Mazda CX-9 HomeLink
I just bought a Grand Touring FWD and added the auto-dimming mirror. Can anyone please tell me how to program my garage door and driveway gate into the "homelink" buttons to operate from the car? I'm assuming I do so through the mirror, but I have no clue what to do. My salesperson is clueless, too.
Thanks very much.
Thanks very much.
HomeLink® Programming Instructions:
WARNING! Before programming HomeLink® to a garage door opener or gate
operator, make sure that people and objects are out of the way of the device to prevent
potential harm or damage. When programming a garage door opener, it is advised to
park outside of the garage. Do not use HomeLink® with any garage door opener that
lacks safety stop and reverse features as required by U.S. federal safety standards (this
includes any garage door opener model manufactured before April 1, 1982). A garage
door that cannot detect an object – signaling the door to stop and reverse – does not
meet current U.S. federal safety standards. For more information, contact HomeLink® at
www.homelink.com or by calling 1-800-355-3515.
1. To begin, press and hold the 2 outer
HomeLink® buttons (to clear memory) until
the indicator light (LED) blinks slowly
(approximately 20 seconds). Fig. 1
2. Release both buttons.
NOTE: Do not hold the buttons for longer than
30 seconds. Do not repeat this step when
programming additional devices to remaining
buttons.
3. Position the end of the hand-held transmitter
1-3 inches away from the HomeLink® button
you wish to program while keeping the
the indicator light in view.
4. Simultaneously press and hold both the
chosen HomeLink® and hand-held transmitter
buttons. Fig. 2
Do not release the buttons until step 5 has
been completed.
NOTE: Some gate operator and garage door
openers may require you to replace this
Programming step 4 with procedures noted in the
“Gate Operator / Canadian Programming” section.
5. After the HomeLink® indicator light changes
from a slow to a rapidly blinking light, release
both the HomeLink® and hand-held transmitter
buttons.
6. Press and hold the just-trained HomeLink®
button and observe the indicator light.
If the indicator light blinks rapidly for 2 seconds
and then turns to a constant light, the device being
programmed utilizes rolling code and
programming is not complete until the following
steps are completed. Fig. 3
7. On the garage door opener receiver
(motor-head unit) locate the “learn” or “smart”
button. This can usually be found where the
hanging antenna wire is attached to the
motor-head unit.
8. Firmly press and release the “learn” or
“smart” button. Fig. 4
NOTE: You have 30 seconds to initiate step 9.
In the other thread you said no wire is showing. Does that mean that if I get all the right parts and have it installed properly that it will look and operate just like factory installed?
If so, can you point me to the parts I need for a 2008 GT AWD?
Rob
This is the one you need. Ship and handling is free.
http://www.mazdaparts.org/macxaumiwico3.html
0000-8C-Z02
0000-8C-N01
Two parts. One is the mirror itself, one is the kit that fits vehicle with rain sensors. Essentially, there is a big housing to accommodate the rain sensor. The kit comes with instructions. Several steps are tricky
- removing A-pillar interior trim. Read instruction carefully before you do it.
- removing the existing rain sensor housing. Don't use brute force. It should come off easily. If not, you are doing it wrong. Read instructions again.
- removing the existing mirror. You need to make a steel wire tool (use wire hanger, for example). You will see when you read the instruction. If you are lucky, it takes 10 seconds, if not, it may take 10 minutes of trying.
Well good luck and have fun.
When I said no wire showing, I mean nothing you can see when you are in driving position. Of course, there is a black cable (of wires) into the mirror. It is behind the mirror so you don't see it unless you try. The most part of the cable is covered under a U shape trim piece (from the kit).
Don't worry. If you do it right, it is as good as from factory. They do it with the same part. Those workers just have more practices than you. That is all. Take your time doing it. It is not a race.
