Should "Beaters" Be Taken Off the Road?
Mr_Shiftright
Member Posts: 64,481
Do you think that badly rusted cars, or cars with smashed side windows covered in plastic, or cars with holes in their mufflers, or massive body damage (trunk pushed up to rear window, tail lights wired on, etc.) should be taken off the road here in the US?
In Germany, the Technische Überwachungsverein or TÜV is an agency that must approve the roadworthiness of German cars and trucks. They can bust you for say a rusted suspension support for instance.
Do you think this would be justified by facts? In other words, is there any credible evidence that beat-up cars are by definition more fatal than clean ones?
Keep in mind that a "beater" doesn't necessarily mean a car with bald tires, no lights whatsoever. These are obvious safety items and probably most cops would order these off the road.
How about severe oil burning? Sometimes a really obnoxious oil burner can actually pass the smog test, but not your lung test.
You don't define severe oil burning but I doubt any car with visible oil smoke would pass inspection here.
Every state inspection I've read about in the US is universally hated and politicians tout them at great risk of being defeated in the next election cycle. When I lived in TN decades ago, the program was eliminated.
My sister grumbles a bit about the annual inspection required in Virginia - it looks pretty thorough (for the US anyway - link) but I don't think she's ever failed one.
In Germany of course there are age exemptions for emissions etc just as in NA - when a car is considered old (in a good way) must only be structurally sound and have proper safety materials (tires, brakes, unbroken windows, etc). This would cover oil burning as well, as these cars can puff a little here and there and be well within original specs - and it's not like the few remaining fintails, 55 Chevys etc are in use enough to actually impact pollution anyway. Germany has an active car restoration hobby just like in NA, and it is all with legal registration.
An impact to this similar to Japan is German used cars that don't pass muster end up in export markets, usually to eastern Europe and especially Russia. I think most MB W140s are there now.
This type of setup would probably be a benefit...I have to wonder how many crashes are caused by unsafe vehicles themselves - and I suspect a lot of the iffy ones aren't insured to begin with. However this might not be entirely so easy - as cars get better over time they age better, so a car might not have rust etc but still have physical or safety faults.
I also don't think there should be an option for "resurrecting" vehicles totaled by insurance after a wreck. That is just begging for trouble, since you KNOW many people don't properly fix them, they just do enough to get them back on the road. There has to be a safety hazard to other motorists lurking in there somewhere...
I have always wondered why California has such an aggressive standard for checking smog compliance but no visual safety check.
SAFETY CHECKS: Great idea, I'd like to see this in every state.
SMOKING DIESELS: That's just neglect. There's no reason they have to smoke that badly. Mostly that's dirty or worn injectors and/or bad pump timing.
Still smoking diesels neglected or not should have to pass the state standards and if they do, they should be allowed on the road.
I thought California had a clunker buy back program?
If things like headlights and glass are missing, there is no doubt in my mind that stuff like brakes, suspension, and tires have been equally neglected, making the beater a rolling missile on the road, just waiting for the first unanticipated traffic problem or light rain to torpedo someone into oblivion.
I agree that a car running down the road with a rusted out fender flapping in the breeze should be ticketed. I guess it is not a problem in CA, at least not So. CA.
Most of the beaters I see on the road are going to low wage job sites. For many of these folks public transportation is not available.
Personally, I think that if the car is able to pass a safety inspection (we have a very tough one here in NY) you should be able to put it on the road. The only other alternative would be some sort of buy back program like someone mentioned exists in CA. BTW, how does that work?
A few years back they had an article in the LA times about unregistered or uninsured cars on the streets of LA. Many of us are afraid to drive our car without insurance just knowing we will get caught and have to pay a fine. Many un documented aliens and people that just can't afford insurance simply take the risk finding that quite often they don't get caught or if they do the fine is less than it would cost to insure the vehicle.
