Oldsmobile Intrigue towing capacity
 menardsy
                    Member Posts: 4
menardsy
                    Member Posts: 4
I was intending to tow a folding camping trailer with my Oldsmobile Intrigue 2000. I would install a transmission cooler. The folding camping trailer has a dry weight of 1250 pounds and has electric brake on it. If I had some accessories in the folding camping trailer it will probably add around 200 pounds so it would be around 1500 pounds. We would be 2 passengers in the car (350 pounds) + around 200 pound of luggage. So in the car the weight would be around 550 pounds. To recapitulate, 1500 pounds for the trailer and 550 pounds in the car. I would like to know if it is too risky for: the frame, the transmission, the manoeuvrability in an emergency situation (must brake quickly or avoid obstacle) ?
Sylvain
Sylvain
You can probably get away with it as the manufacture always has a factor of safety. But if it were my vehicle, I would not do it even with a transmission cooler.
I think I am going to follow your recommendation. It’s going to be some time before I can buy a more expensive car to tow something. :-(
Sylvain
