RAV4 Radio issue
I frankly don't care how MMNA fixes it, I just want it fixed.
I think each vehicle, especially in its first production year, has some sort of problems. To be true, from what I read so far on RAV4, CRV and Oulander forums, Outlander's issues are the least severe.
Mitsu will probably address all this issues sooner rather than later.
The Outlander has been available in Japan since 2005 so by now there shouldn't be any bugs left unless there were far more before which have already been fixed.
However, the North American version is not IDENTICAL with the Japanese version. One obvious difference is that Japan does not have the V6 engine. Fitting a V6 engine in the same engine bay requires mechanical changes. I'm pretty sure that there are other less visible changes to the vehicle, especially on the tuning side and other mechanicals, maybe materials, etc.
While I agree that most part of it is the same, any changes made would make it a slightly different vehicle so technically, the North American version is indeed in its first production year.
My 2 cents only....
Do You have the basic radio?
Luckily companies like Mazda and Mitsu are bringing over exciting cars and hopefully GM and Ford will bring over some of their European models. And they better not alter them in transit because it would defeat the purpose.
I have the XLS without the NAVI, only the 6CD changer. I have tried hooking my IPOD using an FM transmitter. The sound quality is not very good.
Today, I popped the back cover of the center console in the hope that I can find a prewired harness for the audio input jack that is available if you have the NAVI. The cover is held by plastic plugs that you can pop out. Here is what I found inside:
A 5-wire harness with receptacle colored black with the following colored wires: a) Blue, b) Blue with silver streak, c)Black, d) White and e) brown wire with silver streak.
Is Anybody out there who knows what the color coded wires are for.
I did not have the RCA audio jacks, I believe these jacks are available only on those with NAVI or the fosgate upgrades. I only have the 6CD changer and the back cover of the console did not have the audio jacks.
As I mentioned earlier, I was able to pop open the back cover and found a 5-wire receptacle. the 5 wires are separated in two sections, the first section has two and the second section has three. I think the two wires at the first section is for video. I used the second section with the three wires, the third wire is for the jack shield, the other two are for left and right channels.
I could not find a mating plug for the 5-wire receptacle at Radio shack and I ended up plugging three individual solid wires into the receptacle. I then soldered the ends of these solid wires to an I pod connector jack cable. Plugged my Ipod and placed my 6cd radio to AUX and turned my Ipod on. It worked. Took me the whole afternoon as I did not have the parts handy after popping the back cover open.
Pop the cover back and went to see the movie 300 with my wife.
I did not pay any attention to the wire colors, but here are the receptacle orientation:
Looking from the top, left to right:
1. First two holes in the first section are separated by blank space from the three holes on the second section. So let us just say 1 2 S 3 4 5.
2. The 5th hole is for the shield.
3. The 3rd and 4th holes are for either left/right or right/left channels, not sure which is left or right. I suppose if you are a sterio buff you would care. Sorry, I did not have the patience to test it.
By the way it is better to use stranded wires instead of solid wires to plug into the receptacle, as stranded wires are flexible. Just make sure you solder the tip you want to insert to make it rigid. As to the wire size, I used #16 and I stripped a few strands to make a snug fit into the holes.
I used a prewired Ipod compatible with male plug at both ends, I cut one end to exposed the three wires and soldered these wires to the ends of the wires that are plugged into the receptacle. I could have used a female Ipod compatible jack and mount it at the back of the cover (I might still do it some other time) so that I would not have this dangling cable.
I secured the cable inside the back cover by tieng it with a rubber band to the snap-in slot where the receptacle was being secured ( I could have used a tie wrap, but I did not have one).
Hope this explains everything I did, if not, try sending me email for other details.
Don't know about the receiver antenna input. Sorry can't help.
Anyone have any idea on how to gain access?
It should be similar for the base radio.
Next remove the two screws, now exposed, which hold the radio surround panel in place. Pull on both side where you just took the screws out and the bottom of that panel pops out. Then while the bottom is pulled out a few inches pull on each side of the top and it will pop out as well.
Now you have exposed the 4 screws which hold the radio or nav unit in place. Remove those and the unit will slide out the front quite easily. There is plenty of length to those cables, so if it gets stuck comming out it just means one of the cable connectors snagged on something. Try to wiggle the unit or the wires and it will free it up. As best as I could tell the radio antenae cable has a standard connector which will match that of an FM modulator for sat hookup.
Also of note is that there is quite a bit of space behind my nav unit so there should be plently of room to locate the little modulator box.
ITS EASIER THAN IT SOUNDS. Go one step at a time and you should have no problem. Best of luck!
Ben :shades: :shades: :shades:
Ben
So, does the base (non-nav, 6 disc) stereo have a "standard" antenna input connector on the back? I can't really tell from tose pictures. Just want to know if I need some adapters before I tear it out this weekend. Thanks
MMNA called and left a voicemail for me this morning.
According to the representive, "umm they're actually currently testing the final countermeasure for the radio and hopeful they will have a fix in a small number of replacement units by next month. I am on their list, as a matter of fact, your vehicle was the first vehicle they had with a concern, so I'm pretty sure I will be notified and I will in turn, let you know..."
I found that cable also but I didn't know how to put the radio into AUX so i figured that I couldn't use them.
I ran out to the car (in the rain) and yes if you hold in the CD button,it goes into AUX!!!!!!!
I'm going to wire that baby up tomorrow.
Has anyone thought of this being the problem...or has Mitsubishi US/Canada mentioned anything about a possible fix?? I'll keep you updated if I hear anything back.
I don't know how would that be possible with the Outlander as most loans were sold to CenterOne Financial, which has nothing to do with warranty claims except handling your loan payments.
If all songs are that way, then I suspect your cable maybe bad. You may also hear some noise if you are charging your Ipod while playing it.
anyone else notice the "white noise" when on aux with no source plugged in??
In the past, I have usually found a fuse for some non-vital system (for the Outlander, I chose the 20 ampere sunroof fuse #15), remove the fuse, wrap the positive power wire of the radar detector around one of the two fuse leads, and reinstall the fuse allowing the positive lead wire to be making contact with the one of the two contacts on the fuse female openings.
And the negative wire attached to any ground on the vehicle body.
I thought I had it working until I turned off the ignition and the radar detector stayed on! Not sure why, since the sunroof presumably has no power unless the ignition is on.
I know this is a crude method - but maybe someone with more electrical background why the detector stays powered with the ignition off. (The positive wire is in the lower opening of the 20A sunroof fuse.)
Now if someone knew a specific wire near the fuse box that has power only with the ignition on, I could put one of those special clamps over the wire to make contact and connect the positive wire to that.
Anyone know any good secrets in general on how to wire a radar detector so it is out of the way and relatively unseen?
Bud H
Are all channels affected if you crank the balance/fade controls around? Or perhaps one channel only?
Are all input sources affected?
It could also be a bad solder joint or intermittent component failure from vibration.
2.) All channels, fading, adjusting the tone, etc does nothing
3.) No, only FM radio
4.) Doubt it. My friends Outlander does the same thing. I also demoed a brand new unit while I was getting my bearings replaced and it did the same thing.
