Touring owners with PAX systems can switch to conventional wheels and a spare!
http://www.collegehillshonda.com/artman2/publish/Odyssey_41/Podcast_Episode_131_- - -_Honda_Odyssey_DePAX_Kit.shtml
Q&A about PAX tire system
http://www.collegehillshonda.com/artman2/publish/Odyssey_41/Common_Odyssey_Q_A_a- bout_the_PAX_Tire_System_159.shtml
I've read you need to be careful or you can scratch the rims?
http://www.youtube.com/watch?v=M9ML9oQlf7M
college hills honda
Part 1 of 2:
OK so I am now free of the tyranny of the Honda/Michelin Pax tire fiasco. After looking for information on depaxing and only finding bits and pieces, miss-information, and hearsay I decided that I could do it and publish some accurate information for others who may be looking to do the same thing. So here goes
First the standard disclaimer: If you decide to de-pax based on this information herein you do so at your own risk. The replacement wheels and tires that you pick will not be exactly the same in size and weight as the OEM Pax tires and therefore the suspension and handling may vary from the OEM design target. I do not guarantee any information herein although I have attempted to make it as accurate as possible.
2006 Odyssey OEM Pax Wheel and Tire Size: 235-710R 460A 104T. This translates into: Wheel Size: 18.1” diameter Tire Size: 235mm width, 27.95” Tire Diameter, and sidewall height of 4.9”. Translated into P metric sizes it would be a 235/53 R18.1 Tire.
Looking over the Honda 2006 and 2008 Odyssey Glossy pamphlets that I have: The Stabilizer bars are 24mm for non-Pax Vehicles and 25mm for Pax Vehicles. Only a 1mm difference! This would result in only a slightly stiffer torsion bar. From the pamphlets see that a 235/60R17 102T is the tire package offered for a 2008 Honda Odyssey Touring NON-Pax vehicle. So it seems that a 235/60R17 tire and wheel package would be safe as an installation option. Another option is a 235/65 R16 103T Wheel and Tire option. This is the standard tire size for Non-Touring Odyssey 2006 and 2008 models.
See second post after this post for the rest of this article.
Next I back engineered data to see if there were any differences between the 2006 to 2009 Honda Odyssey wheels and tires. I went to my favorite source; www.tirerack.com and plugged in the model years of 2006, 2007, 2008, 2009 for Honda Odyssey non-pax vehicles. The tire wheel packages were the same for each of the years showing that the mounting dimensions, clearances, wheel lugs were the same. Tire rack preselects only wheel/tire packages that will exactly fit your vehicle so the chance for problems are very small. One of the parameters they consider is Wheel Offset (distance from the axle mounting surface to center of the wheel). Just choose any one of the Odyssey non-pax vehicles when selecting the wheel/tire set for your vehicle, example LX, EX, or Touring Non-pax.
I first looked at using 18” wheels (to most closely match the Pax system wheels) but I found only 1 tire choice that was offered for this wheel size! Not good! Tire Rack caries at least 20 brands and they only had 1 tire choice. This would be no better than the Pax System if you got a flat chances are no one would have a replacement. So I downgraded to 17” rims and surprise, I had a choice of about 20 different tire brands. I chose the following: Goodyear Assurance ComforTred 235/60R17 with Elbrus 102 17” High Pressure Cast Alloy Wheels. The load rating of the Goodyear tires are slightly less (102T) than the Pax tires (104T) but 102T is the same load rating as specified for the 2008 Touring Non-Pax 235/60R17 Tires. These wheels ship with a centering ring a circular piece of metal that ensures that the new alloy wheels oversize hub mounts concentrically to the vehicles hub for precision wheel rotation. Some wheels may not require this (if designed only for a Honda) but many will. Tire rack mounted and balanced them (for free) using Hunter Precision Balancing Machines and shipped them in one day! I received them in (flawless condition) on day two via UPS ground. Total cost with shipping was $1,077. This is less than the cost of just 4 PAX tires with mounting!! I love Tire Rack!! This is the third set of tires I have bought from them and the experience has always been great.
What about the TPMS? Well Tire Rack has the TPMS for the non-Pax equipped vehicles but they say they do not carry the ones for the Pax vehicles. So your choice is:
1: Don’t use the TPMS (TPMS was installed originally for run-flats only because you might not know that you had a flat and the run flat could disintegrate after 125 miles). Extra Cost: $0 and ignoring the TPMS warning on the dash display.
