pt cruiser power steering line failure
repeated pressure line failure. line cracks behind flare at pump. pump & rack were replaced, system was flushed ,
Check the power steering fluid level and the PS pump belt for excessive play.
Also, did you check for a similar problem in the message right above yours? (wire mesh screen blocked)
One thing is that the creaking primarily occurs after the turn when I am steering back. Also, it does not always do this and it seems to become more noticable after I have been driving for awhile.
Thank you for the feedback!
I was able to pull off the road and avoid an accident. As I straightened the wheel back to center after getting out of the way, it just fixed itself and I drove home worried, but without incident.
Anything ever come about with your problem Superrak???
