Rattle underneath 2003 Envoy
jaadsilver
Member Posts: 1
Does anyone have any idea what might be causing this? I’ve had a place look at it and they were just really baffled. They even took the gas tank “down” and adjusted it and the rattle noise is still there. It really does it moreso when you slowly accelerate and on bumpy “side” roads.
Any suggestions?
Angie
Any suggestions?
Angie
Snowstorm
In addition to that, I now have developed a 'howling' noise from the front end, almost as if the 4WD is permanently engaged when it is not.
Could they be related in some way? If I bring it in to a shop, what areas should I ask them to focus on?
The dealer replaced the front bearings and this did absolutely nothing.
On an internet board a member suggested that I open the driver's door and jump up/down on the sill. This duplicated the problem.
Turns out the bumpstops under the hood needed to be adjusted. A no cost fix.
