Tell me more about where you're driving when the XM signal cuts in and out. If you're under a bridge or in a parking garage or under lots of trees, the signal will cut out because the antenna can't see the sky. XM does have repeaters in different metro areas to fill in coverage gaps where they know that the terrain will block reception (they're also very hush-hush about where these repeaters are, so if you want to know if there is one near you they won't tell you) and the radio buffers about 8 seconds of data before it drops to try to minimize dropouts while you drive.
If your XM cuts out when you have a clear view of the sky, then yes, I would doubt the radio. If you don't have a clear view of the sky when the signal drops, then your radio may be fine and this is just how satellite radio works.
http://www.xmradio.com/about/musicroyalty.xmc
Anyone have any help on this. Anyone successfully installed an AUX jack on a 09 with Navigation????
So if I understand correctly, I just disconnect one speaker and plug in that channel line level converter and then plug in my AMP?
Thats sounds too easy ))) I was going to buy another radio because mine didn't have RCA output.
Well, you COULD, but that's not the common approach. I assumed you would get a TWO-CHANNEL amp, disconnect both rear speakers and connect to the ALOC-60 and amp that way. This also assumes you're not adding a separate subwoofer.
Now my radio doesn't have RCA and has 4 speakers.
What would be the best setup for me you think?
Thank you very much
In your case, I would connect one side of the converter in parallel with one of the rear speakers (don't disconnect the speaker), and then connect the converter to your amp and then to the sub.
thanks for the help
My 3 months trial period ended in my new Santa Fe 2009 but I still have XM playing, well at least 2/3 of the channels. The other channel says "channel unauthorized".
Is this normal? I thought I would of lost all the channels after the trial period
Anyone have a similar situation?
cmlegend
intermittent... frustrated...
