Need help- Crank Position Sensor
dukecebrelli
Member Posts: 3
in Oldsmobile
Read through the chilton and I'm as far as getting the balancer bolt out- supposedly you should be able to pull off the balancer by hand- I've been yankin it for days now- I don't think I could fit a pulley puller in there so close to the inner fender- anyone know any tips or tricks??
Thanks!!
(1998 3.8L Intrigue)
Thanks!!
PS- be easy with that tranny - I hear from multiple people that they bite the dust if you over do it with high miles.
I do beat the crap outta mine and she still runs great- tranny does some wierd stuff once in a while.
Always here to answer anyone's q's... info@carcaredelivered.com
-Duke
"The only problem with doing this repair yourself is that you will not be able to preform the crankshaft position variation learn procedure with out a factory scan tool. The vehicle may crank an run, but the timing advance curves will be wrong so the vehicle will probably cut off every time you remove your foot from the gas pedal."
(read from here http://www.fixya.com/cars/t940986-crank_position_sensor_location)
Do you know anything about this issue?
-jake
(The proper test would be to use a volt meter to see if power is making it to the starter solenoid from the ignition switch)
-Duke Cebrelli
owner
If it was the crank sensor it would at least try to turn over.
Owned my intrigue for many years now.
Replaced it ignition switch twice.
Contactors get scorched and burnt inside.
I have actually repaired them but don’t even mess with it.
They are about 80 dollars at AutoZone.
thanks,
Shawn
