Finding it thinner than 1 " or so may be hard.
You can also at these stores find felt strips or sheets, many of which have adhesive backings, that can help
That is what I had to do up in the light housing; position pieces of foam around the cables and connectors so they wouldn't rub against each other or bang into the roof or light housing.
However, it's very good idea to keep foam away from hot items like light bulbs (dome lights get very hot and can melt some types of foam).
2008 Outlander's not tested for side yet.
Also unforgiveable:
1. lousy engineering in GM and Ford cars,
2. bad trannies and sludge in Acura, Honda and Lexus,
3. electrical issues in BMWs
I could go on with issues about Korean cars. Just about every manufacturer has made a big time boo-boo at one time or another within recent memory. That doesn't make it right however.
However, in the past, dealers working on my cars to fix roof rattles in lights, etc., usually damaged/soiled the roof, the headliner, or the light itself. :sick:
This time, since the light was easilly removeable, I was able to trace and (so far) fix that squeak problem without those headaches.
I've let Subaru know what the problem was and what my "fix" was. There was no response.
Before you call me a Subaru patriot again, keep in mind I commute in a Miata and drive a Sienna on the weekends. I choose the best product that meets my needs, without any blind loyalties.
Mitsubishi hid safety defects (faulty brakes!) on 1977 models all the way up until the year 2004, a full 4 years after the investigation of the hidden recalls began, by the way.
Did you forgive them?
Unforgiveable ... please.
Again , thank you
I don't find that need with the upgraded one though. I suggest you take your favorite CD with you when you "test listen" the Bean radio. If you find that to be much better then you will really like it with the tweeters and sub woofer. To me there is something to be said for everything integrated, and Subaru has always made things so they just plug in and work well together.
The sub is not large enough to be strictly a low bass enhancer so it overlaps a bit into the midrange. I can't remember what the spec sheet said that came with mine but I think it rolls over at 250Hz. Since it has it's own amplifier built-in that helps too.
The tweeters are a great help because high frequencies get easily absorbed by soft materials and can get lost in a car, so dedicated speakers to enhance the sound work very well. If I were only going to buy either the tweeters or the sub I would buy the tweeters, but I find the whole package very satisfying, as does my wife.
If you were nearby here in MA I would let you listen to the Manheim Steamroller Christmas CD my wife has in her Forester. It sounds outstanding and would convince you in a heartbeat about the whole package. The biggest test will be whether you see a big difference in the Bean radio over the base. If you like that you will love the rest.
If that happens the strips get nasty gouges in them and may not seal properly.
I'm seeing if mine recover from their pinching, but if not, I'll let the dealer know and hopefully get them fixed.
I test drove an X Premium, so it had the middle system. I still want to sample the NAV system.
Generally, audiophiles will want to go aftermarket anyway, but the tweeters are mounted up high and supposedly help a lot.
Bose stereos are funny. People seem to love 'em or hate 'em.
I happen to like them. I think with bass-laden music they work quite well. I listen to some reggae and hip-hop, and I think it sounds good to me.
There are audiophiles that absolutely hate Bose, though. "No highs, no lows, must be Bose". Or they just call it "Blose". Others say it is OK but just overpriced for what you get.
Sounds fine to me.
Spring for the Premium package, just look at the size of that panoramic moonroof. Motorweek said it was "Big as the Texas sky".
-Frank
Kudos to Kurt for creating a new topic where the never ending AWD arguments can continue :P I'm guessing however that won't dissuade chelentano from continuing his Juice-baiting posts here :shades:
Regarding Forester rattles, Subaru has frequently gotten dinged in JD Powers type initial quality surveys due to things like annoying rattles. On the other hand, Subarus fair very well in long term surveys (such as Consumer Reports). So while a rattle can be EXTREMELY annoying, that's all it is. And which would you rather deal with, the occasional annoying rattle or a major mechanical issue that might cost hundreds of dollars to repair?
