Toyota Avalon Rain Sensing Windshield Wipers
Does your Avalon LTD rain sensing wipers make one swipe across your dry windshield when you hit the start button on a dry day when your wiper is set for auto?? Will if your dealer says this is normal he is wrong, report this to Customer Experiance at 800 331 4331 and ask to talk to Eileen Torres (Case Manager). Toyota Avalon's XLS fron 2000 to 2004 with rain sensing wipers did not have this defect, it only started with the new model in 2005. Toyota says no one has reported this problem but my self and that they do not intend to fix it with only one complaint. So if you have this problem please report this to Toyota Custumer Experiance and directly to Eilenn Torres (Case Manager)
So besides setting them to "auto", make sure you have the lever in the correct position also.
, it worked for us.
Although I was having the same problem as you when I had the car for a few days, it's the wife's car and I'm rarely in it lately. I forgot exactly where the problem was for me.
I had the placement of the lever "bumped" on low instead of auto. The velocity setting was also set to lowest point.When you started the car, the wipers went on once. Even if the windshield was dry. Because of this setting, it was still wiping across every now and then but EXTREMELY intermintant. I still thought I was in "auto" but just unfamiliar with this new car.
At any rate, the car was home today so I got the water hose out and checked it. I placed the lever in "Auto" Stopped and restarted the car. No windshield wiper movement. To make sure it worked, I sprayed the windshield and the wipers started working fine.
If you're pulling the "lever" down and counting the settings to find "auto". the first setting "up" doesn't hold so a person could easiy be off by one setting.
Perhaps yours is just a faulty unit or maybe you unknowingly have it on the wrong setting as I did. As I said, today I tried it in the driveway. When set to auto, they work perfectly and do not come on when you start the car or untill it senses water.
One way or another, this should be fixable as you shouldn't have that problem.
I'm already much happier with the 08's wipers.
My reasoning: high humidity levels may trigger the system. Possible solution: decrease the sensitivity of the windshield sensor. I haven’t done it though, since, as previously stated, this behavior has occurred only a couple of times since last September.
Also make sure that nothing is touching the sensor (attached to the windshield).
Amaury
’08 Limited
I have had since 2006 a 2006 Avalon Limited and I have experienced the magical wipe of the wipers as described here and got the same BS from Toyota. It is a problem and has ruined many a wiper. I decided tonight to disconnect the rain sensor. Quit easy. carefully pull down on the back cover closes to the sun roof... latches next to the top of the adjoining cover. When that comes off then pull the horizontal plastic lock for the other cover and rain sensor assembly towards the windshield from its place on the front of the rain sensor. Now carefully wiggle the sensor off its windshield mount by pulling from the end closes to the sun roof.... do not put your fingers on the sticky clear tape under the sensor attached to the windshield. Now push the tiny little clip on top the wire connector in so you can disconnect it. Leave it disconnected and reinstall in the reverse order. No more magical random wipes.
I am in AZ and it seems to malfunction mostly when it's hot.
Wipers have also just come on for no reason when I am driving.
I just turn them off and have to remember to turn the on when it may rain or it's starting to rain. I do like that they generally will pace the rain, so I don't want them disconnected.
Dealer told me there was nothing wrong with them and that no other complaints had been made.
I take it by this thread that after all these model years, the problem has not been addressed by Toyota.
