2009 Honda Civic
1678911
  • toofast2toofast2 Member Posts: 3
    Yea, they said the same to me. they told me its because since the tires are low profiles, more water gets into it when it runs thru a puddle or so. It's not actual RUST, just surface corrosion.
  • mark19mark19 Member Posts: 123
    um, you're buying 89 instead of 87? I've seen many cars (odd i know) using higher octane than what they call for and having issues. You should definitely try 87 octane and see if the problem still occurs. The dealer won't do much for you, sorry to say. Except to tell you to "try other gas". Just try the lower octane, and try something else instead of Shell. I know with my old civic using Shell caused a lot of rotten egg (sulfur) smell and lower mpg's. and you're welcome, glad to help out :)
  • jogousajogousa Member Posts: 402
    Does anyone know how to remove/replace the lower instrument panel/cluster (the one with A/C outlets)? I know there is just one screw to remove under the dash but one has to remove a panel to access it - and then the whole thing just pulls out towards the steering wheel, right?
  • weveweve Member Posts: 1
    2 questions:
    1. My mpg has been slowly rising since new; I have 11,000 mi and am getting 34 mpg (was about 30 when new). Honda service tech said the engines are very tight and take at least 10,000 mi to 'loosen up'. I drive mainly hwy, 65 mph, and try to keep my rpm at starts at 3000 or lower. What mpg can I expect and when will it happen?
    2. Will a K&N air filter help? Anyone had good or bad experiences with this filter?
    I've read an article written by a technician with experience in that field that K&N filters are not good for engines because they deposit trace of oil in intake manifolds (because K&N filters are oiled). It is better to decrease air filter replacements periods with regular OEM or aftermarket filters say from 10,000 to 5,000 miles periods - or shorter, depending on climate and environment, where you mostly drive. Air filters replacements are as important as oil and oil filter replacements. For oil, I use Mobil 1 extended service synthetic oil.
    2009 Civic Sedan EX-L 10,500 miles / average combined city/highway 33 MPG
    2009 VW Jetta Tdi Sportwagen 6,900 miles / average 34 MPG city driving
    Unless you live in a dusty climate, changing your air filter more than once every 30k miles or so is going to be a waste of money.
  • rbuckleyrbuckley Member Posts: 1
    I have a 2009 civic LX with only 1000 miles on it and when I slow to a normal stop the transmission "thumps" into first gear and on occasion lurches forward slightly.I took it back to the dealer and he says this "normal" for the electronic transmission. Has anyone experienced the same thing and if so how did you fix it or is this really "normal".I am a bit skeptical.
    Hmmm - not sure if that would be considered "normal". I have 2009 EX-L Civic and I don't have those symptoms. I am not an expert in that field but it would not hurt to get a "second" opining, perhaps from a reputable transmission shop (other than the selling dealer even though the car is still under warranty).
    Or, if you live in town, where there is more than one Honda dealer, have it checked at a different dealership than where you originally bought the car.
    You can also call your regional Honda Tech. Center - they have factory techs that travel from dealer to dealer and help the franchise dealers with problems that they cannot properly diagnosed themselves. Sometimes (I have that done with Range Rover a few years back) the factory tech. rep will meet you at a designated dealership and looks at the problem himself.
    I would also check the transmission fluid level (while the car is running obviously) and also, if it looks normal and is not "foamy or bubbly".
    If you are near a Civic dealer, ask to drive a different Civic with an automatic (new or used, shouldn't matter) and see if your car stands out as being more rough. Just a thought.
  • mazdanutmazdanut Member Posts: 2
    I looked at a 2009 Civic LX-S yesterday. I got a quote that seemed very reasonable. When I then inquired about the current financing specials, 1.9 for 24 - 36 months and 2.9 for 60 months I was told that if I wanted to take advantage of this offer the price would be $750.00 more as Honda was offering $750 dealer cash OR the finance specials. This sounded reasonable and I assumed I had missed this when I looked at the specials available on Honda's site. When I got home and looked though I could find nothing about this.
