Pontiac Grand Am Steering Questions
i have a 99 grand am. i got in the car today and started it, and i cannot turn the wheels. it feels like i have no power steering. it almost feels like the steering is locked, but i can turn the wheel just a little bit. the resovoir has some fluid but i filled it with no change. can someone please help me with this problem
If that's the case, then I would think that the steering lock has failed to release when you turned the key, or, more remotely, something has broke or come loose in the steering linkage or rack/pinion and is binding it up.
If you can turn it but it's hard to turn then the power steering has gone out.
A fitting wrench is like a boxed end wrench with a slot cut in the end. The slot allows you to slip it over the line and put it on the fitting, but still have mostly six sided contact. That way it doesn't slip and round off the fitting like an open end wrench does.
I remember that even with the wiper motor removed it was still tight.
If you think this is a job you should have seen the ritual that was required to change the power steering hoses on my 88 Taurus. It was at least 2x harder.
also curious if you had any issues with water getting inside the car just where the floor mats go. the doors are never wet so its not the door seals. thats plastic peice up on the wind shield is warped badly and i put silicone around it. its not coming from the underneath of the car cause it gets very wet on the floor only whe nthe car is sitting. so its either the wind shield needs replaced or the plastic piece on the window or both.. thanks again for your help.
Water leaks on the front floor have been discussed many times. Could be a leaking heater core or the drains on the bottom of the fresh air intake box under the cowl being blocked by debris just to name a couple.
