2009 Subaru Forester
1596062646575
    Gimme plain-old matte black, unpainted plastic trim, any day.
  • kurtamaxxxguykurtamaxxxguy Member Posts: 1,798
    It's certainly possible to use good quality colored plastic, with a clear coat.
    But that does cost a little more, and unfortunately Subaru chose to use paint only this time around.
    Once my trim gets fixed I'll research an autoshop repainting all the interior door rests and transmission center plate with a clear coat protective film.
    That's how my Sienna is - clearcoat over the pluminum trim.
    I still prefer plain ol' unpainted plastic.
  • froggy3froggy3 Member Posts: 5
    When I purchased my 2009 Forrester 2.5X MT, two months ago, I thought getting a permanent all wheel drive 50/50 system.
    Apparently not, as in snow driving the rear end fishtails during turns!!!
    As a test, after lifting the rear only (car in neutral and no hand brake), I can freely spin the back wheels, while the front wheels remain still.
    Needless to say I will schedule a visit to the dealership repair shop ASAP!
    My points/questions are:
    a) Others may be in the same situation, so be forewarned.
    b) Is there a better/easier way to check if this specific AWD system is working or not?
    c) Feel free to shime any ideas, comments, questions.
    Froggy
  • sgloonsgloon Member Posts: 323
    Froggy,
    I'll be looking for your update!
    Mine does the same thing. It is my first AWD, so I had thought I was told it is suppose to do that, fish tail on turns, especially under any slight amount of acceleration.
    Yup, mine ('09 XT limited) does the same.
    On ice, if I gun the throttle, it _will_ throw its rear end out or spin.
    Foresters are supposedly FWD biased, but this one clearly isn't.
  • billwvbillwv Member Posts: 48
    Subaru U.S Sales up in February
    http://www.msnbc.msn.com/id/29493414/
    Bill
    The fact that it's fishtailing tells you that power is being sent to the rear wheels. Your AWD is working fine.
    Bob
  • barneyapplebarneyapple Member Posts: 10
    Brake before you enter a corner: Smoothly apply your brakes before you reach a corner and then release the brakes and use all the grip of the car to corner. Then, once you are through the turn, accelerate out. "Enter a corner with too much speed and then try to adjust in the corner and you will lose grip," warns Pearl. When the wheels are braking, their surface becomes static and they can behave like four hockey pucks and can move multidirectionally (that is: spin). If that happens, you will likely lose control of your vehicle. http://www.edmunds.com/ownership/howto/articles/45193/article.html
    i'm guessing it is best not to accelerate until you are thru the turn. not while turning.
  • saedavesaedave Member Posts: 694
    But it does bring up the question of the torque split. My Outback 3.0R with 45%/55% F/R initial torque split will fishtail with careless throttle application. I wonder whether the 80% front 20% rear split of earlier 4 cylinder auto trans models has been changed?
  • xwesxxwesx Member Posts: 16,789
    I found that the '07 and '08 Outbacks I owned would kick their rear ends out with far more ease than my '96. I liked this trait, as it made the cars much more controllable than the '96. The prime difference in their rear axles was the presence of a limited-slip differential in the '07 and '08. Yes, there was more torque going to the front wheels, but if I goosed the throttle, I could apply enough torque in the rear to spin the wheels.... and if one spins, they both spin, meaning that the tires work together to slip the car in the direction of momentum.
    It was very enjoyable - I loved tossing those cars about. ;)
    posted earlier but might explain driving behaviors - info from Subaru Canada:
    The Forester does not have a Variable Torque Distribution (VTD) centre differential. For the 2009 model year, the Forester 2.5XT includes a Multi-plate Transfer (MPT) System that adjusts torque from 60/40 (F/R) to 50/50 (or anywhere in-between) depending on throttle input, road conditions and input from the Vehicle Dynamics Control (VDC) System. VDC operates like most electronic stability control (ESC) systems in that it can adjust engine output, adjust individual brake pressure and even front rear torque distribution to retain/regain vehicle stability.
    It is not possible for the system defeat the role of the centre differential and thus torque output will always be split between the front and rear differential. Meaning, the system cannot direct 100% of power to a single wheel - whether it be with VTD or MPT.
    Note this differs from older Foresters' usual 90 -10 split between Front to Rear.
    However, what happens when both front wheels slip, and the Traction control system brakes the front wheels to help transfer power to the rear wheels?