    Does this seem like an honest omission on the dealer's part or a price bait and switch?
    TIA
    This sounds "fishy"to me. If they want 750 more and they get "dealer cash" 750 - that would be a wash out. What are they talking about?
    You can find official Honda's financing special offers on their website - there is no such things (about $ 750) mentioned there. The interest rate that you have mentioned is correct. I wouldn't pay the extra 750 that they are asking.
    Better yet, get your own financing. Best source would be a credit union car loan. If you are not a member, you can always join one. Credit unions have the best financing deals these days, far better than any banks and they want your "local" business.
  • diamondsnrustdiamondsnrust Member Posts: 7
    I also have a very new 09LX, and it has ~1,500 miles on it. I notice something similar-when I am coasting and not applying the gas, the car will down-shift to first gear. I think this is the i-VTEC (intelligent vtec) working...it seems as if this would help with breaks. Downshifting seems to slow the car down for me so I don't have to break as much as I normally would. Does this sound similar to your car?
    What do you mean, lurching forward? As in, when you're applying the brakes the car lurches forward, or after you've stopped?
    Does your car seem to ever have difficulty with fast accelerations/going up hills? Those are some issues I've noticed- after slowing down for a red light (and I can really feel it downshifting), I often have to quickly speed up as the light has turned green. It feels as if the car really doesn't want to kick back up to a higher gear. Also on hills, the car seems a bit sluggish-this is probably just the 4 cylinder thing.
    PS I have an automatic.
    PS please excuse my bad spelling
    ** breaks = brakes
    Hey, I'm tired today. Spent 3 hours at the DMV registering the new Honda.
  • targettuningtargettuning Member Posts: 1,371
    As with all automatic transmissions this one will also downshift when coasting to a near stop so it is again in low or first gear in preparation for acceleration from a stop or low speed situation. Pretty much normal for all automatics. It isn't anything to do with VTEC but a function of being in the right gear (or nearly so ) at the right time. This transmission also has "grade logic" which automatically downshifts on down hill grades and holds the lower gear until the system detects you have decended the hill. This aids in controlling the vehicle speed without as much brake use. It also works in reverse (not the reverse gear) when the transmission downshifts and holds a lower gear on assending steep hills without annoying hunting for the correct gear (a downshift followed by an upshift followed by another downshift incessantly.).
  • samnoesamnoe Member Posts: 731
    While I love my 2009 Civic, the high quality materials, driving dynamics (albeit a little body lean in fast turns), excellent small sports-like steering wheel, no squeaks or rattles, and much more, I would like to pinpoint some room for improvement which I experienced in the past few months since I bought the car.
    There are some bigger issues, which has already been addressed in many reviews, both pro & consumer. Among them: Terrible road noise (especially that the roads around my area are old and noise increases even more. On newer, smooth roads it is a bit better). Noise includes also the “exhaust/muffler vibration” which makes you shiver when standing behind the car with the engine running;
    No stability control on lower models, and bluetooth hands-free calling is reserved only for the top-end models with navigation systems, (and even these only imports up to 50 names to the system! But I have 300 names in my phone!! Hello!?). Also among the big complaints is that except for the top models, there is no remote trunk release! Can you imagine? You must insert your key to open it or bent down to the floor at the driver’s door in order to open trunk. All these are known concerns. Now to my list, many of them nitpicking:
    Headlamps are not bright enough. High beams are much better, but low beam needs improvement. I would also love the headlamps to come on for a short period when I press the “unlock” button on the key fob, and likewise to stay lit for a minute after turning off engine.
    The outside power mirror switches, which I’ll probably use once in my lifetime, is nicely illuminated. But power window switches, which I use several times every day is not! (except for drivers). Is that logically? Likewise, when you open the drivers door, many gauges lits up nicely, but I am still unable to see where to insert the key. Isn’t an illuminated ignition key insert more important and useful to light up rather than some unimportant gauges? And talking about opening front doors, why don’t the front lamps light up when opening a front door (in many other Honda vehicles, like the odyssey, it does!). If it would have light up, I would be able to see the ignition ring. Also, please put a lamp in the glove box.
