Nissan Sentra Lighting
spacemanpetespacemanpete Member Posts: 2
edited July 2014 in Nissan
Hi, I recently purchased a 07 Sentra and was suprised to learn it does not have daytime running lights (looks like the 08 does). Although I do notice in the manual it references in Canada it seems the car does.
I wonder if this means it can be modified -- has anyone done any work on their 07 Sentra to get daytime running lights? Thanks for your input. Peter
  • greanpea68greanpea68 Member Posts: 1,996
    No Nissan's in the USA have daytime running lights. Some have Automatic head lights.
  • spacemanpetespacemanpete Member Posts: 2
    Thanks for the reply. Yes, I know they don't -- that's why I'm wondering if anyone has had any work done to make a modification since it seems they do in Canada. Has anyone installed the electronics to make them daytime lights?
  • txn_egl_scttxn_egl_sct Member Posts: 20
    When I had a Ford SuperCrew the Canadian trucks had a module that literally plugged into the headlight wiring harness that controlled the DRL's. It was totally plug and play. No doubt there is something similar for this application.
    You could order the component and install it yourself in minutes.
  • spm1spm1 Member Posts: 3
    I just bought a used 2001 Sentra and have purchased a DRL kit that I am going to install. You can find them on ebay.
  • ndbhattndbhatt Member Posts: 1
    How did the DRL install on Nissan 2001 go?
    Which specific DRL kit did you buy frmo ebay? Was it DIY or your mechanic installed it?
    I need to relocate to Canada and am looking to installed DRL for my Nissan sentra 2001 car.
    Please share your experience.
    Nik
  • rosajohnrosajohn Member Posts: 1
    I came home on night and found my brake lights on without the brakes being applied, lights tuned on? does anyome have any suggestions to this problem???
