Mitsubishi Outlander Heating Ventilation and A/C
tidester
Member Posts: 10,059
We're consolidating related discussions into a single topic for your convenience.
SUVs and Smart Shopper
When idling, the temp coming from the vents drops DRAMATICALLY (luke warm at best). When moving again, the heat comes up to full temp.
I've tried the "auto" setting, full heat setting, different heat locations (floor, defrost,etc...) with no difference.
This is especially annoying since I drive in mostly "stop and go" rush hour traffic. The truck blows hot air, then luke warm air, then hot air, etc... It's very annoying.
Can anyone else please confirm this? I'm going to write an extremely long winded letter to MMNA describing the now 4th major problem in this vehicle.
I'd encourage everyone else to at least call MMNA to ensure that our problems are being resolved in a quick and orderly fashion.
From what I understand, the hot air actually comes from the heated air in the radiator. So inorder for the air blown to be hot, the engine needed to be sufficiently warmed up.
And in this wintery conditions, the heated seats are a lifesaver. Definitely worth it.
The service tech used a digital thermometer and measured a variance of ~20* difference in heat between moving and staying idle. I informed him that it's probably more then that, but the truck was extremely warmed up from the 45+ min drive. In addition, it hasn't been subzero here in about a week.
He had specific instructions (from corporate) and he told me that he was going to contact corporate and tell him what he found. He's going to let me know if that's within spec or not.
I suggest calling your dealer (and possibly corporate) if you're experiencing the same problem. MMNA has been more then cordial with me and I'm really starting to enjoy the experience that I've received from them.
Oh well.
Growwise,
How is the heating keeping up with the the cold weather in Toronto these days (-20 Celsius)?
My friend has the same model and his does the exact same thing. It's really noticeable before the truck is piping hot.
So when it's early in the morning, temps in the 20's, the truck takes some time to fully warm up. As it's warming up, I have the heat on 78 (for example). I'll start driving and after about 20min, the truck starts blowing nice very warm/warm air out of the vents (doesn't matter which setting), but as I come to a stop, the air gets to be cool/warm. When I start driving, it's back to being hot again.
As I said, after driving the truck for 45min and it's fully warmed up, the heat is not an issue. The dealer did measure a difference of at least 20*f between idling and revving the motor and that's when the truck was fully warmed up (1hr). I can tell the difference between 50* and 70* easier then between 125* and 145*. That's what I'm experiencing for the first 0-20min of my drive. I only work 30min away from home, so you can see why I'm frustrated.
Whenever I turn the auto climate control, AC light comes on. Why does it need AC in the middle of winter? Especially when it is trying to heat from subzero temps to room temp..
I click on the middle knob and ac light goes away which is what I want until the summer... It also comes on when I turn the rightmost knob from auto to windshield defrost mode which I got no problem with though as it clears the fogging.
If Mitsu is going to offer an Auto setting they are going to cover their butts by having the AC come on when you select it because, god forbid, you should get in an accident from window fogging. They do give you the option of not having the AC come on in Auto mode. See page 5-31, Personalizing the Air Conditioner switch, in the owners manual. Most answers to these kinds of questions can be found in the OM.
I don't know what is the rational behind it, but I'm curious to find out.
Any update from MMNA on this?
Back in the day when the AC compressors didn't automatically come on when you hit the defrost button, I'd turn on the AC to clear the windows faster.
I'd think if you were hitting recirculate, you aren't giving that moist air much chance to escape either. (Where's wwest? He'll let me know if I've hit the high points or not ).
Check out Climate Control Problems (Air Conditioning, Heat) - All Cars too. (jason0820, "Climate Control Problems (Air Conditioning, Heat) - All Cars" #426, 2 Apr 2006 1:43 am is one thread).
1. fan was in off.
2. temp was set to 21 celsius.
3. Recirc was off so that explains outside air.
4. No ac and direction was set to auto.
I thought the engine was getting way too hot and that hot air is coming in. Is this a normal behavior?
When the car is idle you can hear the vents very loud for about 10 seconds, they turno off for about 30 seconds and then again.
This is normal for the car??
It allows the AC to produce cold air in very little time compared to other vehicles.
You can reduce the frequency and time the fan runs by NOT selecting max air if you have a LS. If you have the premium AC with the temp setting I dont know how you dont select max air. Regardless its not something you need to worry about, its not hurting anything.
I haven't been using the A/C that much until recently when summer got into full swing. I noticed about the A/C fan/clutch cycling often (every 15-30 secs) which is normal as I've read from the previous postings here. So I've no questions about that, just a bit surprised when I started noticing it.
The real issue I have right now is about the cold air being not distributed evenly. Pictures paint a thousand words so please refer to the picture below. Everytime I run the A/C, I only get cold air blowing through the vents on the driver side (shown in GREEN circles). The passenger side vent (in RED circles) does not get cold air at all. Even with blower settings set to blow on the widshield or bottom/foot area, only the driver side gets cold air, not the passenger side. I tried to set set the blower to AUTO, still the same. A/C mode to auto and manual, all the same. And this is with a passenger on the the passenger seat, just in case this vehicle is that smart to figure that out.
Any thoughts or similar experience? Share your experience so at least I can relay to the Service Guy if any other vehicles are experiencing the same problems, and this might actually warrant another TSB if proven to be on most vehicles.
Well, condensation is always good when talking about the A/C. Looks like it's a good sign of a good A/C doing its job.
:mad:
Car618@hotmail.com
Even the engine seems to take longer to warm up than it does on my '05 Lincoln and when it's warmed up it still doesn't give great heat.
I'd call it adequate at best.
