Mazda CX-9 Maintenance and Repair
I'm interested in hearing peoples' experiences with repairs and any problems with your cars. Do you find this car fairly trouble free?
I received a letter in the mail regarding the door checker recall...but it only affected vehicles within a certain vin # range. My dealership didn't even know about it.
Mazda should be able to tell you.
I noticed a pull to the left at highway speeds. Have it in today and they said there is a service bulletin on it. I had seen one on the 2007 discussed previously on the 2007 CX-9 board; evidently it's still a potential problem on the 2008.
They've gone through a bunch of steps to correct it, and they are apparently at the final thing that could need changing/adjustment. They didn't get to finish it today - hopefully it will be finished tomorrow (and fixed!).
Not real happy about it, though.
It is driving much better now.
Ken
As far as I can tell, this might have happened once on the CX-9 forums, when a dealer topped off with the wrong fluid upon delivery of a new CX-9. Otherwise, I haven't read of many issues, since computers these days tell the shop what to use.
That's why only the CX-9 transmission requires a specific transmission fluid and has problems if it gets filled with the transmission fluid that is usually used in the other vehicles.
This sounds like BS, any of you gotten this response?
I think the dealership is out of ideas on what to do. As far as I am concerned, if I let go of the wheel on a flat, straight road, the vehicle should not pull in any direction.
I haven't been convinced enough yet to bring it back in.
If yours does reliably still pull (I think it should track by itself, too) I would try to take it up the management ladder with Mazda.
When I used to read the subaru threads, they would mention some sort of regional customer service type to help with such things. Maybe Mazda has a similar set-up?
The service manager tried to tell me about road crowns and potholes, blah, blah....
Whatever. Apparently, the alignment was out of whack from the factory.
The car does track straighter on the highway now, so I'm satisfied with the repair.
Still notice it a bit sometimes, but way better.
This seems to be an issue that Mazda needs to look at.
It is annoying, to say the least, to have to fight the car to keep it straight. I would go to another dealership if the one you went to doesn't give you the result you expect. But that's one issue with Mazda - there aren't as many dealerships around as other manufacturers, so it could be a hassle if your local dealer "gives-up" on resolving this issue for you.
Good luck!
When it does work, it comes on only when the liftgate is open. One of these days I'll take it in and see what they say.
i have the same problem. what is TSB, how it helped you and how it can help me.
Unfortunately, my dealer couldn't totally resolve the issue. Has anyone called Mazda on this issue?
thanks, i brought it to dealer, but it is not fixes properly.
does any one has any suggestion?
One of the reasons I bought the car was because it would go 7K between changes - the hassle of service more frequenly is more than I'll put up with. Anyone have any feedback on this?
On top of that, the first oil change at my dealership was supposed to be free. When the guy bullied me into using full synthetic (I would have anyway, but he didn't know this) he told me that I would only be charged the difference between what I would have paid for the standard oil change and full synthetic. As it turned out they charged me a LOT more than just the difference - I ended up paying way more than the fee for the standard oil change. And they suggested that the guy at the service desk made a 'simple mistake' when he told me that. But that they wouldn't stand by what he said, and that they wouldn't/couldn't explain to me the rationale for this policy. As you might imagine, they've lost my business forever.
- pulling left (TSB - turn strut 180 degree)
- door (recall)
- some concern about tranny by Aisin
- rear hatch light (on or off)
The CX-9 sounds very reliable to me. I love mine so far.
I do wish Mazda use a taller 1st gear. It is too short to be useful other than
towing a heavy load. The second gear is as tall (or short) as the 1st gear of any Honda tranny.
Ken
Your point was exactly like mine. I meant to point out the fact that the 6-speed tranny in CX-9 (Aisin made) is no different than a 5-speed tranny of Honda since the 1st gear runs out of steam very quickly. Good for heavy load launch only.
As long as you keep the receipts of services performed, Mazda can't find trouble with you on warranty. Any ASE certified mechanics can perform the services for you.
That said, I don't trust Jiffy Lube on my new vehicles.
Ask yourself, what kind of oil they use, what filter they use? Do they just charge you the labor cost if you brought the oil and filter yourself?
CX-9 is much more spacious than the Murano - no comparison.
The 3rd of CX-9 is actually useful even for adults on short trip, unlike Highlander and Pilots.
Ken