    I was talking about power mirror switches. I would like to add that both, Hyundai Elantra & Kia Forte offer heated power mirrors standard on all models. But the Civic only give it to you on the top model. It would be extremely useful to add it to lower models as well.
    Being that it is a Japanese vehicle, I would “Americanize” it a little, in several ways. First, ditch that annoying Japanese horn sound. Second, improve the lock/unlock switch. Like Toyota recently did. The American lock/unlock switches is more logically and intuitive designed. “illuminated” cruise control switches are so dimly lighted, I can barely read it. Please make it brighter.
    Also take off those annoying leading zeros, both on stereo and odometer. When playing an MP3 disk, this is how the display would read: 02-004-03’15 (which is Folder 2, track 4, 3:15 time elapsed). Why the confusing leading zeros? Same in odometer. If I have 13 miles, I hate to see 000013. Also get rid of the apostrophe symbol between the hours & minutes (on stereo), and start using the colon symbol, like all mp3 players (4:22 instead of 04'22).
    Also on the Japanese, a locking gas cap. At every fill up, you must manually bend down to the floor to open the “door” for the gas cap. What is that for? (Anyone still stealing gas??)
    Also a stupid idea mostly found on Japanese cars, that lower end models does not get variable wiper speeds, just slow & fast! This sucks! Why shouldn’t I be able to set more intervals my self? I don’t ask here for rain-sensing wipers! I also noticed a “click” every time before and after the wipers are wiping. Very annoying.
    Talking about the wipers, Most Honda vehicles are designed that the wipers wipe off as much as possible of the windshield (unlike most American designed wipers). But on the Civic, too mush is left un-wiped. I tried to replace with bigger wipers, but Honda designed it that you can’t, because it will be blocked.
    Seats are not bad, but would love to see the addition of lumbar support. Your lower back may hurt on longer trips.
    Improve the stereo system. It sounds horrible.
    The interior door grab/pull handle is not sufficient. Besides, there is no where to hold on tightly when taking a turn, etc. You should adopt the design as in the Toyota Camry, or in your own CR-V, or Acura MDX, recent Lincolns, and many other vehicles. They’re so much more comfortable.
    Lack of exterior temperature indicator on all but the top model! That is surely a shame. Toyota Corolla offers it on all models. And also I would LOVE to have a trip computer to show me mileage and more.
    Somehow, the turning circle radius (which Honda says is 35 ft.) seems to be not correct. It feels more like 39-40. I did not measure it myself, but compared to other Honda’s, the Civic’s really fall short.
    Cheap sun visors. And no extender. Does not belong in a Honda vehicle, period.
    Also very annoying, if you unlock the car and do not open a door within 30 seconds, it re-locks automatically. Although it’s a great safety feature, I think that 30 seconds is way too soon. Give me a minute or 2!
    That’s all for now. Hope not to add more in the coming months!
    And please share your opinions as well.
    WOW - that's critical!
    I am sorry, but if you prefer to have othe features that Honda does or doesn't offer you should have bought another brand and make.
    Honda conducts quite a few "public" clinics (I was on few of them) and public reports back items and features that they prefer and then they are (or are not) incorporated in their designs. Like the 30-sec automatic lock - I happen to like that feature and obviously majority of respondents as well.
    My wife has 2009 Civic EXL and I have 2009 VW Jetta Wagon Tdi. While VW is more "fun to drive and has a better mileage" Honda offers carefree commute from point A to point B. We are happy with both. There is no answer to a question: what is the best car? Everyone looks for something in particular and no car manufacturer can satisfy everybody's taste. It is always a compromise.
