Honda CR-V News
Hi all, just found these photos from other forum.
8-Way Power Dr. Seat
Dual Auto Climate Control
Higher-Power Audio System for Non-Navi models
Honda has released all of their info on the feature-updates for 2008 models. And no, I'm afraid I don't know when we'll see them!
Let me tell you, I own a CRV-LX 2007 with AWD, it is a HELL OF A CAR!
the AWD rips thru snow, rain and whatever else you find on the road.
the AWD option is AWESOME, get it you will not regret it.
Think of the SAFETY factor, when you add it at the pump it pays.
Honda, and others, have had some problems with early TPMS units. Have the dealer test the system, rather than rely on, I assume, just a comment by someone.
How much air do the tires actually lose? If you're filling to 33 psi and they're down to 29 psi after a month (at the same temperature), you've got a tire/rim problem, although that sounds unlikely on all 4 tires.
I always try to check mine early in the morning, preferrably before the sun has had a chance to warm the tires...I can get a pound or two difference if one side of the car has been in the sun versus the other.
and so much for the pre-delivery checklist!
"Comparing the 2010 model with the current CR-V, it appears that Honda has changed the grille, bumper and front fascia — a "freshening," in the parlance of the product development specialists — and little else."
Facelifted: 2010 Honda CR-V (Inside Line)
Summary - expect a slightly stiffer ride, without any real imrpovement in handling, and missors that cost a fortune to replace if damaged.
