Sorry about your luck, it should get better now.
The best temporary solution is to lower the windows each and every night provided the car is under shelter.
More info at airsept.com regarding their EED.
After agreeing for the lease, it came as a shock to me that "Gap Insurance" is not covered as part of the lease and I have to pay 600 additional to purchase it. At that point I was totally frustrated and cant blame anyone other than me for signing the lease. I was also not given a good money factor even though I had a excellent fico score 780+.
Having said that about the dealer, I would like to know whether the maintenance should be done only from the dealer where I leased the car or can it be done at any authorised toyota dealer ?
Also I would like to know if purchasing a "Toyota Prepaid Autocare Maintenance" plan is worth for the money ?
Any valuable comments is appreciated.
Ditch the factory air filter for a Purolater air filter even if u apply the tsb
for shifting performance, I did with positive results after having at least
4 tsb's done to my 07' SE 4-cylinder camry.
Replace factory air filter with purolater brand filter. I surmise that
the engine is starving for air. I had about 4 tsb's B-4 that!!!
The instances of 1-2 second downshift delay/hesitation complaints will also undoubtedly rise.
You cannot make a silk purse from a sow's ear regardless of the number of TSBs applied.
Join the rest of the industry, put in a CVT and ALL of these complaints will be history.
According to Toyota, 2009 Camry I4 comes with 5 speed transmission
http://www.toyota.com/camry/features.html?trim=2532
I bought one last month myself and it is very smooth and quiet comparing to the car it replaced - 99 Accord LX I4.
Fred
This is one area where I personally have a probably unsubstantiated concern. Because I tend to keep each of our cars for at least 10 years or more, I tend to look at vehicles as long term transportation appliances. Metal gears, metal bearings, hydraulics in transmissions, normally are pretty reliable and we have all come to expect them to last 100K-200K miles, and manual transmissions even longer. Fiber belts....dry, crack, wear, stretch. This is why overhead cam cogged belts need replacing at approximately 90K miles. Metal timing chains were never a maintenance item.
CVT's have a fiber belt in the transmission, being squished between two sets of pulley faces. Mechancially, I just have a hard time thinking that a belt can withstand the harsh working environment of auto's (heat, cold, dry, humid, high rev's, etc), and compare favorably over the many years against a manual or hydraulic automatic transmission.
For someone leasing, turning the vehicle in before the warranty runs out, who doesn't care about longevity, CVT would be fine. Just don't think I'll find them in my stable in my remaining lifetime.
Manufacturers are going with 5 and 6 speed (7-9 speed in practice/reality) in order to compete with the FE of the new CVT's, and meet the new CAFE standards, especially with small 4 cylinder engines.
Do you know where I can download a copy of this infamous TSB?
Thanks, buddy!
Ciao,
Mike
I'm gonna love waving this hard copy of the TSB in my dealer's face tomorrow.
He said your number was all wrong and that it referenced some bulletin from a "third party"
He's nuts.......and I'm gonna tell his dealership owner!
These uppity service managers need some "come uppance"!!
Thanks again!
Scotty
Fred.
I'm trying to get my hands on the Enhancement to Shifting Performance and Smoothness TSB that pertains to the 2007, 2008 and 2009 CANADIAN Camry. This TSB applies to Camry LE models with 5 speed automatic transmissions. I believe the American version of this TSB is the 0068-08.
I had my dealer perform the software upgrade defined in the bulletin today, but the service manager is being pissy about even showing me a copy of the Canadian TSB, never mind giving me a copy of it. This, even though I was the one who informed him that the TSB even existed....which they didn't know last week, before I went in. (NOTE: Anyone who's purchased an 07, 08, or 09 Camry LE from Performance Toyota in the Niagara Region, in Ontario Canada, can now go in to the service department, with the confidence that Performance will NOW know what you're talking about if you tell them you want the Engine Control Module (ECM) TSB for Enhanced Shifting performed on your car.)
However, make sure they do the required test/training drive (which they didn't do on mine) AND affix the Authorized Modification Label under the hood, as required by Toyota. (They didn't even have the stickers on hand.....but I advised them that this is a necessity, so they're ordering them now.)
So, any Canadian TSB sources out there?
Thanks to all,
Scotty.
The dealer was supposed to put the car "through its paces" under a prescribed regimine of gear changes and speed levels......but he said he "didn't have time for that". Nice. This is my dealer in St. Catharines, Performance Toyota. Can you tell they're the only Toyota dealer in town?
My plan is to appeal to a dealer principal to have the required test drive performed. I'll keep you posted (so to speak.)
By the way, they referred to this TSB as the 2650.....which I'm not at all confident is the correct TSB number.
