Kia Rio Engine Problems
neanderbob
Member Posts: 6
Very occasionally, as in 6-7 times in 18 months our 2006 Kia Rio 5 (manual trans) has experienced a sudden 2-3 second loss in engine power. It feels like the ignition is suddenly cut and the car decellerates quickly, not really dangerous on the highway where momentum and 5th gear keep you rolling, but around town in 2nd or 3rd gear it's certainly a big surprise for anyone following too close behind you! If in a high gear like 3rd, 4th, 5th, if you just leave the clutch engaged the engine will restart within seconds as vehicle momentum keeps the engine turning, if in a low gear you are forced to disengage the clutch, the engine will stop, but banging the clutch back out will "bump start" the car immediately. We really like this little car, besides this and it's reluctance to go into reverse it's been tremendous. Thanks for reading, anyone have info about this power loss?
I have two plugs that I do not wknow where to put, one has a single brown wire going to it, and the other has a dark blue and red wire going to it. they are both located in the front passenger side of the engine department.
btw this is in a 2007 kia rio with automatic transmission, but it should be very similar in most of the 06's. please somebody take a quick look in your car to see where these go, i really need the help!
RIO in DISTRESS :sick: :
So, the timing belt broke in the middle of traffic and the engine is now blown. Our mechanic checked around to try to find a new engine and because the event happens so often and many are needed, an engine was not to be found, new or rebuilt. Besides, if a new engine could be found, it would cost more than the car is worth.
The paint is also fading to the point that the primer is showing.
Does it sound like I might be a little put out? You bet. So I am going to tell as many people as possible not to buy a Kia of any kind because they are hunks of junk. My family has had 2 generations of Fords and we currently have a 1991 Ford that is still running and the timing belt has never been an issue and the maintenance has been minimal.
From now on I am buying American Cars (any one want to buy a Toyota?) and my next car will be a Ford. Save yourself. Don't buy a Kia and if you have one, sell it before it's too late.
I connected a Jump Box for about 5 minutes, resulting in no starting problems for the rest of the night. This morning the dumb thing would not start again. It sounds like the Starter is not allowing the engine to turn over. The battery looks brand new and AutoZone does not show any codes.
Could I have disconnected something when I pulled the dash assembly out? If so what could it have been and how do I disassemble the dash to get a look at what needs to be connected? Could it just be a coincidence as far as time and the problem just is that I need a new starter?
R/iank1
P0300 Random/Multiple Cylinder Misfire detected
P0303 Cylinder 3 Misfire detected
P0507 Idle Air Control /system RPM higher than Expected
P0171 System Too Lean Bank 1
What does all this mean and are these fault something that can be fixed by myself.Or do i have to take it to a Specialist
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
unable to get through inspection, it fails OBD 2
Code of 496 comes up
Other than the drive cycle needing to be reset, (have driven it 1500 miles),
does any one know what needs to be fixed so that it will pass inspection.
thank you
If you just do city driving, go for a 30 minute drive on the freeway. I don't know how much the KIA RIO fuel injection engines carbon up from just city driving, but my (then new) 1986 Nissan 720 pickup sure did.
You can download any Kia owners manual from KGIS and its free.
