Dodge Ram Mileage Improvements
                    I see the following claims on certian items to help with increasing your MPG, what really works?  :confuse:
Cold Air intakes ? - they are sold with the theory they will save you up to 10% in MPG and add more poines. I have read that the oil based filters caused some O2 sensors to fail earlier than expected, causing a decrease in MPG.
Exhausts ? Cat Back? Headers and true duals? - I am skeptical of the cat back systems, aside from them making your truck louder.
High Flow Cats?
Synthetic oil? Can I use this in my 98 dodge ram with 104K miles?
Computer programmers/chips? I have read reviews on auto part sites stating they do nothing and are very expensive.
Tire Size - going smaller will help? (width)
Tire Pressure - inflating to max psi will help? This I know for sure, but lets hear your take on it...
Spark Plugs - what works? I have seen this area of the market change drastically over the years, and some aren't cheap. What really works?
Iginition systems - they are pricey, but does it do anything for MPG?
Electric Radiator Fan - heard two sides about the electrical load will cause more drag from the alternator, and that while driving over a certain speed your clutched fan doesn't cause any drag.
Low drag pulleys - they change the speed of the rotation of your belt driven components. Does it have a negitive affect on them? shouldn't they be spinning at the factory speeds?
and the biggest myth I know, and have facts to prove they don't work, but like to hear people try to convince me of it... the tonneau cover / the dropped tailgate / removed the tailgate. They DO NOT SAVE you gas. I get 0.5MPG LESS with mine in the city. My proof (I know I have posted these links a few times, but here they are once more).
MythBusters Episode 43
MythBusters Episode 64
now on to what I think are just gimmicks...
Waxing your car to reduce air drag
Tornado Fuel Saver
Fuel line magnets
add-on blowers (the hair dryer type)
What has worked for you? I would ask that you state your truck model, year, 4x4 or 4x2, fuel type, and all those add-ons that worked or didn't work. Use real MPG numbers, not what your computer display is telling you. I found that if I spend over $1200 in add-ons I could save up to 20% in MPG, but thats a lot of money to find out I didn't and is it worth it on a 1998?
this is a great site also, http://fueleconomy.gov
High Flow Cats?
Tornado Fuel Saver
Fuel line magnets
:lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon:
kcram - Pickups Host
Ski in TX
1. Superchips Programmer. I have used both the 87 octane Performance and the 91 Octane Performance mode and settled at the 91 (I run 93 Octane and while it costs more at the pump I get it back plus some in MPG and unbeleivable difference in HP) 2-3MPG
2. Flowmaster Exhaust. I just put in a Series 50 it is not as loud, less cab resonance and still has free flow. Sound great and helped my MPG by about 1mpg
3. I have switched to Royal Purple in both engine and Transmission and soon rear differential. I was told it helped... I am a believer now, been running it for about 10000 miles and have seen as much as 2.5 MPG just in changing to Royal Purple synthetics not to mention it runs alot cooler even with the performance mode.
4. New Plugs. Stick with the factory type plugs, there have been lots of reported issues with Platinum and Iridium and other plugs both in less MPG and siezing in the block.. Dodge spend a fortune in R&D to find the right plugs and temp for your engine and I doubt you can do better.
5. I am ordering a CAI. Keep in mind not all intakes advertised are true CAI more are short ram style. Dodge acutually has a true Cold Air box but the "air hat" and the connection tube has poor airflow. I haven't heard about issues with O2 sensors per se but the new Dry filters offered by the better CAI manufactures are worth the $.
6. Fitch Catalysts truely do work I have seen it but haven't forked out the $$ for
one ...yet...
All in all. I have gone from an average of 12.5- 13 MPG in city to 16+ MPG in city with this old Dodge Quadcab...when I can keep my foot out of it. Hard to do with all the new found power. I never go below 13.5 in town now even with my foot in it and pulling a trailer. I have 93000 miles in it and have had good luck with it. I had to change the TPS and the Cam position sensor... about $50 total and 30 mins of work. Not bad considering the miles I have put on it. I don't do much freeway driving these days other than vacations and such, even then I get ~20MPG loaded with camping gear, 4 wheeler or motorcycle and a load of kids.
What did help was going from dino oil to synthetic. MPG went up 1 to 2 MPG on my HEMI on the first oil change.
Ski in TX
I also noticed an increase in MPG (1 to 2) without my AC going. Of course thats hard to do in the summer in Texas. Watch for it on sale and buy the BIG 4 or 5 qt bottles, its cheaper that way rather than single quarts. Maybe just go up to the semi-synthetic at first as it is more cost effective than full-synthetic and you might get a MPG boost as I did with it. At least its worth a try. Good luck bro!
I believe the 5.7 Hemi is susceptible to long break-in as the 4.7. Of the four Hemi Ram owners I know, they seem to be in agreement that the mileage is getting better with mileage. One fellow I work with averages 19 unloaded on the New York State Thruway in his 4x4 2006 Quad Cab.
Best regards,
Dusty
I too once owned a 4.7(2000 Durango) and had no complaints at all. Good power and decent economy. I followed that with an '02 Durango(5.9 because not many 4.7's left when I traded). Mileage was much worse and performance about the same. I recently switched my Hemi to full synthetic oil and added an "Airaid" throttle body spacer and air filter. Average mileage actually improved after the Airaid install, from an average of 13 to a legitimate 16. Didn't notice any change after the oil switch, which was done first. The guys at Airaid were very helpful and honest. I told them I was after mileage, not performance, and they recommended the least costly setup, after advising me that the more elaborate systems are designed to boost hp and generate more noise, while not necessarily improving mileage. So far, so good.
After driving about 20-30 miles the seat belt light comes on and you cant move, the belts just lock, but if i open the door everything works ok again and the light goes out untill i drive another 20-30 miles.
Any ideas as its not very safe opening doors whilst driving.
Lee
