Honda CR-V dinghy towing behind an RV
I have towed a Saturn behind my RV's for 10 years but now want to move to the Honda CR-V. Has anyone any experience towing this car? How easy is it to connect each time to the RV? Have any problems regarding towing at highway speeds?
As per manual you have to tow with all 4 wheels on the ground if you have the AWD version of CR-V.
You are limited to certain miles per tow, 50 I think, then you have to go through gears with the engine running.
You need to change the fluid more often.
Page 251 discusses towing behind a motor home. Basically there are procedures to be followed, and you have to repeat the actions every eight hours.
2007 CR-V Owner's Manual in PDF format
Link to pages listing all Acura / Honda model owner manuals
https://techinfo.honda.com/rjanisis/logon.asp
Thanks for the update. The original links worked yesterday when I posted them. I have no idea why they don't work today.
That is the first time I hear of this. Did the brakes lock up? Were the pads properly seated? Broken in? Was something pressurising the brake system?
I'm not sure if Camping World or another place installed it, but they all try real hard, and they don't always get the "little" things just right (I've come to expect that), and leave fine tuning and adjusting up to you. Sometimes they even give you the instructions. Likely they set the device up using a "safe" default, which may be way too heavy for any light-duty vehicle like the CR-V, which results in too much of your braking occurring from the towed vehicle. However, nice and easy on your motorhomes giant, oversized braking system was the goal, wasn't it?
I'm sure you already checked, and adjusted the pressure to the pedal to the lightest possible after experiencing a problem to see if you still have a problem. It's likely you don't need much brake pedal pressure for the CR-V. Just my guess after reading the information you provided in your post and doing a lot of towing. And with my experience getting things installed at CW, each one needed a bit (understatement) of "fine tuning" afterwards, and down the road.
Sounds like the problem is with the auxillary brake installation and not with Honda.
Those are I think about 30 Watt bulbs plus the center brake light so about 70 watts total.
Also make sure the stereo isn't running and nothing else is plugged into the acc socket.
compliant?