2: Dismount your old Pax tires or cut a hole in the tires and remove the sensors and install them on the new wheels. Extra cost: $300 to dismount 4 pax tires + $90 for install, balance and mount on new wheels (Honda dealer quote).
3: Buy new TPMS OEM sensors from Honda and install them on your new wheels. Extra cost of $235 for new sensors + $90 for install, balance and mount on new wheels + $50 to initialize new sensors (Honda dealer quote).
I choose option 1 and we are just ignoring the TPMS sensor warning. I will be checking my own air pressure. Note: Pulling the fuse on the TPMS system still yields a TPMS warning on the dash.
I plan to buy a 17” space saver spare from Honda and it should fit in the floor space after removing the revolving turntable. Honda quote: $67 for wheel, $135 for tire, $25 for mounting = $227. The Touring already includes the jack so nothing is needed there. If you want to save your turntable, forget the spare, buy a can of flat fix, and keep your AAA membership up to date. In the last 20 years I have not had a flat on the road that required a spare. All the flats I have had were slow leaks due to nails and they were recognized and fixed at home.
So how does it ride? This is subjective as I am comparing to how I remembered it to how it is now. My first feeling was a lighter feel from the overall van. The wheel response before felt somewhat lumbering. The ride may be a touch harsher on broken pavement on side streets. On the highway it is quieter. I feel the taller tire sidewalls (more cushioning) on the 17” tires offset the stiffer suspension that results from less un-sprung wheel weight. My significant other says it turns better and overall is happy with the ride quality. Most importantly she is relieved about not worrying anymore about a Pax flat and getting stranded.
Conclusion: I can now replace my tires with any number of tire brands at any tire dealer I choose for a fraction of the cost. Of course I choose Tire Rack! If I get a flat anywhere it can be fixed anywhere. My ride is improved and in fact the new wheels are ultra cool!! We can now travel without the fear of getting a flat and getting stuck because no one can change a Pax tire. Good luck and happy depaxing!
I want to replace these tires with a all-season tire as i donot drive in anything but light to moderate snow and occasional ice.
I have done some inquiring into what tire would be best and theYOKOHAMA Avid TRZ (235/65/16) tire appears to be it.
Has anyone had these tire on there odyssey and how did they perform for you. i was told about the Blizzak tire but i cant afford another set of rims with new sensors just to put a set of snows on and mount and unmout snows this leaves me with concern about the tire bead and air leaks. I have been told by two tire shops that the bead could be compromised at any time the tires are changed seasonal. Thankyou very much for your help
john
If you want to de-PAX, then talk to your local tire shop. They most likely can help you if they really want your business. The trick seems to be removing the old tire and reusing the tire pressure gauge sensors on the new rims. Again, any tire shop worth their sweat will do this. Skip the Firestone or Sears stores, they probably won't touch it. Go to the independent guy.
STEVERX - would love to see some pics of the aftermarket wheels - I am tempted but don't want to make it look "ghetto" - it is a minivan after all :-)
I have cross-terrains on my 05 highlander now and love them except for snow. Heard several complaints on the PAX systems is removing it challenging for a technical guy?
I did not have much time do to research and didn't want to do it myself so my friend recommended me a seller: Acurahondaoem on Ebay who have a lot of depax package sets for sale on Ebay, ready to bolt on with Hankook Tires, so we bought a set of 18", I think they came from an Acura MDX. Wheels came to our house within a week, great packaging, great communications from the seller. Wheels and tires are look great upon arrival, installed on the van and tpms kick in within 10-15 mins as seller stated, sweet, love those ride on the Hankook tires, very quiet, handling great, much better than those PAX tires. I would recommended seller Acurahondaoem. You can browse his store by on to Ebay and enter DEPAX on search section, then look for seller Acurahondaoem. I love our van more now. Bye Bye PAX....
Thank you for your very informative article.
I'm ready to take your advice for my 2006 Touring w/pax system. Would you do anything different or make any changes to your recommendations?
Hankook Optima H727
Goodyear Assurance Triple Tread
The Cooper CS4 received a good score for snow traction, but not as high overall. I'm considering the Hankook's for my 06 Odyssey.
Anyway, I had done some further research on the internet and message boards, etc. Also April 2009 edition of Consumer Reports listed this Yokohama as one of there top 3 rated tires.
