Dodge Dakota Radiator and Cooling Problems
I recently went on a long road trip. During that time my engine temp peaked at about 240 w/ no A/C. (norm being around 190-200) Red line is 260. The first thing I changed was the thermostat. Didn't change a thing. I am hesitant to change my water pump because (1) it looks like it would be difficult and (2), I am not losing any water. The pressure in my upper and lower hoses seem to be sufficient. The strange thing is that the faster I go, the hotter is gets. if I go over 70mph, the truck would red line for sure. (Common sense would say the faster I go- more air in the radiator- the cooler the engine.) Once I back down to around 40mph, the truck cools to about 210 rather quickly. At a loss for what might be the problem. Any help out there?
Best regards,
Dusty
Omen
Larry
Just this morning I was going in to work and I noticed that the truck wasn't heating up inside as it normally would have. I looked at the temp gage and it was readin very low as if it hasn't been running. Then it just spiked like crazy into the red. My check gages light came on and I pulled over. I opened the hood to check for a problem but nothing seemed to be apparent. Then the hose on the passenger side burst at the bottom and started spraying coolant. My coolant level was fine. I waited about half an hour and drove it back home. The temp gage rose slowly this time but eventually back up into the red. When I got it home I let it sit for a while and checked the fluid level again. It was still good and it hadn't leaked very much in the driveway. When I was inspecting the hose I could feel something inside the hose at the bottom. Not sure what it is unless the thermostat for this truck is very odd shaped. It kind of felt like rod or something similar about pencil thin and about 4 or 5 inches long. Does anyone know what this is and if this could be my problem?
When I pulled over the first time. I walked to a parts store and grabbed a manual. It didn't seem to offer much help in troubleshooting. I figured I'd come here and see what you guys can do for me.
Thanks and I appreciate any help you can give.
Chuck
Omen
So after that I drove it into town, topped it off with coolant and proceeded to drive home. After going back over the pass I stopped at a gas station and found the same problem of leaking coolant from the overflow bottle. Unsure of what to do I drove it back to Boulder without a problem. But as I pulled into my drive, coolant was leaking once again.
Any solutions?
Omen
Omen
I would recommend using a factory gasket instead of those paper types commonly sold at auto parts stores. I apply a very thin film of RTV on the gasket before I install it, although I've never seen a leak on a factory installed one. The factory gasket appears to be a better grade of material. I use RTV because I use to own Chevies!!
Best regards,
Dusty
See my old post for an overly-detailed description at:
http://townhall-talk.edmunds.com/direct/view/.ee99556/2478
Does anybody have any ideas? Please. Radiator or Pump which one is it cause that’s all that’s left.
I have the same problem with my dakota v-6 magnum. But I have radiator fluid leaking from what appears to be the housing for the thermostat. Could that be a freeze plug or is it probably the housing bolt rusted out? I appreciate your expertise!
Bill
My apologies but I've been away hunting and just got back yesterday.
Since you do not mention the year, but refer to your engine as a "Magnum," I'm gpoing to assume you have a 3.9. If there is any leaking from the thermostate housing I suspect a hair line crack or it is badly warpped. Replacing the housing should solve your problem.
Best regards,
Dusty
I did this and it worked great. I went from having little to no heat on a cold morning to having to turn the heater down because it was too hot. It still takes the truck getting to norm operating temp to get the heater that hot, but it does work.
Hope this helps.
Cheers,
Omen
I recently noticed that during the cooling cycles the car goes through from going to ~210 down to ~185 (when the radiator fan is on), a significant amount of steam (I think) is produced from the radiator. I initially noticed this when I turned off my car and got out to see steam coming from the grill. It is not enough to see when the car is moving, but if the radiator fan is turned on at a stop light, you can see steam coming out from under the hood. The engine never overheats!
When I open the radiator cap, coolant is filled to the brim. The reservoir also indicates a sufficient amount of coolant. Oil level is slightly low, right on the "add" line.
Is this something I should be worried about? Again, the engine doesn't overheat.
