Toyota Camry 4 Cylinder Transmission 2007+
I just got this car a month or so ago. I have almost 900 miles and I notice that the transmission is slow to react when accelerating. I also notice upon takeoff that the car basically jolts right off the start rather than smoothly accelerating. Is this normal behavior? I test drove another LE before choosing this car and I do not remember this occurring. Is there a fix for this?
However, your is 2008, so Toyota mights need to come up w/ new fix or may be never. This problem has been known for a long time especially w/ Lexus.
I have a friend who's driving 2006 Camry LE and told me same thing happens to his car, so he warms up about 5+ minutes before driving.
My car sits inside a subterranean parking garage in Southern California, it never gets cold inside there, by the time I exit the needle on the temperature gauge is already 1/4 of the way up on the register.
Good luck with your 08
It appears that the ENTIRE Toyota/Lexus FWD and F/AWD products series is suffering, going all the way back to the '98 RX300, from transaxle design flaws having NOTHING to do with engine "selection". It's just that the design flaw may exhibit itself in a more pronounced, noticeable, fashion in one engine vs another.
Regarding the extent of this alleged problem, I'm not so sure it's that bad. My 2 Camrys (prior generation) are fine, and Consumer Reports doesn't show any transmission issues for pre-'07 Camrys either.
Camry is lightweight, FWD, and HSD generates so much TORQUE that the ECU cannot allow the use of full torque even with your foot to the FLOOR.
It is a real shame, truly, that Toyota doesn't see fit, hasn't seen fit, to build a RWD hybrid SUV in this weight class.
If ever a Prius or Camry hybrid and a Porsche Boxster or Cayman turn up in Ebay savage simultaneously I'll be off to the races.
I read that it reduces the pressure on the transmission and extends its life?
Pleas let me know if anybody has any idea on this.
Since about 2000 most Toyota and Lexus transaxles do not downshift into first gear until you come to a full and complete stop. As a matter of fact there are rather strong indications that "these" cars do not downshift at all when coasting down to a stop unless you step on the gas pedal for "re-acceleration". And even then there can be as much as a 1-2 second delay in downshifting.
Be that as it may, I suspect that if one were to be able to reliably predict a full stop is upcoming then a quick shift into neutral BEFORE coming to a full stop would not only do no harm but increase FE slightly and possibly extend the life of the transaxle slightly.
Keep in mine that many of your fellow owners have learned to manually downshift the transaxle in this "like" instance so as to avoid the infamous 1-2 second "re-acceleration" downshift delay. That, in my opinion, would definitely shorten the useful life of the transaxle, but in compensation has the real potential of extending yours.
If you allow these newer Toyota/lexus transaxles to operate normally they will upshift, or maybe just go into neutral ("A") as you coast down below 10 MPH coming to a stop, and then only shift into first once fully stopped ("B").
If you can manage to move the shifter into neutral just prior to point/time "A", and then back into gear at point/time "B", then you have caused no more "shifting" wear on the tranny than would have happened normally. And if "A" was to have been an upshift, as is most probable, you will have actually decreased the wear on the transaxle.
It takes 0.9 hours (really only 25 minutes).
"The TCM determines the gear that is to be selected when the accelerator pedal is released (released completely) in accordance with the way the accelerator pedal is released (quickly or slowly) during deceleration. In this way, unnecessary upshifts are prevented during deceleration, matching the driver's intentions. In addition, unintended downshifts are prevented when accelerating the vehicle again, achieving smooth acceleration."
So, unless you can learn to abide by the above rules as to how you "manage" the accelerator pedal the 1-2 second downshift delay will remain a potential problem.
Else what is the dealer's basis for denying warranty coverage...??
A 2008 FWD vehicle without a TC system that will INSTANTLY activate to prevent/alleviate driven wheel spinning via braking and engine dethrottle, INSTANT engine dethrottling, has been deemed to be PATENTLY unsafe.
TC will ALWAYS prevent undue stress on the transaxle arising from the situation you describe. Either the TC system FAILED or was somehow disabled, if it failed the warranty applies.