Scotty
In any case depending on the engine and transaxle component wear level, servomotor calibration, and sensor tolerance drift, etc, it may take several drive cycles, factory prescribed, precisely controlled drive cycles, to even bring the "learned" control parameters back into the ballpark, OBDII emissions MIL cleared. Since you are not very likely to rigidly adhere to the factory prescribed drive cycle you should not expect 2 or 3 of YOUR drive cycles to accomplish the task.
Then it might take as much as 500 miles to bring the parameters back to the level of accuracy they were just prior to the TSB application.
So the dealer not being willing to put the car "through its paces" was a perfectly reasonable decision. It probably wouldn't have helped matters absent your needing to immediately complete/pass an emissions test.
You probably will not know if the TSB even fixed anything until that ~500 miles has gone by.
Thanks for your response. I understand what you're saying about the emissions specs and so on, but it's not the dealer's "prerogative" to decide whether or not they'll perform the test drive........it's part of the directive included in the TSB:
"3. Start the engine and warm it up to normal operating temperature before test driving.
4. Test drive the vehicle to confirm proper vehicle operation and ECM (PCM) initial learning.
Refer to TIS:
2007 / 2008 / 2009 model year Camry Repair Manual,Drivetrain – Automatic
Transmission/Transaxle – “U250E Automatic Transaxle: Automatic Transaxle System: Road Test”
If this procedure is not followed, to the letter, then the TSB has not been performed....just like the labeling requirement. The dealer MUST attach the Authorized Modification Label, otherwise he has not completed the TSB. (If this were an owner-performed procedure, you can well imagine that any warranty factor would be voided if the factory issued TSB were not followed to the letter; it shouldn't be any different for the dealer.....especially since they are being PAID by head office to do this.)
Otherwise, why waste everyone's time (and credibility) by even including the test drive procedure/description in the fix?
My bad.
I read the above as meaning using the drive cycle technique/regimine to clear the MIL. Yes, the dealer should be required to test drive the vehicle to verify a correct level of performance in accordance with the TSB.
I drove home tonight with an extremely-rare Japanese-made 2009 Camry LE I4 auto. Everything was put together well. While most of the Japanese-made Camrys are found in higher trim-levels, having a Japanese-made basic Camry LE I4 auto with no option is something that is really impossible to get. The dealer I bought from charged me $1,000 more from the USA-made one due to its rarity, and they only get one in shipment every month. :surprise:
According to the Toyota dealer I spoke with, only 1% of 2009 Camry productions (excluding hybrids) are Made in Japan, and are strictly sold only in California, Arizona, and Nevada. Because of its low production number, they tend to be build more slowly and carefully. The ones build from Japan come with Michelin tires as standard instead of Bridgestone.
2009 could mark as the final-year for Japanese-made Camry for the North American market as the 2.4L AZ engine will be replaced with a totally-new 2.5L AR engine next year in spring 2009 for 2010 model. The AZ engine was designed in Japan, but the new AR engine was designed in USA.
See my profile: 2009 Camry V-6 LE with under 5000 miles and the tires are the same as yours with a 260 Tread Wear rating. My tires are already starting to show (even) wear but the great gas mileage may pay for it.. My first oil change became due before the six months at 3,800 miles so the tires were not rotated.
BAD OEM TIRES are the one problem you get with Lexus/Toyota. Go to ConsumerReports.org to find what tires to put on your car. Usually Michellein but there is a new Bridgestone series that has a tread wear rating over 600. Your tires probably have a the same 260 tread wear rating mine do. I don't understand why Toyota puts low mileage tires on all its vehicles ........... probably because they have great traction and no road noise.
THE GOOD NEWS: Here is the reliability you can expect from your vehicle based on the experience of my family:
In over a million miles:
All maintenance done at the dealer but not on their scale - we go by the owners manual and double the oil and air filter changes. My family has bought Toyota and Lexus ONLY with V-6 or V-8 engines since 1991: 1991 LS400 V-8 180,000 miles, 1992 4wd Pickup V-6 that went 150,000 with no repairs other than brake pads, 1997 Camry LE V6 with 200,000 before giving it as a gift to a nephew, 1999 Solara V-6,that went 90,000 before being traded in, a 2002 Avalon V-6 - sold to a fried when it had 89,000 miles - he has gone to 200,000 mile with no repairs, Wife's 2002 Lexus ES 300 and my 2009 Camry V-6.
Other than brake pads: NO REPAIRS. WI fe's LS400 battery went out in two years. Other than that, you almost feel cheated when your warranty wears out and you have had no warranty claims. I can tell I will have to replace my tires at about 25,000 miles. Read the Lexus forums; they all have the tire wear problem. The answer is there is no answer but after replacing one set of tires, you will be happy with your purchase of the Camry.
Best wishes.
Eight (8) vehicles. They never break down