    Back to you report though. You can increase the headlight brightness by changing the headlamp bulbs and put ultra btright PIAA bulbs there (same wattage but brighter!).
    You can eliminate "road" noise by replacing tires that are rated more quiet than yours (see TireRack website).
    You can replace wiper blades with Valeo brand - they clean most of the windshield.
    Locking fuel caps are handy in certain markets in the U.S. - yes, the gas is still being siphoned out.
    Outside temp sensor is on our model - all you have to do is click set-reset button to have it displayed.
    Finally, most Hondas sold in the U.S. are designed and assembled in North America - so any referral to "Japanese" isn't really proper.
    Any brighter and they'd be distracting; I prefer them not lit. I set them by feel anyway. The accel-resume/decel-set rocker has a different feel than the other buttons.
    Heavens! We can't get the weather report! :P Kidding.
    They extend. While the visor is out of its clip, pull on it. The whole thing pulls away, back towards the driver/back seat. I learned this a year or so ago in my '06 Accord. I was tickled to learn it!
    There's a reason people step up from lower-end models to get things like a high-end sound system, trunk release on fob, variable-speed wipers, audio controls on the wheel, etc (all on the EX model since the beginning of this generation [2006], but not offered on the LX). More money buys more features. Perhaps you'd have been more happy with a Fit Sport, Corolla, or Elantra. They seem to offer more of the features you want.
    Yeah, that's critical, but as I was pointing out most of them is nitpicking, so no big deal. It’s just some “reference” for Honda if they want to perfect their vehicles, they should take my advice..
    I know that higher models offer more features, but there are basic stuff that should really be standard. There is a limit of how much you can de-content a low-end vehicle. Many cars give you manual window switches and door locks, other comes with no a/c or stereo, and you need to pay more to get those.. So what’s next? Pay for a steering wheel?
    Don’t get me wrong. The Civic’s not bad, and I like that Honda in general (unlike Toyota) makes various models very easy to choose, shop and compare, without the confusing option packages for every model. But still, sometimes I don’t need leather and navigation, but I do need a small exterior temperature gauge, or bluetooth, for example. I would pay the few extra bucks for them. I am only comparing the Civic to other manufacturers to “proof” that it is not totally out of order to offer these kind of features on basic small model. I’d still take the Honda over the competition for their refined driving dynamics.
    About your suggestion for road noise - replacing tires is a big expense. I wouldn't do it only if needed to. I want the car to be quiet right "out of the box". Anyone here interested maybe in a noisy ride? I don't see Honda's point.
    Now a few more complaints on the Civic, which I think is not so smartly designed:
    1) You can not turn off the “seat belt reminder”. I always belt, but sometimes just driving slowly in a parking lot or similar situations, I don’t need my seat belts on, but the "reminder" drives me nuts. Most other manufacturer gives you a way out, and let you disable in some way.
    2) Further more, if the belt charm is already going off, nothing will help stop it, not even coming to a full stop and shifting into PARK. The annoying “reminder” should at least not work when in PARK.
    3) When you activate the “power windows lock” on drivers door to prevent access of opening/closing windows, the drivers controls are also being locked. This is very unintuitive and frustrating. Driver’s controls always needs to be unlocked and work. I’ve never seen another vehicle to behave that way.
    Again, let me repeat, my Civic is terrific, a delight to drive day to day (except for the road noise which bothers me terribly), I am just pointing out some areas upon Honda should improve, and be “the best”.
    Thanks, Honda, for listening!
  • bearcrkrdbearcrkrd Member Posts: 167
    Good Post. I have an '08 LX. Many of the things you mention I do not care about. Some I agree with very strongly. Number one is road noise. It is horrible. After one year of ownership, I spent $750 dollars on "quiet" tires. They only helped a small amount. Does track excellent with the Goodyear ResponseEdge, though! Variable speed interval wipers should be on my LX, too. And lumbar support. I would like to see a light in the glovebox, but it needs to come out (at least partially) to change the cabin air filter, so I think that is why. Wouldn't want the wire bundle hanging?? Next is the exterior temp guage and a lighted ignition ring when you first jump in the car. I agree with you again.