See also this site for ratings of tires. Very enlightening.
http://www.tirerack.com/tires/surveyresults/surveydisplay.jsp?width=235%2F&ratio- =65&diameter=16&type=ST
So good luck rihops, but keep checking before you buy. I noticed that Hankook is lower down on the list on that link shown above.
I'll post more thoughts about them later.
(I have been doing this for years on a '02 Toyota Prius and I have the dealer include the winter/summer change overs in the price of the snow tires and am very comfortable with this except that I need to be conservative in the timing).
IMHO, I'd go with 2 sets of rims and some black electrical tape during the winter.
Looking at the whole picture (safety, cost) I have come to the conclusion to simply have the tires changed on original wheels each fall and spring due to the problems with two sets of wheels. I have been successful in the past at getting a tire dealer to include all those change outs with the snow tire deal buy adding about $60 to the cost of the deal. Will see how I do this year and let you know.
link title
It appears it will do the job and then I found a discussion on another board.
link title
It had been "Test-Driven" during the 84 miles to the NC Dealer who was selected.
Though 2 hrs away from our home, they had miraculously produced the color that I, (the "wife") had desired. We checked reputation of car and dealership!
After inital driving approx 40 minutes out -and while ascending a winding uphill Mt. Highway at 70 mph, - the V.S.A. LIGHT and ALARM sounded accompanied by sounds similar to a home "Sump Pump cycle". This was accompanied by HORRIBLE GRINDING NOISES - like driving on metal rims only. Thank god I, (a lesser-experienced-Driver), was not at the wheel and could easily have lost control by being surprised at 75 m.p.h between trailers.!)
After turning VSA back-on the same scenario occurred --whether ascending or descending -- heavy turns or slight -- different speeds (incl 30 mph on local winding country road ).
Next AM - we reported to selling Dealer who was completely unsympathetic to the danger, just denied any awareness of the problem, and suggested my husband, (an experienced middle-aged Driver with considerable background in Auto Mechanics ) "might just have left the safety brakes on"!!
We then contacted nearby local Honda Dealer and insisted the Van be picked up on flatbed that morning. After Computer and Testdriving by different Tech/Mechanics with the same results - they concurred on the serious problem and said they were " stumped and never experienced this before". (Neither did we - after spending over 40K$ the afternoon before) . This Monday AM : Nov 2, a Honda Rep will be brought in and begin "Conference-Call Repair Sessions " with Honda Tech-Engineers. (Do I smell a recall situation brewing??)
We're very concerned with the danger and a recurring lemon nightmare that might follow - and have been researching blogs on Goggle. Did anyone else experience this situation? and with what reasons and results??. Any tips or advice from professional mechanics or recommendations from savvy readers?? Should we keep this car? How do we protect ourselves -asap?? PLEASE HELP! Thank you in advance.. Spikey09 Mom
Since my original series of posts on this matter, I was able to purchase a set of Blizzak WS-60s from a local dealer at a price competitive to TireRack ($525 including everything) AND they agreed to do the fall/spring change overs at no cost as long as the snow tires last. No wheels to buy, no tool to mess with,... talk about a "no brainer".
NO LUCK - still the same problems - especially driving into a curve. HONDA is Clueless...Now we really have a problem and have lost faith in Honda's Reputation of Reliability. Plus we're "out" a $40K+ brand new car that we haven't been able to sniff or touch since we drove it home last Thursday... (Only the Selling Dealer, who has demonstrated the fact he doesn't give a Damn, is Happy!!
(I promise a Reward for the Hero who solves this Lemon P problem)
Meanwhile, our distress continues as it is a week since we pickedup the new Van and it's still languishing at the AutoDealer Repair Shop.: Honda Tech now determined it was a defective "STEERING ANGLE SENSOR" - which was miscommunicating to the V.S.A.system with a "no signal" on turning the steering wheel...they're sending a relacement S.A.S.today!!
PS (Honda is now getting investigated by the Feds regarding the Safety of 2009 Brake Compaints on the Odyssey Minvan !! Hope our problem doesn't become another issue that will poorly brand the Odyssey for "Tradein Value". It's unfortunate that Honda needs outside legal pressure to force them to protect "SoccerMoms" and others! Wow, Honda sems to be buckling under in this hard economy and becoming totally "Americanized"in the worse sense of our unfortunate Automobile History --- what a great and priceless loss to their sterling reputation this will be!!