If there is around 13 pounds of pressure and there is no signs of coolant loss, either from the radiator or the coolant expansion tank, you are probably experiencing steam from the collection of moisture under the hood or possibly snow, if you live in a snow climate. I wouldn't worry about it, but would monitor the expansion tank for signs of coolant level change when cold.
If there is little or no pressure released when the radiator cap is removed, the cap is likely defective. In this scenario the steam you see is probably hot coolant vapors being released. Over many cool down cycles you will notice coolant loss in the expansion tank. the fix is to replace the radiator cap.
Best regards,
Dusty
Should I just following the basic procedure suggested by the Prestone flush kit, in which you add water to an in-line Tee (hose going to heater core inlet) and open drain at the bottom radiator, etc.?
Or there a better way that requires - in addition - removal of one or more plugs in the engine block itself?
Any thoughts are appreciated.
For low pressure flow flushing, the engine block drain plugs do not need to be removed, however, they will need to be removed to completely drain the engine of coolant.
If you are real fussy...or "anal" as my kids would say, you should use distilled water instead of tap water when replenishing the coolant. I know, this is not typically done, even at automotive repair centers and tap water is probably adequate for most vehicles within the expected lifetime of the cooling system parts. But tap water can contain minerals that may be corrosive to internal engine and cooling system parts. It depends, of course, on any particular water supply.
Best regards,
Dusty
Your point about distilled vs. tap water is well taken, and one I'm well aware of. Tap water, while not ideal, is most practical.
When all's said & done, it sounds like the "upwelling" approach (forcing effluent up & out of the radiator fill port under pressure) is the best all-around way.
As a side curiosity, regarding the radiator drain plug, if a guy wanted to open it, is there any easy way to do so? I looked a couple times and it seems to be well hidden and disguised. Is there a special "hat trick" involved to access it?
Dusty
On a final point, what was driving this whole thing was the sad circumstance in which a couple years ago I lost virtually all heating. My heater core is toast and this was no doubt due to my lame failure to ever flush my coolant. This even contributed to my water pump failing (bearings/seals) at about 8 years (57590 miles).
So - what to do about the clogged heater core? I'm sure you know what's involved in removing it from the Dakota so let's not even go there. In exploring/searching/surfing the 'net, I stumbled onto what I believe may be the very next best thing:
Thoro Flush by Irontite (Kwik-way):
http://www.irontite.com/store/index.php?main_page=product_info&cPath=1&products_- id=4&zenid=1ca29354381138950675c2b8b7603f95
According to its manufacturer, this industrial strength product has been successfully used on diesels and heavy duty trucks. The one-pint jar is actually a powder which is mixed on-site to the recommended specs (using very hot water). You then isolate the heater core by cutting/disconnecting the feeder hoses and circulating the Thoro Flush solution in a backflush direction for about 10 minutes or so. It's supposed to work miracles ...
This, my friend, may be the only "solution" to this problem, short of the miserable task of removing the core from under the dash.
What say you? Have you ever heard of/used Thoro Flush?
So - what to do about the clogged heater core? I'm sure many of you know what's involved in removing it from the Dakota so let's not even go there. In exploring/searching/surfing the 'net, I stumbled onto what I believe may be the very next best thing:
http://www.irontite.com/store/index.php?main_page=product_info&products_id=4&zen- id=1ca29354381138950675c2b8b7603f95
According to its manufacturer, this industrial strength product has been successfully used on diesels and heavy duty trucks. The one-pint jar is actually a powder which is mixed on-site to the recommended specs (using very hot water). You then isolate the heater core by cutting/disconnecting the feeder hoses and - with the heater turned ON - circulating the Thoro Flush solution in a back flush direction for about 10 minutes or so. It's supposed to work miracles ...
This may be the only "solution" to this problem, short of the miserable task of removing the core from under the dash.
Has anyone ever heard of/used Thoro Flush?
I worked in a radiator shop for a year and we typically backflushed heater cores and entire systems without using a chemical additive with good success. Occasionally some vehicles did need a cleanser.
Dodge used heater cores and air conditioning condensers and evaporators in their trucks from Harrison in the lates ninties and these were trouble prone.
