1999 Isuzu Rodeo Shift Lock Control
Does anyone know how to fix the shift lock control on a 1999 Isuzu Rodeo. I usually have to rock the car a bit to get the shift lock to release in order to put the car in gear (automatic). The other work around is to start the car in Neutral.
I took the cover off the steering column by removing 4 screws. (I had to remove the dash by removing 2 screws behind the Hood release and yanking the cover off. This is how i gained access to the two forward most bolts on the steering column cover.) From hear I can see the shift interlock on the top right of the sterring column. Pull the white lever to release the key lock. Turn the key to lock and remove your key.
Now i need to know, how to adjust this shift interlock so that i do not have to manually move the lever in order to remove my key or shift my car from park. Help?
Its a simple fix - you just need to put your right hand underneath the dash, under the ignition switch with the stuck key, and feel around for the stiff transmission-shift-lock cable, and just giggle it about a bit. Try all directions, don't be aggressive with it; and eventually you will be able to turn the key to the LOCK position. Good luck