It is true that some cars in Southern California look like they shouldn't be allowed on the road. But they are a pretty small percentage. I am sure we have more people driving while under the influence on our highways than we do driving cars that won't pass smog or safety. The real beaters just stand out and make the problem look worse than it is.
Just last year I had an old beater 1978 Ford F-250 I used to haul trash to the dump that I had to sell to the junk yard because it wouldn't pass smog. So some are taken off the road.
It is a program designed to get old yet operational cars off the road (because the smog standards when they were built were so much lower than today, and a car is only required to smog to the standard in existence when it was built). Therefore, if your car is 20 years old and registered for the road, they will pay you for it and come and haul it away. When the program started the price they would pay was only $500, but I think it has gone up to around $1000 over the years.
Not a huge incentive to junk your old car, but if you are facing the prospect of an expensive repair, for instance, or you get to the annual renewal and it is going to need work to pass the smog check, getting the state to pay you to junk it might look like a pretty good option.
I dunno if California does this, but Maryland actually makes the emissions tests more stringent with each passing year. I noticed this in early 2002 when I took my '79 New Yorker in for its emissions test. I still had my old emissions results from a 1979 Newport I'd had, that I had to take in back in 1997. I forget the exact figures now, but the limits were considerably lower for 2002 than they were for 1997. So theoretically, a car that passed in 1997 might not pass in 2002, using the same numbers.
Also, some of those old cars would surprise you at how clean they run. My 2000 Intrepid has just gone in for the OBD-II scan the past two times, but the first time I had it tested, they put it on the treadmill and got actual pollution results. I still have the results from my grandmother's '85 LeSabre, and my '85 Silverado still has to go on the treadmill test. While the Intrepid put out considerably fewer pollutants, the LeSabre and Silverado were still clean enough that they would have passed by the stricter standards imposed for the Intrepid.
Now I'm kinda curious...I'm going to have to dig up the pickup's emissions results and see if they still change the standards like they did with the 1979 cars. My truck got tested in early 2003, 2005, and 2007.
Not only are Mexican cars allowed, but Mexican big rigs as well.
Not all of them are beaters however.
I see a bunch of new Renaults, Peugeots, Fords, Nissans etc.
We even service Mexican Volvo's
In comparison, for 2000 vehicles, the standards are 0.7 GPM for HC, 15.0 GPM for CO, and 1.8 GPM for NOx.
Hmmm, I just found the old printout for my grandmother's 1985 LeSabre. It lists slightly different standards: 2.0 GPM for HC, 30 GPM for CO, and 3.0 GPM for NOx. So I guess they're more lenient for trucks? Isn't that a shocking revelation... :P
It may be that already took effect for the '08 model year, I forget the exact effective date. It's either recent or coming up soon though.
Good, I'm glad that day has finally come. Seems like trucks have been getting away with murder for way too long. Now I don't think they should be singled out and punished excessively, but a little equality would be nice. I could see the argument back in the day when trucks were used mainly for work, farming, etc., but the automakers have been exploiting those loopholes for all they're worth.
Interestingly, in spite of the more lenient truck standard, my '85 Silverado actually did better on that emissions test than Grandma's '85 LeSabre! Probably because they're similar-sized engines...a 305-4bbl and a 307-4bbl. The pickup has an oversized air filter too, which might help it turn better results by breathing better? I guess those more lenient pickup standards let them keep putting those 350/351/360 and 454/460 sized engines in trucks long after they dropped them from cars, though.
Is that website, www.beaterz.com still around?
Nope, gone.
Oh wait, here's one!
http://www.molestedcars.com/beaters.html
PERFECT examples of what I'm talkin' about. :P
I guess I just put it in that category because I got it so cheap. And it has plenty of little issues. Power seat fore-aft adjust broke, but fortunately in the position I need it to be in. One of the power windows in back quit working. It also leaks sometimes around the padded opera windows in back, when it rains hard enough and the wind blows just right. The chrome is starting to peel off the rear bumper as the aluminum underneath deteriorates. The struts for the trunk are off of some little subcompact import model that just happened to sort of fit, but aren't strong enough to hold it up, so the previous owner kindly left a broomstick back there for me to use as a prop rod.
