Nissan Sentra Electrical Issues
I have a 2000 Nissan Sentra GXE.
I'm having a strange problem with my left turn signal/brake light/headlight system and can't figure it out. when I turn on my left turn signal and it works fine until I press on the brake then the signal dims way down, the brake light flashes, and the lights over the license plate flashes as well. It gets even worse when the head lights are on. The right side works perfectly.
I've tried replacing the bulbs and checking the harness at the back light system by swapping it with the right side. I also checked to see if its a grounding problem by temporarily connecting my jumper cables from the negative terminal on the battery to the engine block - no help.
I would really appreciate any help or ideas anyone has for this.
And sometimes anything to do with the dash board area (turn signals, brake lights, shifter and a/c you get the idea) will stop working and if you take the battery cable off for awhile it will work again. Any ideas on whats causing this? changed the fuses the battery cables already.
I have the same problem with my Sentra. Did you ever get an answer?
Left turn signal/brake light/headlight system: When I turn on my left turn signal and it works fine until I press on the brake then the signal dims way down, the brake light flashes, and the back-up lights flashe as well. It gets even worse when the head lights are on. The right side works perfectly.
1) Within the first 3 weeks of ownership, I got in the car twice to find out that the clock reset to 12 and the radio presets were gone- just like when you get a new battery. Dealership service maintained they were clueless about cause. Small irritant, right?
2) Two weeks later, radio and clock went out entirely. Replaced, and service said that there was a short and burned out fuse. I thought to myself- in a NEW CAR?
3) A week later, car did not start at all after I had been driving it fine all weekend with no problems. I jiggled the gear shift, thinking it wasn't all the way in park, and it then started. Drove 2 miles, suddenly ALL electrical systems went out and car lost power. Fortunately, I was not up on the highway and coasted into a plaza. No lights, no horn, no nuttin'. Water in five of the six battery cells was very low. Towed into dealership, where they replaced a "bad" battery. I insisted that they check to see why the battery would burn up water like that. I was told- "No problem could be found".
4) Exactly ten days later, car is towed again from work. Completely dead electrical system again, although I had taken it out for an errand during lunch. I should mention that the evening before, when I ran up to the store, the car had no pickup and would not go over 30. When I came out of the store, it drove just fine.
This time, the mechanic said he was "100% sure" that the problem is likely the one that caused the radio to go out and is the result of the failure of the factory to properly weld a connection behind the battery so that battery wasn't recharging. I was told, however, that the proper part to fix this was on national backorder. (Hmmm- do I smell a coming recall?) The proper part being called both a connector for a wire harness or the right battery terminal. After six days in the shop, with no loaner car furnished to me, I picked up the car tonight after the proper part came in and it was "repaired". I drove it home two miles this evening. Two hours later, when I got back in to visit a friend at the hospital, the dashboard lit up real purty and I still had a horn- but it didn't start. Not even a sputter. I looked in the battery and the water in all chambers was low. (Curiosity question- why was the battery not checked?) I put more water in then tried to start the car both in park and neutral. Nada.
Service division was closed but I talked to dealership sales manager who told me another 2010 Sentra with exactly the same problem got towed in to them yesterday. The mechanic had last week told me he saw the same thing four months ago.
By the way, I took this in twice before the electrical problems started because of a "popping sensation" under the floorboard when I turned the wheel to the right. It came and went, and shop said they couldn't replicate it so had nothing to fix. But if the steering system is electrical, I wonder if there is a relationship.
Well, my "new car" , with a whopping 3100 miles on it, got towed in for the third time in 2 weeks tonight. But I am beginning to question whether this is fixable, and, if a bandaid is put on this, what confidence can I have that there aren't other slipshod quality problems awaiting me in the future? Meanwhile, my 175,000 mile Taurus that I thought was on its last legs and that my son now uses is going strong, air conditioning cold as the day I bought it.
Is anyone else aware of such problems? What has been your experience? I am more upset than these words convey. If I bought a lemon computer, the store would exchange it - but I'll have to go through an arduous lemon law proceeding on this one. :mad:
We're having the same exact issue with ours right now. How did you get it resolved ?
Please share the soulition for the below problem....
I am having 2004 Nissan Sentra 1.8S, having the same issue
All my meters goes off and on frequently. The OFF and ON time is 2 to 3 seconds.
"The speedometer, fuel gauge, RPM gauge, engine temperature gauge stops working off and on."
Please share the solution.
I gshanmugam posted the problem in this forum, want to share the solution...
My problem was
All my meters goes off and on frequently. The OFF and ON time is 2 to 3 seconds. "The speedometer, fuel gauge, RPM gauge, engine temperature gauge stops working off and on."
Solution is...
I took my car to the cluster repair specialist and he solved it in just 30 to 45min, and said some electronic part went out due to heat. No earth wire loose, now loose wire harness, no other sensor issue...
It is just a clustor.
Please refer the cluster specialist website "http://www.piclusters.com" and the person name is "Jorge".
I had lot of web search for my problem, so want to share the solution.
Gshanmugam.
