Taurus/Sable Squeeks, Rattles and other Noises
I have a clunking noise in the front of my Mercury Sable 02 and I replaced the struts and the upper baring mounts but i still have the noise that sounds like its coming from the front of the car....anyone know what might be causing it?
Thanks for your Time
$500 + labor back in 2004.
My shop told me it is the lower ball joints. I don't believe him because I put the hole front end on jack stands, got a crow bar and pried on all suspension connections looking for something lose and found nothing.
My car also has the skwealing noise when the wheels are turned all the way either way. It is some problem with the power steering valving or pump. It has been doing that for ~10k miles but still steers OK. I had the power steering fluid and filter changed but it didn't help.