I'm not trying to give Subaru a free pass for any rattles, there's certainly room for improvement. However, in Kurt's instance, wasn't the rattle caused by the dealer? In which case, I agree that it can be better to try and fix yourself rather than have an inconsiderate mechanic futzing around and potentially doing more harm than good.
-Frank
P.S. Welcome back to Big Frank, you were gone for what, 2 years?
Also I read that Subaru and L.L. Bean are not going to renew their partnership. I wonder why?
Good to see the old-timers still here as well as all the new posters. This has always been a great group and an excellent place to share.
You still have a great name!
:confuse: In my 04 the subwoofer is mounted in the left rear cargo comparment wall.
-Frank
Tweeters and the sub woofer are a great way to enhance the musical range of the sound system. The sub adds to the low frequencies, the bass, and the tweeters do the high frequencies. I have installed several of each myself because I always figure that no one works on my vehicles with the care I do.
I just looked through the 09 accessory catalog and the tweeters look just like the ones I put into my 06. The car is pre-wired so accessories can be put in easily at the Port or the dealer. They go at the leading edge of the door where it meets the A pillar, just inside from the mirrors. There is a little cover that pops off and the wires are under that. The tweeters just snap into place after you plug the wires in, then the speaker grill snaps on to replace the dummy cover previously removed. The grill looks just like the dummy cover except for the small holes to let the sound out. This install is a piece of cake. If you can change a light bulb you can install them, really. The only tool needed is a small screwdriver to pop the dummy cover off, and you should put some tape over the tip so as not to scratch anything. That is the hardest part, and that is not hard.
The catalog also says the sub still goes under the driver's seat. This is not pre-wired but everything needed comes with the sub, including excellent directions. This is a little more involved because the seat needs to be unbolted and tipped back so you can work under it. The wires get run inside the console and under the dash to the back of the radio where it gets plugged in. The electrical part is easy but the real work is running the wires. If one is handy it can be done in about 30 minutes, but is harder than changing a light bulb.
The catalog says the part number for the sub is H630SSC000, and for the tweeter kit H6318SC000. It does say that the tweeter part number is for the X and the Premium, so you may want to inquire about the Bean, and what if anything is different.
Good luck with your purchase!
The XT has it in the rear cargo area as standard equipment. The add-on subwoofer for non-XT models goes under the front seat.
Aside from not being able to a get manual on the turbo, what do you think of the new Forester? Have you checked it out in the flesh and/or taken a test drive?
Bob
I'm sure Subaru could come up with a more elegant fix than mine but my foam wraps around cable and between mirror bracket and roof have hopefully shuddup'ed the noise.
There are still a few minor creaks/pops in dash over some bumps, but any car's going to make some noise over bumps. My former Maxx rattled a lot more than the Forester does, and my '03 Ions were buzz/rattle fests by comparison.
The tweeters do add air to the sound. Good to know what is involved with Subwoofer install (a pity wiring has to be run, though).
Apparently the suspensions are different between the X and XT series. The XT is more "sporting" and leans less in turns. IMHO, The XT ride's firm but not harsh - kinda like a WRX but with more suspension travel. The rear end tends to kick up its heels over speed bumps, though.
Bob- Some aside... that's a deal killer for me Probably a good thing though since without the manual, I'm not tempted to want one :P Which is good news considering there's absolutely nothing wrong with my 04.
I've not gone to look at one in person but from what I've read it sounds like they've made improvements in almost every area and my fears of the Forester losing some of its handling ability appear misplaced.
Now if Subaru decides to re-offer the manual in the XTs in a year or two, then I'll be in big trouble :shades:
-Frank
They've been a fair number of hiccups on their my.subaru web site as well (having difficulty updating stuff, service contracts not being listed, etc.).
Visiting some dealers for accessories, I've found they don't always have '09 parts lists.
Perhaps the support infrastructure for this car's still evolving? :confuse:
Wrt body-mounted rear-most door weatherstrips, they seem to be reforming to their original shape and are not being pitched by the added "wheel well" trim.
