Dodge Ram Long Term Storage
I have a 2001 Dodge Ram 1500 SLT 4x2 with 88K miles that I put in a government contracted storage facility because I got stationed overseas for four years. The truck has the following items checked at least once a month: move car, tire pressure, all fluid levels, engine run, a/c & heat, lights, gauges, horn, engine coolant. I want to make sure the truck is in top shape shortly after I take it out of storage. What should I do to the truck after I pick it up this summer? Thanks!
You may also want to think about new tires fairly quickly. Even if they're not flat-spotted, they are not getting much use and could be cracking or dry-rotting.
kcram - Pickups Host