So, like Lemko, I guess I need to try harder, too? :P
I have to disagree. My 1999 Ranger PU is my beater truck. It does not have a dent in it at 109k miles. I just do not worry about throwing things in the bed like I did with my 2005 GMC PU truck that was spotless. I bought it to be my BEATER truck. Takes a beating and keeps on truckin'.
In San Diego it is rare to see a really beat up vehicle. A few stake bed trucks coming in from Mexico is about it. They come up and get a load of old appliances or tires and head back across the border. They still have the old Freon down there to recharge that 25 year old reefer. Then that is a whole different subject.
The automotive writer for Road & Track magazine, Peter Egan, drove a ('88, if I recall correctly) PA to keep the road salt off of his newer cars. He lives in Madison, WI. His Buick was a several years old low mileage car, in excellent condition, when he bought it, and he got a lot of good use from it. He used to refer to it frequently, in a very positive way, in his columns, but since he hasn't mentioned it for a while, maybe he sold or traded.
It would be difficult to enforce a law against vehicles that required all kinds of subtle interpretation. If you look at the cars on the website I posted, there's really no DOUBT what they are.
IOW your "beater" is what you drive to keep your Corvette or Porsche out of the salt
and slush.
Driving a structurally or mechanically dubious car in winter conditions is even less advisable than doing it in good weather
We always have to remember that there is no such thing as a honest, ethical politician. Try to find one and google their name and you will see they are not honest or ethical.
However if a car is unsafe we do have laws on the books to cover that. They simply tend to mot be enforced. I saw a 2006 Toyota mini van at Lowes Monday running on what looked like slicks. If it had rained there was no way that car would have been safe.
That could make sense in states that have an annual inspection. However, some states, like Maryland, only make you get a car inspected whenever you buy a used one. My 2000 Intrepid, for example, has NEVER been inspected, because I bought it brand-new. Sure, I've had my mechanic look over it and tell me if he sees anything scary, but it's never been in for anything government-ordered. And if you get a car handed down to you by an immediate family member, such as your mother or father, it doesn't need to be inspected either. For instance, my '85 Silverado, which was my Granddad's, got passed down to my Mom and then on to me, and it never got state-inspected, although I've had my mechanic look over it.
Now if a cop sees you running around with a burnt-out headlight or taillight, you might get pulled over. And if your windshield is cracked/busted badly enough and you get spotted, you'll also get pulled over and get a warning. And I'm sure if you drive around actually missing a body part, like a hood, door, etc., they'll get you.
But if you're riding around in a rusty piece of junk that's more bondo than metal, on bald tires and non-existent brakes, I doubt if they're going to do anything unless you actually get into an accident. For example, if you wipe out in the rain or get stuck in the snow and a cop comes on the scene and sees that your tires are worn down to racing slicks, you'll probably get a ticket.
Evidently though, for not having annual inspections, Maryland is pretty strict. I bought a 1979 New Yorker from a used car lot in West VA back in 2001. Not the NYer I linked above, but this one instead. The seller guaranteed it to pass if I registered it in PA, West Va, or VA, all states that I believe have an annual inspection. However, he said that in Maryland I'm on my own, and good luck! :sick: Fortunately it didn't need much to get it to pass. One tire, some adjustments to the steering/suspension, and new rear brake shoes. And the obligatory headlight adjustment.
But you are corect that most other types of infractions will never be caught by the authorities in California, which is why I am so in favor of Shifty's new law. Perhaps in states with a regular visual and safety inspection it is a non-issue.
I particularly remember friends getting tickets for exhaust systems that were too loud when I was a kid in LA, and I know you would never get that type of ticket these days even though the number of coffee-can exhausts out there has just exploded in the last ten years.