I'm curious...do any other '09 Forester owners see a groove in this weatherstrip? The strips' grooving/additional lip starts from the lower rocker panel to about 6" above the rocker panel, then gradually blends into the weather stripping.
http://www.carspace.com/arvin1/Albums/Japan%20cars/originals/subaru-forester-sti- -version-9646.jpg/photo/v./original.jpg
Bob
Anybody still have the link for the British car magazine comparison between the Forester STi and WRX STi? I'll never forget the woman driver's reaction to the acceleration and cornering of the Forester (to say she was surprised is an understatement).
-Frank
I was looking for Bluetooth but haven't seen it listed with any of the accessories.
This should work:
http://video.google.com/videoplay?docid=-117426835217777671
Enjoy!
Len
I have the most sympathy for owner of the new Forester who, perhaps of bad luck got in the first week of buying the vehicle some problems (little faults). I have also experienced these horrible disappointments that eat your flesh, just to be told by people, like here in this forum that he should be in high spirits with the rattles in his car, because many others vehicles has more rattles. Is this a consolation? Or more salt onto the wounds. Mates I have had a Hyundai Tucson for 3 years with more than 60K miles, and although the vehicle was not a proper off road I used the vehicle as a proper off road. Before I sold it I did not have any experience of any rattle and the vehicle was a Hyundai (supposed to be a junk vehicle).
They are not junk, but there are people who have had their fair share of problems with Hyundais also. Citing Hyundai as an example of a shining star is perhaps the worst possible example. That's like saying I never had a gas tank explosing in my Pinto. :shades Unfortunately lately, no manufacturer, maybe except for Porsche is seems to be immune from issues.
Can you cite some sources this is a widespread problem? Or, did two people post on a forum and now this is a catastrophic issue. Inexorably all cars will have issues. The Foresters in general will have less than most. I fully agree some model years have been problematic, but that can be said for every manufacturer on earth. Subaru isn't exempted nor does it lead the charge.
I can post some links to owners who have had Lexus lemons with sludge problems.
With the Subaru engines I have read a number of owners saying that they changed the piston rings at about 70K-80K miles.
If you read these boards, there are members who have had trouble free ownership well into the hundreds of thousands of miles. You have no substianted proof of any systematic issue. The layout of the engine alows the Subaru handle much better than the competition. Are there trade-offs? Absolutely. Buying a car is one huge trade-off.
Each of this movement by the physics law carried an extra force (i.e. gravity force) that pushes down the piston harder to the walls of the piston. This is just a hypothesis.
Are you aware a number of Porsche engines have the same basic layout? Horizontally opposed sixes. Are you aware that Porsche engines are vitually indestructable? I'm not saying the Subie engine is made with the same meticulousness as the Porsche, but if what you say is true, Porsche engines would be breaking left and right alongside of Subie engines.
Having said that, I can't resist myself in responding to the most outlandish statement
Yeah a dumb hypothesis Using the same argument, V-6/8/12 engines would also be more susceptible to the "forces of gravity". Which means that the inline engine is the only good design. Huh.
The reason there are dozens of car manufacturers and hundreds of models is that everyone has different needs, wants, preferences and priorities. The Subaru Forester is obviously not the best choice for many people but... it is for some.
-Frank
Edit- Uh oh, it looks like Sam agrees with the inline engine design
With regards to the sludge matter in some Lexus SC300 this has nothing to do with piston design horizontal/vertical piston.
Len- That's the one! Thanks for the link.
-Frank
As for an STI version of the Forester? How many STI's does Subaru sell wrt total Impreza sales?
If Subaru were to do this for the USA, I suspect it might open a new niche. Would Toyota RAV4 TRD, or Mitsubishi EVOLander, or Honda CR-V-SI, be far behind?
Your point is about engine failures, Lexus has had it's share.
I think this entire board, the moderators and Subaru would really, really like to know more about your hypothesis. Can you prove a scintilla of what you infer?
I didn't think so.
Frank - over the years at edmunds I've seen some very outrageous statements, but this takes the cake.
