SUVs and Smart Shopper
The 09 brochure indicates that all SE's and Limiteds have the trailer prep package. Is it really that simple for the 07s and 08s?
Obviously I'd rather not trust the salesman/dealer. Did that once before and didn't get what I was told.
I was thinking of getting the Coil-Rites for my 2007 Hyundai SF and wondered what your impression of them are now that you've installed them. How and how hard was it to get the jounce bumpers removed? That's the only part that I'm questioning if I can do myself. The rest looks fairly straightforward for a DIY'er. Thanks.
Me i'm pulling a 10' starcraft popup and when i'm loaded it's almost 2700 pounds!! I will try it next week for the first time whit the air spring!! Me to the problem was to much sag.
The 7 to 4 pole adapter I used was this: http://www.etrailer.com/p-30717.htm
The adapter has 3 wires and a ground that aren't attached to anything. Should they be? And to what?
The camper has no breaks.
If still not working I would double check the trailer lights for good ground and possible breaks in wire connections. You might also double check the Santa Fe harness connections for any loose or non contact wire problems where they tap in to the vehicle to be sure they're connected to the proper wires.
Towed my 19.5 ft bayliner/trailer and 3 adults with no trouble (2.7 liter engine). Trip had many inclines and the powerplant struggled but we made it...also no problem on a very long and steep (paved) boatramp. Very satisfied!!
Give it a try and good luck!
Thanks in advance.
Anyhow, I ordered, got and a confirmation email very quickly and then they upgraded my shipping to 3 day AAAND they shipped it same day. I will get all my stuff this Friday. So far so good. Certainly no complaints so far. Again thanks for the input.
Thanks for your help!
Since you mention your intention is to use the hitch primarily to haul bicycles, such as the case with me, I recommend the Curt. The Curt fit my '08 SF much better than what the dealer gets for you. You can't see anything by the hitch itself from looking from the rear of the car. It's great. The one from the dealer was completely visible, meaning cross bar and the hitch. I bought my Curt hitch from eTrailer.com and am very happy with them. I also bought my Thule bike carrier from eTrailier.com.
I was as concerned, if not more, about how it looked on my SF as it was functional. I got both covered with the Curt hitch. This one from Curt looks exactly like the one from Hidden Hitch, but theirs includes a tab that sticks out next to the hitch mouth (for lack of a better term) that is used to mount an electrical connection if you are towing a boat, small trailer, etc. Since you are only using the hitch for bikes, as do I, the Curt is the way to go for functionally and looks.
Thank you so much for this very helpful information! It's just what I wanted to know.
Best wishes!
jstegall
I have installed a brake controller in my GM vehicle where I had to manually splice into my brake pedal wiring and run the leads to the battery and run the blue lead to the 7-way plug. I do not wish to do this on the Santa Fe as it will probably void the warranty and I am not the owner of the Santa Fe.
As well, are there any "air bag" helper springs available for the 2010? I phoned Michigan Truck Spring and they phoned Firestone who did not have an answer at this time.There are air springs listed for the 2007-2009 models but I feel the design on the 2010 has changed.
Do you pull this with a weight distribution system or any sway control? If so, what is your solution. Thanks for your help.
:confuse:
As far as I can tell, the only model with the so-called "towing package" is the limited. We have a 2008 SE and it has a small transmission oil cooler in the front of the radiator on the bottom left as you look at it. It also has the factory wiring at the driver's rear of the car which made installation a snap. No problem towing our 19.5 ft bayliner, as mentioned earlier; downshifting when needed for hill-climbing. Satisfied owner
Happy Towing!!