By better you mean more frequent and I'm in agreement with that. In NH and ME I have been stopped and issued a ticket for defective headlights or tailights. There is no fine if they are fixed within 10 days.
I once bought a new Saab and was mistakenly issued an inspection sticker that expired in December instead of the same month that my plates expired. Believe it or not a Trooper who passed me on the highway noticed this and issued me a warning. I guess that's a "benefit" of living in a low-crime state.
Let's see---the 3 biggest car-owning states are probably California, New York and Florida (or would that be Texas instead of NY?). Do they have safety inspections? I know California does not.
Naturally we can't have laws based strictly on "aesthetics". You can't get a ticket for an ugly car. (Relax all Aztek owners!)
Texas might have more vehicles on the road but they don't move more new metal.
New York does have some kind of Annual inspection and I have seen their stickers for that but not sure if it is mainly emission related or has anything to do with safety.
I don't think Florida has any type of annual or biannual inspections of any kind.
Also, there should be a special patrol in each state assigned to Consumer Vehicle Enforcement like they have Commercial Vehicle Enforcement. These patrols are special and not just a general police officer. They have special training for their field so they know what to look for and can actually identify the vehicle they pulled over. I have seen many police officers not even be able to name the most common cars they are pulling over. Random roadside safety inspections should be placed in all states like they do for DUI checkpoints. Its a great state revenue generator and will send a clear messege. Fix your car or lose it!
I'd have to support a law that would take exceedingly ugly vehicles off the road. They'd have to let me decide ugly, though. I mean an Edsel is ugly but that's part of its charm. You never hear Aztek and charm in the same sentence (well, except for right now).
I thought at one point there was such a law. SOMETHING had to happen that all the Citroens disappeared.
When I last lived in NY the annual inspection included safety items as well as emissions. There were plenty of beaters on the roads there so it was apparent to me that you could "buy" a sticker. :mad:
He continued to drive it that way for awhile, and the real cops never did anything. However, the campus police where he attended college gave him some kind of ticket for that bumper and it stated that he had to either get it fixed, or they'd tow him if they ever saw his car parked there again.
I think that was when he finally decided to get rid of the car. It really was looking like a beater, too. In fact, on his way to court for the first accident, driving that Cordoba, he got sideswiped by a Nissan Pathfinder that tried to run up over him! From what I heard it gouged out the Pathfinder pretty good, and nearly tipped it.
Years later after he got rid of it, he saw his old Cordoba, abandoned along a road somewhere. The bumper was still shifted off to one side, jutting out.
Oddly, he ran across the abandoned carcass of another one of his cars a few years ago. After the Cordoba he had a '78 Newport, and then an '82 Cutlass Supreme sedan. It had three Oldsmobile wire hubcaps and one Chevy rally wheel, like what you might have seen on an '83 Malibu, Monte Carlo, or S-10 pickup. He got like $600 trade-in on it when he bought a '95 Grand Marquis in 1999, and then I guess they wholesaled it off. A few years later he saw it abandoned along the road, no tags, windows broken out...and still with that mismatched Chevy rally wheel!
Until 2006. That year I went up for the Mopar Nationals alone, in the NYer. Came home Saturday night, late, instead of staying through Sunday like I normally would. Forgot about that danged headlight. And sure enough, about halfway home, in Thurmont, MD, a cop pulled me over!
I just made sure to turn the engine off before he got out of the car and approached me, so that he wouldn't hear how loud it was running!
Well if you had the bad headlight, a bent bumper, no muffler AND some duct tape, you might have qualified as a BEATER OWNER and subject to our draconian regulations.
And while I still don't have a muffler on it, I do have the catastrophic converter...so it's not polluting any worse. Oddly, I get compliments on the way it sounds. People either think I put some big-block under the hood, or some other performance mod. And I guess you could argue that it actually benefits society, because it has a nice deep rumble that easily drowns out those little cars with their fart-can exhausts. :P
