2007 Honda CR-V Rolling Resistance and Grade Logic
I used to drive a toyo camry and even when i dont step on the gas it just sort of glides forever.. but our new '07 CRV seems like it has a lot of resistance to it. If i dont step on the gas it slows down almost to a halt. i'm not sure if this is a "problem".. but anyone else experiencing the same thing?
Happy 67-yer-old guy
Could that be a safety feature?
SUVs and Smart Shopper
thats what they said when the CRV didnt track straight ^^
"its a safety feature just in case you fall asleep"
Read the OWNER's MANUAL, especially the part about "grade logic."
Hondamatic operates like a manual would. Instead of shifting into neutral when you coast, it keeps it in gear, or even downshifts, because it thinks you intend on slowing down when you take you foot off the accelerator.
Reading the manual (3-10X, or however many times it takes you to know it from cover to cover by heart) is probably the best investement you will make into keeping your Honda running forever.
Tho i've seen it downshift going downhill and thought that was pretty cool.
No it does not. Cruising in neutral uses more fuel than cruising in gear.
When you are in neutral, fuel system supplies more fuel to the engine to keep it idling to power the accessories attached to it.
Ehen you cruise in gear, the rolling of the vehicle provides the rotational power to the engine. And since the throttle plate is closed, the computer minimized fuel usage because it thinks that engine is turning too fast for the given position of the throttle plate.
If you want to experiment, shift into neutral when coasting and see what happens with the fuel economy. Don't rely on the instant fuel economy reading, as it will skyroket, since it is calculated based on engine RPM and speed, and not by the actual fuel usage.
I get lower overall fuel economy (less miles per given fill up) when I shift into neutral on downhills, but my MPG meater reads 250 mpg going downhill at 70 mph in neutral, but I drive stick, my transmission is designed to be shifted on the go (I still have to double clutch to go back to 5th from neutral at the bottom of the hills, to save the synchros). Automatic will probably fail prematurely if it is shifted back and forth, like a manual, unless it is designed for that.
Are you saying that power is cut off to the accessories when you cruise in gear?
No, but the fuel injectors inject much less fuel into the engine when cruising in gear than if you were cruising in neutral.
It takes fuel to keep the engine turning (even it idle), but when the inertia of the vehicle is turning the engine, it uses less fuel.
typesix, "Hybrid Tips Optimizing mileage" #305, 20 Sep 2005 8:24 am
sebring95, "VW Passat TDI" #891, 8 Aug 2005 9:58 am
steve_, "How it Works! Welcome to Auto 101" #246, 24 Aug 2006 11:09 am
If people want to revisit the issue, that last discussion would be a good place to do it in.
