Acura Integra Steering and Suspension Questions
90' Integra. I am having an intermittent shaking in what feels like the front end. It will happen at low speed and high speed. It will come on and then maybe not happen for days. I know this much.
It is not the the wheels or tires. New tires and have had re-balanced, and rotated around the car to see if the vibration moved. It's not the brakes, I know what a warped rotor feels like and i don't feel it thru the brake pedal. I do know now that it definately occurs under load, more so on accelaration. The motor runs fine, no shake at idle or under load with the e-brake on. It will cease to shake when I depress the clutch and let it roll.
Thought CV joint but had them replaced about two years ago and this def was not a symptom. Had it to an alignment front end guy who said everything seemed tight, and of course we couldn't get it to shake for him.
Thought motor mounts, but doesn't explain why it's intermittent. Maybe a clutch issue? Flywheel?
It had a new clutch put in it back in September.
To me originally it felt like it was in the wheels (wobbling), but now that its been on and off since x-mas it feels more central.I just need to know who the heck to take it to.
Thank you for any input.