    Stability control would be very nice. That should be mandatory for 2010, or 2011 for sure? I used that, along with Drum rear brakes, as a bargaining chip when I bought my '08 LX. Radio could be better, but if the car was quieter, or you are stopped, it sounds good.
    I think the lights are plenty bright, wipers swipe just fine, and don't mind the gas cap lever or trunk release in the cabin.
    Some of your other points I do not use the stuff that much, or don't notice it.
    Honda does this for lawsuit reasons, I'm sure. That said, my dad has had $12,000 damage done in a grocery store parking lot. He got hit by someone who didn't stop at the end of their row and turned in front of my dad, causing him to effectively hit them square on, in our then-new '92 Accord. His head shattered the windshield.
    Wear your seatbelt if your car is out of park.
    I almost forgot to ask... what cars let you disable the seatbelt reminder, and I'm not referring to pulling a fuse out...? :)
    I remember the days when "basic stuff" wasn't inclusive of power windows and locks, 6 speaker CD players, and cruise control.
    My dad's "basic" Civic he had in '91 had a 4-speed manual, no radio, and dealer-added A/C. I'm pretty sure there wasn't a lumbar adjustment either! :blush: :shades:
    My how times, expectations, and prices, have changed.
    I know that Ford, Chrysler and Toyota have a way to disable. Not an easy button, though. You have to follow a series of pressing buttons and lock/unlock seat belts, etc. Ask anyone to borrow an owner's manual and you'll find it.
    The annoying part with the Civic is that even if you shift to park, the series of beeps will not stop.
    Another nitpick: Removing the floor mat from from drivers seat (for cleaning or changing) is unnecessarily cumbersome, and it's even harder to put back and fasten on the hooks.
    Also the "AUX IN" is difficult to access, especially with one hand. That cover has to come off. Who needs a cover for the AUX IN insert?
    OK, I think I'll stop already. Enough with the complaints.
    Removing the driver's side floor mat better be difficult in view of a recent law suit against Toyota (and subsequent recall) whereas the floor mat got stuck with the gas pedal and would not let go....
  • sinsdsinsd Member Posts: 46
    I agree- all the little complaints. What bugs the helloutta me is the rear drum brake. DRUM BRAKE! HONDA! WHY?
  • max09max09 Member Posts: 4
    I bought a 2009 Honda Civic EX-L Sedan about 3 weeks ago! I am from Hamilton, Ontario Canada.
    Dealers in the province of Ontario had a promotion going on until November 2 on all remaining 2009 Honda's of $3,500 off!
    On the Civic sedans it's $2,500 off the MSRP. I had a couple of prices of what i wanted to pay for the car before i want to the dealership. I was at the dealership for approximately 3 hours, trying to negotiate my price! The final price with all the fees and taxes was $25,900!
    How did anyone else do? This post is of course open to everyone, but i would really be interested in hearing those specifically from Canada!
    I am not sure what is the exchange rate but I think you've got a pretty good deal.
    I bought "used" 2009 Honda Civic EX-L for my wife with 6000 miles on it back in July from a Toyota dealership for $ 18,000 (someone traded fully a loaded EX-L for Toyota Prius...).
    Normally. if a Toyota dealer doesn't have a Honda franchise, you can pick up quite a nice car because dealers try to stick with their own brand and they give you a pretty good deal on a different trade in.
    5000 miles later and one B1 service (oil, filter and tire rotation) the car is perfect.
    We also replaced windshield wipers with Valeo brand. These are not OEM Honda (quite a complicated design of the blades) but they are OEM on most European cars and are cheaper than OEM Honda wiper blades. In my opinion, they are better than OEM. Depending on climate, wiper blades should be replaced at least once per year (or every oil change). The reason I am saying this is because some 2009 models are sitting on dealer's lot for almost a year and rubber on those wipers goes bad.
