Jeep Grand Cherokee died suddenly at 50 mph
Today I was driving along at 50mph in my 2002 Jeep Grand Cherokee Laredo 4.0L when suddenly it felt like I lost half the power. A few seconds later the engine died. I coasted to a stop and was able to restart the engine numerous times. It would idle fine but as soon as you gassed it the engine would start misfiring again, sputter and stall. It did this a few times and now it won't even start at all.
I did the key trick and received 5 error diagnostic codes:
P0340 Camshaft position sensor circuit malfunction
P0351 Ignition coil A pri/secondary malfunction
P0352 Ignition coil B " " "
P0353 Ignition coil C " " "
P0455 Evaporative Emmission Control System Tank Detected (gross leak)
I believe the the P0455 was present before this cut off. I think that code is due to an aftermarket gas cap.
The other four codes are what have me concerned. Can anyone offer any ideas as to what would make those codes all come on at once? Seems odd that all coil packs would fail simultaneously.
Where should I begin? At first I suspected a fuel filter, but now after seeing the codes I don't think that is it.
sound as if distrubator has frozen
I am hoping a Jeep tech will tell me the best way to go about changing this item out...mostly I want to know how I can be sure that whatever gear this connects to has not sheared as well. It is impossible to see from the top.
Now for how to replace your camshaft synchronizer. If your vehicle was running when this device seized, then you have lost the timing relationship between your cam and the camshaft sychronizer. In order to get it back you first need to get your #1 cylinder to TDC (top dead center) of the compression stroke. If you aren't sure how to do that, then you probably shouldn't be attempting this job yourself.
When you purchase a new camshaft synchronizer you may or may not notice a temporary plastic set pin which passes through the aluminum casting into the small rotor (on the top part of the casting which stays outside the block). If it is not there, you will have to put something there to keep that position. I used a small piece of scrap 12 gauge household wire.
The goal is to put the new camshaft synchronizer into the block so that it ends up with the position sensor wire connection facing straight back towards the firewall at 0 degrees from the block (basically straight back towards the oil filter). This may take you a couple tries since the gear on the synchronizer that meets the gear on the cam itself match up diagonally. This means you have to start farther counter clockwise from your ultimate goal of 0 degress and rotate clockwise as you push it into place. You may also have to move the oil pump slot a couple times with a long screw driver to line it up. When you get it to seat fully with the wire connection straight back, #1 cylinder at TDC (compression stroke) and temporary set pin in the camshaft synchronizer, then you have finished the hard part!
At this point, I replaced the hold down clamp which anchors the synchronizer, put the small plastic camshaft position sensor back on and reconnected its wires and removed my temporary set pin (wire). You may still have to bring it to a dealer to have the timing fine tuned, but if you get it right, you can drive it there. I could tell when I first started my engine that I was one tooth off (advanced). I just lifted the camshaft synchronizer up just far enough to spin (retard) it one tooth. On my second try, the engine sounded terrific. If you don't know the symptoms of timing being too far advanced or too far retarded, then you probably don't want to attempt this job because you could cause engine damage...especially if your timing is way too advanced. If you were truly at TDC on #1 cylinder, you should be good to go. If it doesn't start you may have to repeat the procedure. You may have been at TDC of the exhaust stroke instead of the compression stroke meaning you were 180 degrees off.
Hope this helps...it took a great deal of digging to get the right instructions.
And that is probably why more help was not forthcoming so that makes you a pioneer! (I didn't say trailblazer or pathfinder!)
Seriously, though, consider writing up a guide (see link at top of this page). Eventually, someone else is going to come looking for that same information.
SUVs and Smart Shopper
My first question is this: Is the Camshaft position sensor the same as the camshaft synchronizer? If my local parts store doesn't have a listing for the CMP sensor but does have the pick-up plate, will the pick-up plate work for me?
I love my Jeep but it is getting old and it's got a lot of miles on it. I want to keep it but I don't want to go broke fixing it. Is it likely that changing this part will fix the problem or only lead to more problems?
Any info would be greatly appreciated.
Heeply Jeeply
i have a 2001 jeep grand cher 4.0L and was having trouble starting.
i did the key trick and got code for crankshaft position sensor,i replaced and truck started right-up.
now while truck is idling it stalled so i did key and got code p0351,p0352,p0353 ignition coil primary dwell time. I replaced ignition coil pack and truck is still running ruff,after replacing coil pack code p0351 went away but p0352,p0353 are still showing and truck keeps stalling.
i went online to try to find some help could find anything. the code reads dwell time if theres anyone who has had this problem could you help please anything will help
i read your post and agree with you that this forum has been much help,
however you seem to have a good idea on what going on with the jeep.
i have 2001 jeep gran cher and was having trouble starting it got code from key code was for crankshaft position sensor,changed c.p.s. and truck started right up.
now truck is running ruff and will not idle keeps stalling did key and now getting codes for p0351,p0352,p0353 ignition coil changed coil pack and p0351 went away and truck still running ruff will not idle without stalling.
code p0352,p0353 still showing i've taken all kinds of wrong advice from so called mechanics.i'm slowly learning that they've been wrong, changed spark plugs,fuel filter all kind of stuff and not one of them worked.
i'm hoping that you may have some insight on what i could do or is this a job for the dealer.trying to avoid the costly repair tag that the dealer going to tack on please help anything would be helpful
thank you;
carl
The sensor has a plug on the driver side of the engine and the sensor bolts to the bell housing of the flywheel driver side. Its a pain to replace without a universal joint and 18" extension.
I have changed the cam shaft sensor, EFI module, fuel pump, plugs, wire, distributor, rotor button, battery and the pins on the computer connection. Did I miss anything. Now the dealer has a team working on it. Please send prayers
Vfreen :confuse:
also how do you get the codes on them
It is not giving any codes and because of the randomness, my mechanic is not sure what is causing the problem.
I have a '96 JGC.
i guess it is a sensor playing up somewhere but i have know idea which one
if you solve yours can you please let me know what it was
I called the shop today hoping to get my jeep back today. I was informed that after replacing the wires the computer in the jeep would not take the program codes that were necessary. They called Chrysler and found out my computer would have to be replaced also. ( there was a technical bulletin about this problem and that Chrysler would cover the cost of computer) here’s the problem they don’t have any in stock it will be mid May or June before they would have any. I hope this helps someone out there having the same problem ask your mechanic to check your wiring. I still have to pay the $ 600.00 for the wiring that has been replaced but Chrysler is paying for the computer
Thanks so much Kattykay