  • bigfrank3bigfrank3 Member Posts: 426
    Well, Bob is of course correct. If there were no power to the rear wheels it wouldn't fishtail like that. And yes, vehicles with a limited slip differential or the electronic equivalent are more prone to this that those with an open rear axle.
    AWD and limited slips only manage torque distribution based on traction, but not the amount of traction. If there is no traction or if you overpower the traction available the wheels spin. And if the car is pointed into a turn and this happens in the rear it will fishtail because of the force vector. You will notice that it always fishtails to the outside of the curve never the inside. It is the whip effect caused by the car being pulled through a curve and then the rear not having any or not enough traction.
    In the old days we used to play with this on our muscle cars with limited slip. One of us would get the rear wheels spinning and then another of us would gently push the rear of the car in one side direction or the other. It is amazing how easy it is to almost rotate a car around a circumference with the front of the car stationary and the center of the circle. We could even do this on bare tar, no rain or snow needed. You can't do this with a vehicle with no limited slip because with 1 tire overpowering the traction you still have 1 tire with traction but no torque so the vehicle is anchored by that wheel.
    Any amount of torque applied to the end with poor traction will cause this. I am sure some have experienced a FWD car with no traction, and while the front tires are spinning the front "walks to one side or the other depending on the torque application design of the powertrain. No traction is no traction so other forces take over.
    Even if the rear of the Forester is only getting 10% or 20% of the torque it is still the much lighter end. The front has a lot more weight over it and therefore more traction available, even with the bulk of the power. I have mentioned this before but the solution is easy. You need more weight over the rear axle so that end gets more traction. I discovered this by accident when I happened to go buy some big bags of bird seed, but sand, cat litter, or anything that can be put against the seatback over the rear wheels tremendously lessens this effect. The rear wheels have torque they just need traction.
    The torque split of 60F/40R is given for the turbo model. I wonder if normally aspirated Foresters are the same.
    As another comparison my previous Passat W8 4-motion (quatro) did not fishtail even with max throttle. However it often ploughed instead. :( I prefer my 3.0R's behavior, but Consumer Reports calls Subaru VDC response "reluctant".
  • board_jayboard_jay Member Posts: 22
    About 6 weeks ago I started noticing this smell when I got into my Forester in the morning to go to work and again at night when I came home. It is hard to describe, but sort of a sweetish smell that is kinda revolting. Does not smell like rotten egges. Here's what I know
    1. Seems worse in front of car near dashboard.
    2. Nothing leaking (not radiator fluid)
    3. Took apart dash and heater core hoping to find a dead mouse or something. Nada, no dead animal.
    4. Smell gets better and goes away when heater/fan is turned ON. just in case, had dealership spray that anti-bacterial stuff they have for mold in vents. Didn't help, still smells.
    5. Smell gets better/goes away when temp is below freezing and gets worse when
    above freezing. Obvious that something is freezing and then thawing.
    6. I have kids and removed their carseats. Still have the smell. No obvious places where I can see split milk or anything like that. Nothing under seats, in obvious spots. I can't find anyplace where the smell is obviously worse in one place vs. another other than seems worse in the front of the car.
    7. Just in case for #6, I used lysol EVERWHERE 2 weeks ago. Still have the smell.
    8. No smell from under the hood or under the vehicle, just inside.
    At this point in time I am getting ready to dump this car and not buy another Subaru. I love the Forester, but can't subject myself and my kids to this. I have had 20cars in my life and never had this problem. Any ideas before I bail?
    Try running your defrosters at full output at maximum temperature for a few minutes (roll windows down or open moonroof if it gets too hot), and see if a greasy deposit builds up on windshield.
    IF so, you may have the problematic HVAC gasket problem referred to earlier in this thread, and covered by a Subaru TSB.
    That sums it up pretty well.
    Try this...
    First off, be careful, make sure you have a gigantic and empty parking lot with tons of space, wear a helment, bla bla bla disclaimers.
    OK, take a turn in a snowy parking lot and stay on the gas.
    When the rear end begins to fish tail, and this is the important part...*stay on the gas*.
    Don't add throttle, but don't let off the throttle either.
    Let AWD do its job. It should slowly shift power to the front axle when the rear axle slips, and the FWD bias should pull you out of the skid. This is also the best way to ensure that your AWD system is functioning properly.
