, DTC B0361 or B0441, may be present but will not illuminate a telltale lamp. Cause The HVAC controller unit and the TEMP door actuator motors rely on a feedback system that supplies the controller with count values in order to accurately adjust the air temperature. When battery power is interrupted to the HVAC controller, the current actuator position values are lost. When power is restored, the controller will perform a "sweep test" of the doors from full cold to full hot and record the end values for reference. Over time, the TEMP doors may develop some flexing when run to their extremes. This flexing allows the count values to run out of range (beyond 0-255) and results in DTC code B0361 or B0441 to set. Correction A revised HVAC controller has been released with new programming that allows for a wider tolerance in the expected range of the TEMP door. Replace the controller using the procedure below: Important: On the 1997 Buick Century and Regal, additional steps are required. You will have to run a jumper wire to the new HVAC controller. Be sure to follow the additional 1997 model year steps below. 1. Disconnect the negative battery cable. Important: On the Buick Regal, the console must first be removed to access the HVAC controller. For Buick Century and Oldsmobile Intrigue, skip to Step 10. 2. Apply the parking brake and block wheels. 3. Shift the transmission to first gear. 4. Remove the console trim plate and disconnect the electrical harness. 5. Disconnect the cigarette lighter sockets. 6. Remove the console storage box. 7. Remove the console control plate and disconnect electrical harness for traction control and heated seats, if equipped. 8. Remove the console retaining bolts. 9. Remove the console from the vehicle. 10.Remove the HVAC trim panel, if equipped. 11.Remove the HVAC controller retaining bolts. 12.Disconnect the electrical harness. 13.Discard the HVAC controller. Important: At this point, you must refer to the 1997 Buick section below if working on that model and year. The section below includes steps to revise vehicle wiring to enable HVAC controller backlighting. 14.If the vehicle is a 1997 Buick Century or Regal, refer to the section below titled 1997 Buicks (Enabling Backlighting Circuit). 15.Connect the HVAC controller electrical harness and install the controller retaining bolts. 16.Install the control module trim plate, if equipped. Skip to Step 23 for the Buick Century and Oldsmobile Intrigue. Continue below for the Buick Regal. 17.Install the console to the vehicle. 18.Install the console retaining bolts. 19.Install the console control plate and connect the electrical harness for traction control and heated seats, if equipped. 20.Install the console storage box. 21.Connect the cigarette lighter sockets. 22.Install the console trim plate and connect the electrical harness. 23.Shift the transmission to PARK and unblock the wheels. 24.Connect the negative battery cable. Additional Steps for 1997 Buicks (Enabling Backlighting Circuit) 1. Remove the radio retaining bolts. 2. Remove the radio and disconnect the electrical harness. 3. Prepare an 457.2 mm (18 in) long, 18 gauge jumper wire. If multiple colors are available, it would be the most convenient to use grey to continue the backlighting circuit in the same color. 4. Locate and splice one end of the jumper wire to the grey wire occupying pin location F4 at the radio harness. 5. Position the radio back into the I/P and route the jumper wire down to the HVAC controller harness location. 6. Using a new terminal (GM P/N 12146447 Micro-Pak .35-.50), attach and install the other end of the jumper wire into cavity C16 of the HVAC controller harness. The row and column position indications are molded into the body of the HVAC controller at the harness location. 7. Connect the electrical harness to the HVAC controller. 8. Connect the negative battery cable and test the HVAC backlighting by turning on the headlamps and varying the backlighting intensity. 9. Install the radio retaining bolts. 10.Install the I/P upper trim panel. 11.Refer back to Step 15 of the Correction section to complete the procedure. (You will have already connected the electrical harness).
Parts Information Part Number Description 10435588 Controller, HVAC (Buick) XXXXXXX Controller, HVAC (Oldsmobile) Parts are currently available from GMSPO.
Read more: I changed the battery on my 1996 buick lesabre a... - JustAnswer http://www.justanswer.com/questions/2n7ej-i-changed-the-battery-on-my-1996-buick- -lesabre-and-now-the#ixzz0v6kyeF5P
thanks Pam
Everything else works pretty well. Only had the car 4 mos. I sat in a tow yard I believe for couple of years. Thankfully it just doesn't stop
