Visitor Agreement.
Mack
Here's the list of all Samsung phones but I don't see a Blackjack 2 listed in this section or the section where you would connect thru the navigation system. Might have to get a new phone.
Mack
The Blackjack 2 is a brand new phone and works fine with the system. It's AT&T's flagship for the smartphone platform.
The only problem is that the Toyota docs don't really give enough in depth detail on transfering your data to the system from your phone. I figured most of it out through trial and error and have is working now.
Question for mackabee: I was hoping someone would fully answer message #1183 regarding satellite radio questions. As a salesman, possibly you could do that for us?
2. XM and Sirius will be available. Right now the website does not show either one but it will be available.
3. It's a port installed or dealer installed option.
4. the module is not visible
5. Once installed the operation is thru the radio interface however it must be the upgrade JBL system with satellite radio capability and bluetooth OR thru the navigation system for those equipped with that option. On SR5 and Limited It shows up on the window sticker as option code EJ.
Mack :shades:
Mack
I did not have time to research it-late for the airport. It does list a phone number.
Good article on extended warranties. I contacted the Toyota dealer in the post above from gldwing. Sounds like a good guy and very informative. His price on the 7yr/100K/$0ded extended warranty for a 2008 Plat Sequoia is $1040 ($100 above dealer cost or $810 under msrp). The price from the dealer contact I provided earlier (Troy Dietrich) in this thread sells the same warranty for $990 or $50 over dealer cost ($860 under msrp).
I had a cargo cover that came standard with my Denali XL. It's still sitting in the garage where I placed it 5 years ago when I brought the Denali home from the dealer.
I by the way use it quite a bit. I leave it in place when not in use, it does not really get in the way of anything.
Wonder why GM couldn't do this? Does it have something to do with the (lack of) independent rear suspension?
Barry
What I want is a bug shield and a set of husky liners for the 08 Sequoia but have not been able to find those yet.
Mack
We have the Platinum and I've never seen them come on yet, is there a switch or something to turn them on.
I would assume that they would be activated when you unlock your car and be timed to go off after a short time. Anyone know how this works?
Also I find it strange that the Sequoia doesn't have an internal gas lid release to help prevent tampering/stealing your gasoline, which is getting rather expensive. I suppose I could find some kind of locking gas cap but the internal release would have been much better.
I too was surprised to see no locking gas door ar at least a locking gas cap. I plan on getting a locking cap.
Thanks much
Much appreciated. Thanks.
Carpet Floor Mats
Cargo Mat
Door Sill Protector
Cargo Net
First Aid Kit
MSRP = $368
Dealer cost = $295
I purchased it with my Platinum and the dealer included it in my purchase for $320. I hope that helps.
1. As far you know, does the picture below accurately represent the rear entertainment system in your vehicle with the 10" screen?
2. Does the system integrate at all with the navigation system or is it stand alone?
3. What are the options in terms of sound delivery? Does the sound play back only through the wireless headphones (2 pairs) or can the audio play though the JBL system?
4. How about control? Is the entire system just controlled by a remote control or can the system be controlled from the dash?
5. Is there any scenario under which the Rear entertainment system comes installed from the factory and not port installed? Dealer swears that they are only port or dealer installed.
6. If the answer to #2 above is no, are you aware of ANY FACTORY option where the rear entertainment system does integrate with the NAV?
7. Anything else I should know about the system?
I am not looking for any surprises at the time of delivery and want to make my expectations clear with the dealer upfront.
Many thanks.
Becasue it mounts directly up against the rear of either the 2nd row or 3rd row (depending on the position you want).
It would only get in the way if you had the 2nd or 3rd row folded flat.
Thanks, JD. Still loving this vehicle!
But like you say, not a lot of insurance companies (or people) see much value in it.