Dusty
Heater:
Does anybody know for a fact whether the control knob/key position actuates
a solenoid valve, etc. to allow hot water to flow/not flow thru the heater
core? Something inside me says there should be such a control. Otherwise,
when driving thru Death Valley in August, even though the AC is turned on,
hot water is circulating under the dash board! On the other hand, when I
recently isolated and flushed said heater core, I could find no such
position of control knob/ key position that seemed to prevent water from
circulating thru the core. In other words, once I got it flushed out, water
flowed through it no matter what the position of any knob/switches (and
whether the ignition key was on or removed).
Radiator drain valve:
Along with my heater core clogging, it turned out that the radiator drain
valve was also clogged - so much that nary a drop would drain out when
"opened". When I looked at the valve, the "rib" on the plastic knob was
vertical. It would only turn counterclockwise 1/4 of a turn, where it
seemed to hit a stop. I presume this horizontal position of the rib is the
open position. Does anybody know of a physical trick that can be done to
clear out the drain valve? I tried fishing a small wire up in the valve
opening (it's hard to get to), but no luck.
Any help is appreciated!
Be sure you've got the drain cock open all the way. The plastic drain cocks on Mopar radiators work real hard. I haven't run across one yet that has a clogged drain cock. I suspect you may not have the valve open all the way.
Dusty
As for the radiator drain valve, I'm now 95% sure that I didn't open the valve correctly. After turning it 1/4 turn counterclockwise, I believe I'm supposed to then pull it out (using, for example, micro channel-locks). I didn't do this last step and so probably never got the valve in an OPEN state. In the near future, I plan to go thru all this again and - this time - try carefully pulling on the plastic valve cap to open it. How does that sound?
Good luck,
Dusty
Could I please ask one more "bonus" question?
Back to your earlier comment, supposing I was interested at some point in doing a "high pressure flush" - could you please tell me where I'd find the "freeze" plugs on the engine block? How many are there? Are they hard to find? One on each side? 1/4" NPT?
Any advice is appreciated.
I think what you are asking for are the drain plugs. There are two on a 4.7 motor, one on each side of the engine block about midway between the oil pan rail and the bottom edge of the cylinder head.
Dusty
Per seventy7's advice, I reviewed the post here:
Though the post involved a different truck (4.7L 4X4 vs. my 3.9L Dokota Sport), I was able to pick up on a couple useful things. Laying under my pickup, I readily spotted the 9/16" plug on the driver's side. This one is easy to get to - just the opposite of the arrangement seventy7 described for his 4X4.
On the passenger side of my Dakota, I didn't readily spot the plug. I may have to put it up on ramps and try to find it again after a bit of "attitude adjustment".
http://townhall-talk.edmunds.com/direct/view/.f150267
This post is really informational only, and I decided to start a new one in order that it might be seen by those wanting to do an effective "High Pressure" coolant flush on their Dakota.
As revealed in the thread cited above, there are 2 drain plugs (9/16" hex heads) - one on each side of the block. The one on the driver's side is rather obvious - it sits just behind the water pump and is easy to get to. The other one was troublesome to find. After searching a while, I decided to presume symmetry to help me find it. With this in mind, the good news is that the plugs are symmetrical and the passenger-side plug also sits just behind the water pump.
That's where the good news ends.
To my complete dismay, 3/16" above the head of the passenger-side plug sits a large bracket for the right-side engine mount! The interference this creates requires that the engine mount be removed before this plug can be removed. (Of course, no one in their right mind would do that.) I was so astounded by this that I actually took closeup digital pictures to convince any disbelievers. Unfortunately, this otherwise great posting template does not accommodate uploading of pictures, so you'll have to take my word for it. Bottom line: for all practical purposes, one one of the 2 drain plugs in the engine block (driver's side only) can be removed for a good coolant flush.
Whenever I see something like this, I get philosophical. I start thinking things like - the Dodge engine designers and the chassis designers work in 2 different buildings - never talk to each other and never know each other. It also confirms a thought I've had for many years: the aforementioned highly-paid mechanical engineers never actually do maintenance on the vehicles themselves.
Have you tried an aftermarket radiator for price? I wouldn't advise a used one unless it was nearly pristine.
Dusty
Omen