    If you lift off the throttle, the weight shifts forward, that means the rear axle has zero weight on it, and the fishtailing only gets worse.
    The stability control can't do anything if the rear axle has no weight on it and therefore no traction.
    I know it sounds counter-intuitive, you begin to fish tail and you stay on the gas? Yep.
    There's even a word for this: drop-throttle oversteer.
    Practice in that safe environment and learn how the vehicle reacts.
    If you get good at it, this is the most fun you will ever have in a Subaru.
    Let the AWD do it's job.
  • oregonboyoregonboy Member Posts: 1,650
    People seem to be using the term "fishtail" to describe a state of oversteer, as when the rear of a vehicle swings wide in a turn. I believe this to be wrong. Fishtailing is a back and forth motion. Have you ever seen a fish swing its tail just to one side? :P
    "fishtail." Merriam-Webster Online Dictionary. 2009.
    fish·tail (fis̸h′tāl′)
    intransitive verb
    1 : to swing the tail of an airplane from side to side to reduce speed especially when landing
    2 : to have the rear end slide from side to side out of control while moving forward
    Yeah, I'm picky. I just hate to see the language misused. :shades:
  • orcorc Member Posts: 39
    Fish tailing when accelerating from a stop around a corner is what rear wheel drive cars will do on very slick surfaces. Our Forester with stock all season tires does the same but most front wheel drive only cars won't. It's one reason I believe front wheel drive only cars are best for most folks in everyday commuting and going to the store applications. Four wheel drive comes in handy for rough and steep dirt and gravel unimproved roads and plowing through heavy snow. Folks with steep driveways living with bad winters appreciate 4WD. There are some misconceptions about AWD or 4WD vehicles and for the most part front wheel drive only is all most pavement pounders need. JMO.
    Yep... it's not really a fishtail but is it really oversteering? How about just "Losing traction and sliding sideways." LOL Rear end breaking loose? I know what folks meant when saying fishtailing - no biggy.
    This isn't always possible, such as accelerating from a stop and having to turn the corner right away. Even a very slight acceleration has caused the "fishtailing". Which in my car, as correctly pointed out above, is the rear end breaking loose to the outside corner, typically.
    I definitely don't accelerate on the corners on the mountain roads though, unless I need it for grip, that is another story.
    Also, in my experience with front wheel drive vehicles (all I've driven until now), I can gain more control with a little acceleration if the car starts to slip (and turning into it). At this point, I don't think this AWD vehicle will be able to do that. I'm not sure if it might fishtail more??? But, I'm heading up to the mountains with a different 09 Forester this weekend, with 10 - 22" of snow predicted, So, I might get a chance to see how a different car behaves. That will be the real test for me. Hope the trip doesn't get canceled
    Not all FWD is just for pavement. My old FWD Subie could go EVERYWHERE! It was fantastic. You wouldn't need 4WD with that vehicle, it handled snow, mud, and 4WD roads up to the level of it's road clearance, which was pretty good. And I had to have the "right" tires on the car - which came with it as original equipment. I loved that car!!! I never once got stuck, though other cars did in places I went...
    Now, I know not all FWD vehicles would behave like the old Subie, it was just Fantastic!!! And perfect for me!
    Sounds like a good tip, Juice.
    And definitely counter-intuitive. But makes sense the way you explain it. I will try it!!!
    I learned how to drive on rear wheel cars. And, my car before the 09 Forester was a 2 wheel rear drive pick-up -- talk about spinning out, it was useless in snow.
    You just have to get used to how the AWD handles.
    Once you are used to it, you will realize the amazing capability, and fun, driving in snow.
    Love this car!
    Bill
    If not that, you say it is a "sweetish smell," so what about the possibility of a tiny fracture/leak in the heater core? It may not be noticeable under non-use, but turn on the defroster or heater and that liquid will get vaporized... producing a nauseating, sweetish smell.
  • birdboybirdboy Member Posts: 158
    hello..It is nice to see that my mpg has gone up again. I have 12,500 miles. During last spring , summer and Fall I was averaging 29-31 mpg @ 65mph. It dropped down to 24 during the cold long winter. This weekend with the temps in New york reaching the upper 50's I found that my mpg increased. I have the non turbo 09 LLBean edition.
    I have also had unfortunate luck with the windshield cracking twice. Both times a small stone hit it. I have had many cars during the past 20 years and have never had a windshield crack. Have the windshield materials been economized along with the interior materials?
