Have you recently used your tax refund (or are you planning on using your tax refund) toward the payment of a new or used vehicle? Or, are you planning on using your tax refund toward any expenses related to your car?
If so, a reporter would like to talk to you. Please reach out to [email protected] by Friday, January 25 and the Edmunds PR team may connect you with the journalist.
Are you the parent of a generation Z child (born in the mid-1990s to the early 2000s)? Do you have differing opinions on the importance of buying a car, what types of vehicles you're interested in, or just how you view cars in general? If so, a reporter would like to speak with you and your child. Please reach out to [email protected] by Friday, January 25 and the Edmunds PR team may connect you with the journalist.
Subaru Forester Air Conditioning Problems
2»
  • mjb59mjb59 Posts: 1
    The AC on my 2009 Forester (58,000 miles) quit working. The compressor makes a lot of noise (rattles) when the AC is turned on. I took it to the dealer and was told I had a clog in the system. They said the rattle was due to the compressor pulling vacuum on the low side and that pressure on the high side was over 200 lbs. I was told there was no way to find the clog and the only sure way to fix it was to replace all components in the system. Total cost around $3,000.
    I would like to know if there are any other options.
  • dahs10dahs10 Posts: 6
    I had another problem with my a/c this summer. When I would drive on the interstate with the a/c on and then get off, the car would overheat. I just had the head gasket replaced 18 months ago so I didn't think it was that again. I took it to an awesome mechanic and discovered the connection to the second fan was not working properly. He fixed that at minimal cost and now it works perfectly.
  • aathertonaatherton Posts: 617
    "The AC on my 2009 Forester (58,000 miles) quit working. The compressor makes a lot of noise (rattles) when the AC is turned on. I took it to the dealer and was told I had a clog in the system. They said the rattle was due to the compressor pulling vacuum on the low side and that pressure on the high side was over 200 lbs. I was told there was no way to find the clog and the only sure way to fix it was to replace all components in the system. Total cost around $3,000."
    This does not sound right. In 5 decades of car ownership I have not heard of a "clog" in the AC system. Also, being unable to find the problem, and needing to replace the whole system, and the cost of $3,000, all sound wrong. It is well worth seeking a second opinion from another dealer or a good independent shop.
  • ateixeiraateixeira Posts: 72,587
    I can imagine debris causing a clog, but the price sure does sound high.
    Funny thing is they usually leak...
    Over the years on various cars we have had such problems as a plugged evaporator drain, intermittent cooling, minor refrigerant leaks, an untended leak where loss of refrigerant and its lubricating properties ruined the compressor, and a couple of failed compressor clutches. But no clogs.
    I had a leaky compressor on a '91 Ford Escort GT.
    I was mad because the A/C was a $460 option, but fixing it cost $700 at the time. And I had just serviced the A/C the year before.
    The shop gave me a break and didn't charge me for the freon the 2nd time.
  • Hello, my Forester is doing the exact same thing and dealer recommends head gasket replacement. Can you tell me exactly what second fan connection was not working properly on your car? What is the "second fan" and where is it located? Thanks very much - you might save me a ton of money!
    The second fan is located on the passenger side of the car at the very front right behind the headlight. Good luck
  • My AC in my 2009 Forester started blowing hot air about a year after I bought it (bought it in July 2008). I took it to the dealer and they couldn't find a leak but did replace what they called a Shrader valve on it and they put more freon in it and it worked pretty good for 2 years. Now I have about 72,000 miles on the car and it stopped working at the beginning of the summer. Didn't take it to the dealer because it wasn't under warranty. Took it to another garage and they said that my compressor made a lot of noise and the pressure was off on it and they quoted me about $700 to replace the compressor. I actually found a used one and had another garage put it on and paid about $400 total. It worked for about a week and half and now all the freon is leaked out again. The garage that put the compressor in thinks it is something else. I believe this all stemmed from the first time I took it to the dealer. I think they give you outrageous prices I know that when I talked with them about the compressor they said it would be between $1200 and $2000 to fix it. I am emailing Subaru because I keep being told by mechanics that this should not be happening on this new of a car.
  • baires60baires60 Posts: 30
    WOW that is a new car practically, my car 2010 subaru forester had a problem and blew hot air at the beginning of the summer - I took it to the dealer and they said they found a leak and replaced the evaporator? Whatever it was, they needed to wait for a part to fix it. It works great now but after hearing your story I am waiting to see what happens in a couple of years, I got the extended warranty so I guess if it does happen again I am covered either way - well as long as it's not over 70K or 7 years old. I don't like it when things that major already go out within the first 15 months of a car's life.
  • arcana1arcana1 Posts: 1
    I had the same problem but had it fixed at the dealer yesterday. The mechanic told me it was rust on the clutch plate.. He showed me what he did. You move the fluid bottle out off the way, then remove the cover plate that protects the belt.
    Here is the best part, you spray WD-40 or similar onto the clutch plate and in between the compressor and clutch plate.
    Put the cover plate and bottle back in place.
    Worked like a charm
    Another dealer quoted $1500. for the fix. this dealer charged their minimum 1 hour labour but anyone with a socket set could do it themselves.
  • Hi,
    My 2009 Subaru Forrester is having related problems - whenever I turn on the front window defrost, fuse #22 blows. I took it to the dealer and they told me I need to replace the compressor, cost = $1000.
    Seems like too young of a car to have this kind of issue.
    buummer :(
  • techmarcomtechmarcom Posts: 1
    I have a 2004 Forester with 146k miles. The AC words at the start, but after running for about 15-45 minutes, the air stops being cold. If I turn it off for about 5-10 minutes, I can turn it on and have cold air again.
