2008 Outback 2.5i Interior Smells
I have noticed during the past few months of having my new Outback an unpleasant chemical smell coming through the vents when I turn on the temperature controls. The A/C comes on automatically and I believe the smell is coming from there, since when I turn the temp up it seems to go away. Also, even when the temp controls are turned off, there is air coming through the middle vents at all times. It doesn't matter whether the air is being recirculated or not. There is no way to close the center vents, which is annoying because it's hot air in the summer and cold air in the winter. This may be something I just have to deal with, but I thought I'd see if anyone else is experiencing these issues. thanks.
sillhouez, the fan should absolutely shut off on "0." There *might* be a tiny bit of residual airflow, but if so, it is hardly noticeable. I do not notice any on mine.
simon2, does the Limited have the automatic climate control? I have heard those to be finicky beasts to tame. :surprise:
If the system is "on" then the fan won't go off even if you turn the fan all the way down. If you turn it "off" the screen will blank and you should have no fan.
For the "free flowing air" you need to hit the recirc button when the system is "off" to close the outside vents or else you will get a residual flow of air through the car.
-mike
-mike
I was happy to see the post by sillouez because it gave me a feeling it may be a somewhat common situation between relatively similar cars.
Remember to be nice, at 101k miles you're beyond what any manfacturer has offered to customers that I've heard of.
You get more bees with honey.
Under warranty you should be fine.
I think that after 100k, it's mostly luck of the draw.
Otherwise 400 miles and no problems.
My 98 Forester had it, bad. It goes away, fortunately.
950 miles and no problems, we are loving the car, very happy with our choice for a new company/family car.
Thanks for the replies...
Enjoy your Subie! :shades:
I found that placing a car seat in the center caused stability issues with it due to the deep bolstering on the rear seats. I always had our son secured in the center on our '96 Outback, but after having our '07 Outback for a few days, I moved it to a side position to keep it more stable. With our '08, we drove a 5500 mile trip and we had our son in the front passenger seat, wife or me in the rear (passenger side), and infant in the rear (driver side). That configuration worked out very well, save for the times the toddler would get overly bored and decide to start pushing dash buttons or open the glove box with his toes. :P