    Another item to check is the tire pressure because people that prep new cars at dealerships (for close to min. wages) tend to over-inflate tires.
    Other ownership experiences.
    My wife first complained about the "second" tachometer display (speed) above the lower instrument cluster but after she got used to it she actually loves it. It shows you (in big numbers) what you need to know most - the speed!
    We also replaced the fabric floor mats with custom made rubber floor mats, both in passenger compartment as well as rear cargo trunk.
    One draw back is a relatively small gas tank. But I guess it's that way for a reason - you get a better overall average mileage with a lighter car!
    Happy motoring!
    One of the favorite things I like about my Civic (or any Honda for that matter), is that they use the straight shifters. Unlike Toyota, which gives you the GATED SHIFTER (very ugly IMO, and not useful at all, I don't see the advantage). I would suggest Honda to keep it up and don't fall for those stupid shifters.
    One thing, though, which someone mentioned before, and both Toyota & Honda are accused for that, which I would like to see changed: Give the option for a car charger to work even the engine is off. You can not charge a cell phone or any other device with engine off (unlike all American vehicles, which gives you the ability).
    Interesting though, speaking about the battery, that Honda doesn't have a battery saver feature like most other manufacturers, especially domestic. Meaning, if you leave an interior lamp ON by mistake, it won't turn off automatically after a while, causing your battery to drain. Thankfully, they had the same problems with (more common) headlamps -- I had an incident with a 2005 Accord --, but that was recently corrected on most Honda models. Still need to do the same for interior lamps.
    Another minor improvement I would like to see in Toyota/Honda cars, to get rid of the intrusive trunk hinges, which limits trunk space & crushing cargo. Again, in this regard the US manufacturers are better. So copy them.
    I think it was mentioned on this forum previously that designs of Hondas (like most other brands) are based on frequent consumer's clinics where consumers fill out features that they prefer or what they would like to see on future models. I was on few of them myself.
    Only then some of these features are implemented into production.
    Gated shifter is a safety issue (so that kids bouncing inside the car, for example) do not accidentaly shift gears. All Subarus, for example, have that feature. You may not like it but most people surveyed probably do.
    Ditto car charger. If these were "live" and someone would leave some electronics plugged in, it becomes a fire hazzard.
    I agree with you on the lights accidentally left on and draining battery. One example, daytime driving lights on VW Jetta do not automatically turn off, when you turn the iginition key off. That is annoying. Typically, a small interior bulb should not drain the battery although in some instances and climates it might.
    Withe regards "copy them" - they did a lot of copying in the past and it seems that is now the other way around; i.e. US car manufacturers are copying them (in my opinion)!
  • vanderhb2vanderhb2 Member Posts: 1
    Signed Scarborough ON Canada deal on Oct 31 2009. On the road (OTR) price is $24,999. No options / extras in this deal except wheel locks and touch up paint. Only regret (so far ... delivery is later this week) is that my first offer (accepted) didn't go into managers office lower :-(
    I disagree - I can just as easily shift down a gear in a gated shifter as in my inline auto shifter. To go past neutral or 3rd, You have to push the button on the lever. In my girlfriend's Hyundai Santa Fe, you just push forward and the gates guide you to park; no button necessary. I'd say its safer to have to make two steps to shift (button+movement) rather than just movement. At least the gates in my friend's old TL ('96) required one push down on the shifter to move it past Reverse or into lower gears.
    Whose kids are bouncing around the car while driving down the road? The driver should be buried under the jail for not buckling the kids up.
    With regard to Honda's use of a non-gated shifter....it has garnered universal dislike in the automotive press for the ease with which it slides past D (drive using all 5 speeds) into 3 (I believe) which eliminates overdrive use causing the car to motor along in other than 5th gear with the driver mostly unaware. Can you say worse, relatively speaking, fuel economy? If I remember correctly at least one poster here also complained that he found his daughter consistently driving in 3 rather than D. It isn't too confining to follow the gated shift pattern found on Hyundai among others since you generally only shift from park to drive or reverse once or twice during any given drive.