    Just got it recharged the other day, but noticed the problem again this afternoon.
    Anyone else experience this? Any ideas? I'm not about to sink $300 into an AC repair with this many miles.
    Perhaps the refrigerant is leaking out of a bad seal. Low refrigerant can cause intermittent cooling as the compressor loses and regains suction. And maybe turning off the AC for awhile can allow what refrigerant is left to drain back to the compressor.
  • quark613quark613 Posts: 5
    See my previous posts #14, 16 and 25 - this sounds an awful lot like what was happening to me. Turned out to be the a/c clutch - replaced in 2010 and haven't had a lick of trouble since.
  • nanasarananasara Posts: 1
    I have a 2006 Forrester with well over 100,000 miles. Car still runs great, but the A/C only blows on auto setting. Air is cool, but not as cold as we would like and takes a long time to cool passengers in the back seat. Last summer was so hot here in Texas and it was almost unbearable. Any idea what the problem could be? What could make it only work on auto setting?
  • chawkfan71chawkfan71 Posts: 1
    edited July 2012
    I own a 2011 Forester with 10,000 miles. Since day one of running my AC the compressor makes a chirping noise when it releases. The faster the speed the louder it gets. I have taken it in to be serviced two times and I keep getting told that this is a normal noise for this model. Just wondering if anyone else has this problem??? I have been in other Foresters and didn't hear this noise.
  • xwesxxwesx Fairbanks, AlaskaPosts: 12,460
    I've never heard a chirp in mine. I have a 2010 Forester.
    2014 Audi Q7 TDI, 2008 and 2013 Subaru Forester(s), 1969 Chevrolet C20 Pickup, 1969 Ford Econoline 100, 1976 Ford F250 Pickup
    edited July 2012
    Our 2009 2.5i Limited's HVAC is also quiet.
  • I own 2011 forester since oct 2011. After a few weeks of using my AC and it sounding normal, it started making a LOUD click and a LOUD buzzing noise by the compressor (buzzing lasts from 3 to 10 seconds) when I would first push the AC button to turn on the compressor. It sounds the worst first start up of the day or afterthe car sits for a while. After it males that noise and while it's running it sounds and works normal.
    I brought it to Subaru service and they said it sounded normal as they compared it to another 2011 Forester.
    I know it is not Normal. If it was it would have sounded like that from day one. It is also starting to get worse.
    Does anyone else have this problem?
    Can anyone tell me what they think can be slowly going wrong?
    However it does not make a constant chirp noise like yours. I'm suspecting yours is a belt or pulley problem.
  • mithrasmithras Posts: 2
    I have a 2005 Forester (89,000 miles) with the same problem. It is, apparently, not unusual.
    The A/C clutch is burned and slips when the engine and/or the clutch gets hot. A new compressor/clutch is required. The clutch cannot be repaired or replaced by itself). Price from local Subaru dealer: $649, plus $9 for a replacement bracket. That's without labor. Total price is "around $1,200."
    The best price from a trustworthy local independent garage: $918.
    My Subaru dealer says the $9 bracket is the cause of the problem.
  • jebrown9jebrown9 Posts: 1
    The XT I bought new in June '03 now has 84K miles. I've loved nearly everything about it except for the HVAC system. The A/C has never been powerful. I think the problem is that even when the A/C is OFF, and even when the temp dial is all the way to the cold end (i.e. heat is completely turned off), this system still warms the ambient outside air by about 5 degrees. If the air outside is 72 degrees, then the air from the dash vents is 77 degrees, and so forth. When the car was new and under warranty, I asked the dealer to find out why. They reported that everything in the HVAC system was running correctly. Long story short: I still have the exact same problem: The system always heats the incoming air by about 5 degrees. Result: I have to run the A/C more than ought to be necessary, and it also reduces the A/C capacity to cool the interior on really warm days.
    My guess is that a damper in the system that is supposed to blend air from the heater core with air from outside is not completely closing when the head dial is completely off, so that some heat is always flowing.
    Has anyone else with a 2003-2006 Forester had a similar problem? If so, has it been corrected, and how?
  • The central dashboard vents on my 2010 with 37,000 miles blow cold air from the passenger side vent but warm air from the driver side vent? These vents are side-by-side yet one blows cold and the other warm? Result is the car interior never gets cool.
    I opted for the dealer replacement of the A/C unit. Cost: $1,045, including dealer rental car for the day. Ridiculous, but done -- thankfully -- before the recent 90+ degree weather. Here's hoping the replacement lasts eight years.
  • robert142robert142 Posts: 18
    only works on unlock. have to manually lock. dealer wants a lot of $$ to replace with a new one. my friend says that it could be micro soldered as a fix.
    anyone else have this problem....and if so what did you do?
  • bell15bell15 Posts: 1
    I have a 2005 Forester. I had to have the engine replaced. Following this, the air conditioner broke. I have had it in twice to have the freon changed and tested for leaks and it still blows cold and then shuts down. This seems to be a common problem for Foresters and I'm interested in the range of remedies that seem to be offered here. I have never had air conditioning problems before with any car.
  • If you ARE hitting your high-pressure switch and the compressor keeps cutting in and out, you need to let out a bit of refrigerant as it's overcharged. Just press the nozzle in on the Air Conditioner line above the intercooler (or the one you used to recharge the system, usually along the firewall). Let out small, short bursts until it stops cutting in and out. Some people will get all crazy if you do this (and that I'm even recommending it), claiming you are ruining the environment and so on, but like I said, it's no different than having a leak or getting in an accident where it breaks a line. Plus, most shops do this as well if they overcharge it.
2»
