Squeaky brakes 2001 GMC Yukon XL
I have a 2001 GMC Yukon XL. It has around 73K miles on it. The brakes squeak almost every time they are applied. I have had them checked at 2 different places and my husband even looked at the pads with the mechanics, who both told him that they brake pads and rotors were fine, and did not need replacing. Is there anything else this could be, or just a chronic thing I should learn to live with? Thank you.
Any suggestions or help will be appreciated.
A crappy solution but it works and is better than driving around with everyone looking at you. I considered selling the car just becasue of the noisy brakes.
It is my opinion, the proper way to minimize or even eliminate (in most cases) the squeak noise to your brakes is to first clean the brake dust off the calipers and pads, then install a properly sized/fitted shims to each brake pad... Good Luck!
Many people have their brakes checked and re-checked only to have their mechanic tell them their brakes are fine, which is true from a braking standpoint, but what the mechanic fails to do sometimes is actually address the customer’s issue, which is the noise, not the brakes per se. Any mechanic who has even some experience should already know how to remedy the noise problem and those that do not should make you worry about their experience. Those that tell you to drive 45 mph and slam on the brakes should scare you to death and make you run from them never to return! (Unbelievable) Although this may stop the noise temporarily and only because the brake pad is now jammed against the caliper piston for a short time preventing it from vibrating, but as soon as it moves freely again you get the noise again.
There are many aftermarket applications you can use to stop the noise, from disc pad shims (custom cut to fit the size and shape of your pads) which stop the metal to metal contact thus stopping the squeak, to sprays which don't need to match the shape of your brake pads and can be used on all sizes and shapes of pads.
I prefer Permatex® Disc Brake Quiet myself. It stops brake squeal by dampening the shimmy or vibration at caliper/brake pad interface. Provides tighter fit and allows for easier disassembly. Protects against corrosion and is compatible with anti-lock brake systems. This product contains an elastomeric polymer that once sprayed on the metal backing of your pads (yes, you have to remove your pads, clean them and spray this coating on, usually 2 coats then allow them to dry thoroughly) they provide the same barrier between the caliper piston and your brake pad backing that shims do. You can use this spray (or any brand for that matter i.e. CRC makes the same product) on any disc brake pad, outboard and inboard, for all disc braking systems on disc brake pads without anti-squeal shims.