    No kids should be bouncing - that was just a figure speech...although I have seen that around here quite a lot... for that matter, there are many other distractions like texting, handling food, smoking, animals running back and forth ... etc. that could trigger shifter to move...it's a jungle out there....
    I like the gated shifter and apparently many others as well...had it on my Subrau ....
    Wow! Is this for a 2009 or 2010? $24,999, does that include taxes & freight? I think no matter what price you get your vehicle for, you always think that you could of gotten better! I was very happy paying $25,900 for my 2009 EX-L!
  • onedmconedmc Member Posts: 5
    Had my 2009 Civic LX-S ( 5000 miles) stolen from my driveway last week. Car was locked and I am still in possesion of both keys. No alarm was heard and car has not been found to date. This is my second Honda stolen from my residence in 7yrs. Either it's time to move or better start buying Lojack.
    Most stolen cars:
    Source: www.nicb.org
    1994 Honda Accord
    1995 Honda Civic
    1989 Toyota Camry
    1997 Ford F150 Series
    2004 Dodge Ram Pickup
    2000 Dodge Caravan
    1996 Jeep Cherokee/Grand Cherokee
    1994 Acura Integra
    1999 Ford Taurus
    Hondas are stolen mostly for parts because thiefs can make more money on parts rather than on stolen cars - those are harder to "unload".
    Get a dog! The best alarm ever!
    I'm surprised. I wonder how they got around the immobilizer key?
    One popular way nowadays is towing the vehicle away. They push/pull/drag the car to a secure spot and then pull it on a tow truck.
  • svosvo52svosvo52 Member Posts: 3
    I changed oil on my 2009 civic when it had 5000 miles on it. This was the first oil change. Being old school, I didn't want to leave the break in oil in past 5000 miles. Ever since then, my mileage dropped from 32 to 27 and the motor seems to start like the battery is low. Did I make a mistake by not leaving the break in oil in longer? I changed it in November just before it turned cold. This may contribute to it also. Any info would be appreciated.
    Assuming you've used the correct viscosity and OEM oil filter, earlier oil change should not effect your mileage.
    Could it be the "cold" weather? Not sure in what climate zone you live but that could have an effect on starting.
    I used 5w20. It is in Michigan. The motor seems very tight acts just like the battery is low. It is inside overnight and has not been super cold. I have read that mileage drops but I never had a car drop so much. Does anyone know what makes the original break in oil so special?
    My mileage here (Birmingham, AL) dropped fairly significantly with winter-blend fuel. Combined with new tires, I'm down about 4-5 MPG from where I was over the summer on my 4-cyl Accord.
  • tsytsy Member Posts: 1,551
    Hi all
    I have a new 09 Civic EX-L with less than 1000 miles. It has an annoying glove box buzz/rattle. When I open the glove box the rattle goes away. Anyone else have anything like this?
    Otherwise the car is pretty well put together which makes this one rattle even more annoying! :)
    tom
    Try to change cabin air flow - by means of changing where air blows and test it with various fan speeds. Listen, if the "buzz" sounds in all air blow positions. Maybe you only hear "buzz" at certain setting.
    Alternatively, open the glove box - it drops open. Squeeze both sides on top together and the glove box opens/drops down fully and exposes the cabin air filter compartment. Slide the cover (follow arrows) and open the cabin filter compartment. See if it's clean or if there is some obstruction in the fan.
    Check the glove box and see if there are 2 rubber bumpers on both ends, where the glove box touches the dash board in closed position.
    Just a few suggestions....
  • victorcharlievictorcharlie Member Posts: 3
    Hello, I'm considering purchasing a new 2010 Honda Civic LX but am second guess this decision based on what I've read about previous model years. I am just wondering if anyone knows if Honda has corrected the engine block cracking, the premature brake wear and the premature tire wear. These are at least the most prevalent and severe problems I've read about with these cars. If you have any information it would be very helpful. If Honda hasn't fixed the problems I may have to turn to Toyota despite their accelerators of death.