    More likely is weight -reduced, ie thickness. Another reason for cracking is stress: the windshield can also be a structural element. The new Forester could have such a combination of factors.
    But what do I know? My windshield manufacturing patent (Ford Glass) was granted over 50 years ago. :D
    Knock on wood, but my wife has cracked 3 windshields in her driving career and her 09 Forester is still OK.
    I got my first tiny crack on my 1993 Miata, small rock hit it.
    I don't think it's any worse than the average windshield...it may be more upright but it's also higher up. Unlike my Miata....
  • samiam_68samiam_68 Member Posts: 775
    The glass in 09 Forester is paper thin. Just take a look at a partially rolled down rear tinted window.
  • volkovvolkov Member Posts: 1,306
    A news article and picture from my local paper. Now it seems that Foresters are as dangerous as Audis :-0
    http://www.princegeorgecitizen.com/20090307180023/local/news/parking-goes-awry-a- - - t-mall.html
    Now, THAT proves the effectiveness of Subaru's AWD. Not just any car could climb over a Lebaron! :P
    Yeah, it should be used in marketing...
    Nothing can stop a Forester; it can drive over anything!!!
    Yeah, that's impressive - no front end damage at all. That thing literally climbed up the snow bank and across the top of those cars. If the driver had lined them up better, she probably could have cleared the Lebaron altogether!
    Haha.
    I'm impressed the glass didn't break. The A- and B-pillars are strong enough to support the car in that position without buckling.
    No wonder it aced side crash tests even before it had side curtain air bags.
    I never thought I'd say this, but I'm more impressed by the LeBaron's roof holding up. Isn't that a convertible? Maybe it's just the old Landau, but I don't think so.
    Noticed the unfortunate Subaru's not an '09; might front window glass in '09 be thinner than earlier models?
    Surprising how all three vehicles seem to have held up pretty well from the accident (though we don't see the fronts of the others..).
    I thought the same thing. It does look like a convertible.
    Well, still smells horrible. And I don't have the HVAC gasket problem, no film builds up when defrosters on high. Also, dealer says they have dealt with the HVAC issue on a few Foresters and none of them had any 'smell' issues associated with them. They have pretty much ripped apart the HVAC system and dash and find no dead animal. Nothing in my seats or my rugs. Have deionized the car and now are waiting for a 'cabin air filter' which seems bogus. I mean, how can that do anything? The smell happens when the car sits and it's >25-30 degrees outside and gets better when it's colder and pretty much goes away. It also goes away a minute after you start running the heat. So it seems like is HAS to be a dead rodent somewhere that is freezing and thawing and thus smelling. I have never had this issue in over 20 cars of ownership so wonder where the hell it is and how it got in. Pretty much seems like I am going to have to dump the Forester and get something else which is too bad. It's still at the dealer, 3 days this week in addition to 1 last week. All I can say is this sucks. Should have kept my 01 Navigator, never had any problems other than it cost more for fuel.
    Does the smell come specifically from the HVAC, or does it appear in the car after the car sits for awhile?
    Also, if some smelly residue gets on the cabin air filter, it will stink up the cabin every time the HVAC is used. The filter is easy to replace, though.
    Also check all the hoses and fuel lines to make sure all the clamps are tight.
    Some forums have reported minor coolant or fuel leakage can lead to major odors in the passenger compartment.
    From cars101.com:
    CU explains their reasoning for the change;
    "Although the criteria for selecting a Top Pick is fairly simple on the surface – the car ranks at or near the top of the Ratings, average or better reliability, easily available electronic stability control (ESC) – there are some nuances.
    One interesting choice involves our 2009 Pick for Small SUV.
    When we tested the redesigned 2009 Subaru Forester, it did very well. The turbocharged 2.5XT even outscored the RAV4 V6 and the basic Forester 2.5X outscored the four-cylinder RAV4 at the time. We also tested a group of several manual transmission vehicles including a Forester with a stick; it’s one of the very few small SUVs that offers one. It also scored well.
    So, why isn’t the Forester our Top Pick for small SUVs? Two reasons:
    The RAV4 got a new 2.5-liter, four-cylinder engine for 2009. When we retested the RAV4 for the upcoming May issue, we found that it was improved. It just barely outscored the equivalent four-cylinder, automatic-transmission Forester.
