Nissan Pathfinder Taillights
anyone know where to get the cool aftermarket taillights for 95 pathfinder
that often pop up.
My tail lights would not come on with the headlights or shutting off when driving (great no one could see me from behind). It's the turnsignal-headlight switch. I fixed this easly
in 30 minutes. Underneath the steering wheel remove the 4 screws that hold the bottom half of the steering wheel bezel. Once you have those off you can lift the top half of the bezel a bit to get to the two screws that hold the switch in place. Remove switch and take inside your home / or shop. There is a plastic plate that covers the where the
contacts are. That plate is about a 1 1/2" roughly square. I forget if it has screws or not , unscrew and or pry to pop that piece of plastic off. You will now see 4 or five contact legs. One for the headlamps 1 for taillamps and 2 turnsiganl contact legs. From turning headlights on/off alot they get unsprung a bit and will make little contact with the other mating surface. I used a small screw driver
to bend them towards the inside of the switch so they could make good contact. Take the switch in your hand and turn it on , you will see a one or two legs that have lost some off the orginal bend to make contact (thats the brake lights, use a small screw driver or you thumb to bend then inwards a bit to match the other legs. You could also use a very small pair of needle nose to bend the legs downword towards the other mating surface. My tail lights worked after this fix and i haven't had a problem in the year that i did this fix. good luck it works! Take your time to understand where and how the contact legs go to make a connection.
Those switches are too darn expensive but that is the problem
:shades: SWITCHFIXER
SUVs and Smart Shopper
Good luck
Switchfixer
that is on the driver's side back fender. How can I get the old light out? Where
can I buy a new lens without having to go to the dealer and getting clobbered
with a huge cost?
www.car-stuff.com
can't make it easier than that!!
:shades:
I own a 2002 Nissan Pathfinder.
I feel I have some sort of electrical short with regards to my signal lights and brake peddle. (Please Note: the problem only exists with regards to the left turn signal light 'both front and rear'). I'd really like to try to fix this myself as I am on a very tight budget. I was hoping maybe some kind person here might be willing to offer me some advice, based on the symptoms, of where I should begin looking.
Symptoms:
(1)
My left turn signal lights both front and rear (i.e. driver's side) light up when I press the break peddle.
(2)
If my left turn signal is active, every time I press my brake peddle my left turn signal stays lit but stops flashing until I release the brake (things act normal with regards to activating the right turn signal).
also...
(3)
If my car is in "P"ark and I have my left turn signal engaged (or my hazards flashing). My shifter console makes a loud clicking sound with every blink of the flasher lights (I assume this sound is the brake peddle controlled "safety" relay inside the shifting console that unlocks the gearshift from the "P"ark position snapping in and out of position)
Does this sound familiar to anyone?
Any advice is most certainly and thankfully appreciated.
Sincerely,
Rob
mr g
