http://www.topix.com/forum/autos/jeep-grand-cherokee/T63DRCOTUFKMHQ207
First, I want to say thank you for the info, you saved me money and aggravation. Second it took me a little while to figure out what contact I was looking for. So I would like to provide a little more detail to make it easier for others in the future.
This is the corrective method for your brake lights not working when your headlights are on(2000 Jeep Cherokee Laredo).
1) The cause of the problem is heat from the bulb.
2) Remove the light assembly as if you were going to change a bulb.
3) Turn the socket and remove it from the taillight assembly and set it aside(check to be sure your bulb is not burnt out).
4) Look at the opening, you will see 3 flat chrome colored contacts on the assembly.
5) Notice the one by it self at the top of the opening, that is the “ground”.
6) If you look closely you will notice the plastic around the ground contact has shrunk a little bit, this caused the contact to pull away from the socket, causing the problem.
7) With a small flat head screwdriver, VERY GENTLY pry up the contact so it stays slightly upward by itself.
8) Re-insert the bulb assembly back into the housing and press your brake petal with your lights on.
9) You should be in good to go!
10) Tools: Phillips head screwdriver and a small flat head screwdriver.
11) Time : 5 minutes per light
I'm assuming both lights are supposed to work and the inner bulbs are not just for aesthetics. I consider this a major safety issue at night due to the fact I can't see but 50 feet ahead of me. Has anyone had this issue? Fixes?
I constantly see Jeeps on the road with at least one of BOTH (break or lights) out! We keep getting warning tickets from the local cops and we show them the 1/2 dozen sockets in the back that we have tried with no success.
Do you have a photo of how you added the aluminum foil!?
Thanks again for sharing.
Whoever designed this light should be SHOT!! It's moronic the way Jeep has designed it and kept the same design despite years of problems.
IT WORKED! THANK YOU!