    I have done a lot of research regarding what car to purchase including consumers reports. I never heard of the engine block issue. I have had my civic for 6 months and am very happy with my purchase. There is road noise and the e brake lever is in the way of me knee, but by doing my research I knew that going in. All cars have there issues but Honda still has an excellent reliability rating.
  • 2theedge19742theedge1974 Member Posts: 1
    I am curious to find out if anyone is having a similar problem like me. I love my 09 civic ex, it only has about 7800 miles on it. The problem is that when I drive 55 mph, it seems to be wanting to hesitate like it loses power. This is with both the ac on or off. The rpm stays the same it just feels as if the wheels tighten up for a split second and I lose a little power. Of course I take it to the dealership and they can not duplicate it. Also I have a real problem with the door. When it is warm outside, the door has to be slammed to be shut tight. Took it to the dealership and they state that it is because it is sealed so tight. Even so, it is hard to open regardless if it has been shut hard or not. I noticed when I bought the car with 2.5 miles on it, there was a flaw in the paint on the lower kick panel on the door. almost like it had been repainted and the paint was not clear coated properly. Just wondering if this vehicle may have been damaged during PDI or people are having the same problems as me.
  • mynewcivicmynewcivic Member Posts: 4
    Has anyone else experieced their Honda Civic rear tires wearing out unexpectedly ---sooner than they should be able to last?
    I have a new 2009 Honda Civic 4 Door that I got in October '09. I just got it inspected before I drove across the country. Halfway through my trip, I lost control on the highway when I drove over a shallow puddle of rainwater because my rear tires went completely bald in only 1200 miles.
    1200 miles in 9 months? Something is wrong with this picture....are you saying you only drive appx 130 miles per month?
  • klrssklrss Member Posts: 28
    I have been waiting for someone else to ask about this. I have not been able to find anything on this issue for the 09, but have found a lot about previous years. I have noticed this issue on my 09. I bought it new with 12 miles on it. I drove it for maybe 12K miles, and brought it to discount tire to have them rotated. He asked if the drivers side rear tire was newer that the rest, and I told him no. He said it had a lot more tread than the other 3 like it had ben replaced! I have had the car since 12 miles and I KNOW it had not been replaced...so, I figured there was something going on. I researched and found issues with rear control arms, but it was supposedly fixed in 08 or 07. I asked my service advisor about it and he said it was because i waited until 12K to rotate them. I know this is not right, but I just left it.
    I am at 26K and all tires are pretty much bald. I really dont want to spend 600+ on new tires, when in the back of my mind I know there is an issue with that drivers side rear tire not wearing like the others. If I get new tires, I will surely keep track of wear and rotate on time and if that rear tire is not wearing like the others I will bring it to Honda's attention with proper documentation.
  • Sandman6472Sandman6472 Member Posts: 6,968
    Those tires should've been rotated twice by then. Best just to do a rotation with the oil changes. But to wait till 12k...just plain silly.
    The Sandman :sick: :shades:
    2023 Hyundai Kona Limited AWD (wife) / 2015 Golf TSI (me) / 2019 Chevrolet Cruze Premier RS (daughter #1) / 2020 Hyundai Accent SE (daughter #2) / 2023 Subaru Impreza Base (son)
    There is something wrong with this picture. I did not say I drove it only 1200 miles in 9 months. I said that after the tires were "fully inspected" by Honda. ( where they checked tire tread depth, rotation if needed check, etc)
    I put 1200 miles on it. So, from Los Angeles to Oklahoma I had driven 1200 miles ( actually more like 1400 miles).
    So, in that amount of time, both rear tires went completely bald. Absolutely bald.
    To me, something is wrong with that picture. How could that have happened? Has anyone else had this problem.