    While the turbocharged and manual-transmission Foresters each outscore the RAV4, those versions sell in comparatively low numbers. The vast majority of Foresters and RAV4s sold are basic, non-turbo, four-cylinder, automatic-transmission versions.
    It boiled down to this: we wanted the Top Pick to apply to the biggest number of buyers out there. In the end, the 2009 RAV4 four-cylinder narrowly out pointed the Subaru equivalent, becoming our Top Pick."
    In other words, Top Pick factors how many people are likely to buy a given vehicle, as well as the absolute value of the vehicle.
    Ow, my head hurts. :sick:
  • p0926p0926 Member Posts: 4,423
    Kurt- I'm glad you posted that because I had just been looking over CR's Annual Auto issue last night and was puzzled why the Forester wasn't listed as the top small SUV pick when it was both the best "Compact Sporty SUV" and "Small SUV"
    In other words, Top Pick considers how many people are likely to buy a given vehicle
    Well that kinda makes sense but by denying the Forester the honor of being a "Top Pick" even though it won thier own comparison tests, they are discouraging (and confusing) potential Forester buyers and at least indirectly contributing to the fact that MTs and turbos are sold in low numbers :(
    -Frank
    $230 can now get you a Turbo boost gauge for the '09 XT models.
    fredbeansparts.com has more details and some prices.
    So instead of choosing the best vehicle to buy, they choose the best vehicle most people will buy. That's something of a self perpetuating philosophy isn't it?
    I made it to the mtns this weekend, however someone else drove, so I didn't get the big test I was expecting regarding driving another 09 Forester in the snow.
    However, the other day it was a little snowy & a lot icy here. I found with this other 09 Forester that the tail end did not slide out at all on pretty much pure ice while cornering.
    So, for the experts out there, Here's my question:
    I was driving the same as I normally would, only difference that I know of is my car is MT premium model and this car is AT base model but with Alloy wheels and Bridgestone Dueler H/T tires. Why would my car kick to the outside corner in snow when this forester didn't do anything on ice???
    Are those Geolanders that came with my car making that much difference?
    Is anyone familiar with these Bridgestone tires? Are the base model tires suppose to be better than the premium tires?
    Still learning about the AWD, so Thanks! for your help! (in advance)
    Although, perhaps it isn't me & the AWD, perhaps it is just the tires???
    The M/T is a 50/50 AWD system, so the rear wheels get a high dose of torque form the very moment you give it gas. That's why the rear on the M/T slides out so easily.
    The A/T is 90/10 F/R, so the brunt of the torque goes to the front wheels initially, while the rears get very little. If the fronts slip, then more torque is transferred to the back.
    I doubt it's the tires, as the Geolanders are decent in the snow.
  • mgagnemgagne Member Posts: 8
    I am not sure about the AT: instead it is 60/40 F/R.
    90/10 is what you get in an AWD like a RAV-4 or others that claim false AWD
    IMO I have to disagree with the Geolanders being decent in the snow. They are better than straight street tread but they are marginal in heavy snow compared to more serious traction tread options available. There are also better tires in the rain. The Geo's are a good average or fair tire for a small SUV - nothing special.
    People have to remember that Front wheel drive pulls the car and rear wheel drive pushes the car. The dynamics are different. Many folks aren't old enough anymore to remember that we all (most of us) drove rear wheel drive cars in the 60's and far into the 70's before the standard was front wheel drive. Folks learned quickly to accelerate slowly when entering a sharp turn at intersections... out of driveways etc. while on slick road surfaces.
    Subaru of Canada, as one poster reported, claimed the Forester AWD goes from 60/40 to 50/50 depending on driving situation. They also said the drive could not transfer all power to either front or rear.
    Then again, various car reviews claim it can send 100% power to any wheel, as the new traction control system can brake spinning wheels.
    So I am not sure what is really going on with this AWD system. But in the last big snowstorm, save for occasional tail lightness during hard acceleration on ice, the XT got around ok and never got stuck.
    Subaru Canada, as one poster reported, claimed the Forester AWD goes from 60/40 to 50/50 depending on driving situation. They also said the drive could not transfer all power to either front or rear. of
    Since previous models of auto trans Legacy and Outbacks were variously described as having 80/20 or 90/10%, that means the new Forester has either a new 4EAT or new software.
    Why the difference?
