Mazda MX-5 Miata Audio System Questions
                    I'm looking for help in how I might put headrest speakers in my 2002 Miata. (I don't have the Bose sound system, just standard, with those worthless tweeters in the top of the doors and regular door speakers)
I had a '91 previously with headrest speakers (aftermarket)and they were great. Of course, the later models don't have the zippers and set-up to put speakers in the headrests, but, I've really missed having headrest speakers and plan to keep it for many years to come.
Who can give me some assistance or advice? Thanks!
You may want to try a rubber spacer to absorb vibration, that may quite the buzz.
My question is this: Does the non-changer model have a 'load' button on it, but without the functionality?
Also, there's a button on the top row right, labelled "media". Can someone tell me what this is?
Thanks in advance.
Sam.
We had 2 of them, still have 1 actually. 6CD plus tape is nice because it's so flexible, you can use those tape inputs for all sorts of devices.
I am reading the forums and this appear to be a common issue. Is there any preventative maintenance I can do in the future? I am having the player replaced as it is under warranty, but if it happens again I may opt for a non-stock brand.
Other than that, the car has been great so far.
Cheers.
Anyone ever had that problem?
Mainguy
The radio started working fine but still fails at times.
My next step is to check the ground on the radio unit itself.
Thanks for any help, I'd be very greatful.
I put in one I got for $99 and it sounded better than the old MSSS upgraded system on my 93.
Who knows what oxidation has occured in 20 years on yours.
Thanx for the reply.
I thought that might happen when I sold my 93, but then the guy asked if it had an iPod input.
The new stereo did, so I just showed that to him. He wasn't even interested in the old head unit.
The only suggestion I have is that you document the problem in writing to your dealer, and copy Mazda corporate on it. State explicitly that this has been an ongoing problem during the warranty period, and you want their assurane that they willo fix it under warranty.
A common "out" that manufacturers use is this: when a previously reported symptom crops up again after the warranty runs out, they will claim that "it's a different problem", so watch out for that.
Sam.
Can anyone help with the following issue. My wife bought a 1993 Miata. All is good except for one thing. It did not have an antenna (power antenna). I ordered one and the install was fast and works. However, I understand that the original panasonic radio, with moisture, may not work from time to time thus no power, no power antenna. I understand that I could pop it (radio) out and then clean off the glue on the circuit board which maybe trapping moisture. But, how do I get the radio out. Anyone done that before. Also, what is interesting, when I did have power to the radio, and was able to feed the new antenna, after, when I went to move the car, when I depressed the brake, it made like a clicking noise. Does not seem to do any harm or anything but did not hear that noise before I installed the radio. Do all Miatas make that noise when you depress the brake? Is it possible now noise is traveling from brakes to speakers. I look to you expert Miata owners for thoughts. I am a Volvo guy but now that my wife has this terrific Miata, I am sold. Thanks for your comments in advance. MB">
First I replaced the head unit entirely. It had an aux input, which I hid. When I sold my car, the buyer asked for the input, so I had to go back in, wire that to the storage bin under the arm rest.
I found instructions on the Miata.net garage:
http://www.miata.net/garage/
While you're at it, check the grommet that seals the manual shifter linkage - I guarantee that rubber was worn and is torn by now. It just takes gear oil (75w90 or so). You may want to use a turkey baster to suck out the old/dirty fluid, then add new.
You'll find instructions for that on the same site as well.
FWIW, I put in a cheap $10 whip antennae and it worked fine. Don't waste too much time on a power antennae, those break easily.
Plus - you may as well change the stereo while you're at it. I'm surprised yours still works. I had the top-line MSSS (Mazda Sensory Sound System) and it had lost all the lighting by the time I swapped it out.
93 Miata C Package (sold)
08 Miata PRHT Touring
