Jeep Liberty Diesel seeing other problems?
hammerboyone
Member Posts: 5
hello all ... first of all i have read many of your posts. thanks. now to why im here... i have a 2005 crd with 45000ml .. up till now i have been real happy with only the basic trouble and recalls. i have all my work done at my local dealer that has only one jeep crd certifide mechanic. i have an ongoing problem that i have not read anything about..my crd looses all power after a heavy run..it don't happen all the time and only is rectified bye pulling over and shutting the truck off/and restarting it.. this has happend several time over the last year and getting more common.i have had the truck in the shop a few times and have been told differant things each time ..well the last few times ive been in there i have noticed that there is a 2006 crd sport sitting in the same stall each time .. after talking to the mechanic i soon found out that it has just been "bought back" from the owner. it has had many of the troubles that i read about but the transmition shutter and the unexplained loss of power was it's final straw. ive just been told that my turbo is bad and that it will be several weeks before it will be fixed due to three other crd's with bad turbos that are ahead of mine.. all of which have over 30000 ml's and under 65000 mls . "glad i bought an extended warenty. has anyone else had these problems. if so please let me know. thank you
Do you come to a full stop after the "long effort"?
I noticed sometimes by selecting Neutral then Drive again, or just by pushing the brake pedal the converter gets loose again and I don't stay in a creep mode anymore. This normally occurs when I slow down to 20mph without braking: the tranny remains in 2nd gear with the converter locked. It's just a bug in the program :surprise:
If you don't mind getting your hands dirty, pull out your boost sensor and turbo vanes actuator filter. When no error code shows up on the console, you need a bit of luck or lots of money to understand what's going on. This is what I called our "Sword of Damocles" a few years ago...
Ask yourself what the computer cannot see:
- the cleanliness and efficiency of the individual filters
(diesel fuel, intake air, turbo vanes vacuum line)
These 3 items are the cheapest consumables of the lot.
Practically all the other elements are electrically controlled. If you had EGR problems you would generate lots of black smoke in one condition and a Lambda sensor error in the other. If I were in your case, I would change these filters first. This can cost you less than driving back and forth to the dealership.
When I reached 60,000 miles the maintenance cost me far too much money. Since then I have an enormous rattle, mushy performance, air in the brake line, damaged a/c plumbing, and no more limited slip differential because the dealership used a friction additive in the rear differential. They got everything wrong this time and it's a pain to end up fixing the truck myself.
Some manufacturers offer 5 years warranty, so customers must go to the dealership during these 5 years otherwise they loose their warranty. This is their latest trick to grab our money.
I have a 2005 liberty CRD and it 90,000 miles on it. recently I have experienced smoking from the exhaust at idle. I replaced the pressure relief valve for the crankcase which is connected to the intake (preturbo). That did not solve my problem. I either have a turbo with bad seals or the engine is losing ring compression. After reading your message I am leaning more towards bad turbo. I have no warranty left so have gone on line to find a replacement turbo. The turbo is made by Garrett and I found one for $795.00 exchange. this is about 1200.00 less than the list at the dealer. What I am wondering is if anyone has experienced this oil burning smoke prior to finding out the turbo is bad or if I might have a larger problem in the engine.
The first test is to check your engine compressions (4) taken through the glow-plug holes. Then monitor the engine oil pressure with a manometer instead of using the digital information; a good technician will evaluate the condition of the engine by observing the oil pressure variations. Perhaps your oil is not thick enough? Some turbos only last 100,000 miles :sick:
1. Be gentle with the engine and turbo for the first three to five miles of driving this is in spite of the fact we all use (hopefully) synthetic oil in the engine.
2. After driving any length of time or speed, it is good to let the turbo cool down before engine shutdown. The user's guide tells you how long and then add 50% more time.
3. Change oil and filter more frequently than called for by the manufacturer. It may seem like a waste of money and time but it is cheaper than replacing major engine components.
4. If you are using Mobil 1 0W-40, then you are asking for trouble. Several Jeep dealers I know of, including the one I use, do not use Mobil 1 any longer in any of the diesels or the spark ignition engines. The dealer I use gets RedLine 5W-40 diesel oil. I use it and I have been happy with it for some time.
5. Smoke at idle is as I see it not a turbo issue. Are you having oil consumption issues? You do not tell us what kind or color the smoke is so it makes it hard to diagnose the issue.
My turbo is starting to leak oil and I have experienced the loss of power and restarting the vehicle twice within the last 4 months and increasing black smoke at higher RPMs. Also have an EGR engine code. I currently have oaver 140K miles, so I guess it's about time. I was wondering where you found the Garrett turbo for $795 and what model is it?
