Jeep Cherokee neutral safety switch, how to bypass
Anybody know how to bypass the neutral safety switch on a 1991 Jeep Cherokee. It is a 6 cylinder.
I just need to do it for a short time until I get a break in the weather so I can replace it.
Zack
Zack
Doing so would deprive everyone else of valuable information. Why don't we just keep the conversation here?
SUVs and Smart Shopper
Your post was very helpful. We bought a 91 Jeep cherokee in December.
We already replaced the neutral safety switch, but the mechanic said there was a lot of wear & he was unable to fully adjust whatever he needed to ensure it would continue to work. He did not charge us for the switch or the labor(can you believe that!) because he had at 1st diagnosed a bad ignition that we had him replace.
At 1st we were hopeful, but it soon had the same problem. A friend offered to replace the starter solenoid, but still no luck. At that point my husband tried to convince me that we should bypass the switch. I was worried about forgetting to put the car in park....but now I think it is the only solution.
We have had a lot of crazy problems with this car but they seem to be fixable. We just replaced the o2 sensor, cleaned the fuel injectors & added a clip to a brake vacuum hose that seemed to pop off at odd times. This was after a scary episode of losing power then surging (and losing most of the braking) last week. The Jeep dealer (believe it or not) said the engine & transmission were fine.
We have been meeting some honest mechanics this week & your post also is a blessing.
I'm a bit paranoid though...I don't want another episode.
JB & Mrs.
I am having some problems w/my 91 Cherokee. Was searching the internet for answers when I had came across this forum. My local garage said that is what I need for mine. This may sound dumb, but, what exactly should I get to bypass the safety nuetal switch? I dont have the $338 plus for a new switch. As I had just replaced throttle position sensor as well as idle air. And I'm being told the coil pack needs done as well.
Any help would be greatly appreciated!
Thank you for your time,
Cheryl
I've re-built my neutral safety switch several times and it's really not hard. All you really need is a wrench and some degreaser. You can Google how to do it. I'm not all that mechanically savvy (no formal training) and my experience is limited to stuff I've done on my Jeep and wiring up sound systems. It took me maybe 2 hours tops to re build it.
However, the reason I'm bypassing is because I'm tired of having to rebuild it every year or so. They get gunked up and the metal contact points do get pretty worn down by the time the vehicles are this old (10+ years). So you can easily re-build it you just may have to do it again every so often. Another good option is to find a newer jeep in a junkyard and snag their NSS, rebuild it, and slap it on your older Jeep. Good luck!
http://img341.imageshack.us/i/img1298n.jpg/][IMG]http://img341.imageshack.u- s/img341/581/img1298n.th.jpg
thanks so much...Frankie...
It helps to be on the starter rather than the generator...
Anyone know however, what fuse should be required in this line?
Frankie
Thanks for your post about bypassing the NSS. After symptoms described by many others, I decided to dive into this simple circuit addition. 60 minutes later she's done. Then I had to wait for the switch to fail again, but when it did, hey hey...that little red button fired it right up.
Thanks for you're post.
Mike
Also when it does randomly turn over, and not start, i am not getting spark,
Any help from here would be really appretiated. Thank You
